Technical Topics DIYs and Coding Discussions ESYS G20 coding - getting started
      12-14-2019, 07:21 AM   #67
sd_dracula
Drives: 2020 G20 330e
I just enabled the lane change assistant
Would also like to extend the time the car can drive without hands on the wheel when in bad traffic.
The most important feature for me (if possible) is if the car is in electric/hybrid mode and you kick down the pedal, to make it jump into sport mode without pressing any button.
Has anyone found codes for anything like that?
      12-14-2019, 10:41 AM   #68
unclez
Drives: VW
Hi,
is there any way to enable the Blouetooth extended to have phone screen mirroring?
      12-14-2019, 11:29 PM   #69
blazesquall
Drives: G20 m340i, G30 m550i LCI
Originally Posted by unclez View Post
Hi,
Are you sure you need Enhanced Bluetooth for this? I don't (No wireless charging) and I can screen mirror via Miracast.
      12-15-2019, 09:47 AM   #70
unclez
Drives: VW
Hi,
are you on iDrive 7 or 6?
I am afraid on iDrive 6 it does not work -_-
I do not see any option for screen mirroring when connecting my Android device. Do I need to have any specific app on the phone?
      12-15-2019, 10:19 AM   #71
zmm12345
Drives: x7 and 330i
Originally Posted by NYC_340i View Post
Originally Posted by cjof2003 View Post
Yes, it has been turning on every day for me this week.
Try setting IKF_ENABLE to "ikf_alle_sitze" in BDC_BODY. I left that out as it references seats, but it is a setting I was messing with and have not yet reverted.
That worked for me. Able to check off the auto heated steering wheel box and set a temp. Also confirmed the wheel heating comes on automatically. Thanks!
I coded this, but don't see any checkbox for auto heater steering wheel.
Where should it show up? In climate rules?
      12-15-2019, 02:04 PM   #72
NYC_340i
Just to make sure but along with that AKT_Auto_Lenkrad and LHZ_CCM_IKF need to both be enabled. And yes if you hit the menu A/C button it should show as an option as shown in the picture in the first post.
Current: 2020 M340xi
Previous: 2016 340xi
      12-15-2019, 04:08 PM   #73
zmm12345
Drives: x7 and 330i
It's working, thank you
I didn't realize that it's in its own menu
      12-15-2019, 11:08 PM   #74
tturbolife
tturbolife's Avatar
Drives: None
2020 BMW M340i  [0.00]
Does anyone know if it is possible to enable text message notifications? I do not have the wireless charging option...
      12-16-2019, 01:19 AM   #75
luckyfrederic
Drives: BMW G20
[QUOTE=cjof2003;25506884]Getting Started
Start here - https://www.bimmerfest.com/forums/sh...php?p=10193333
NOTE: Do NOT follow the charity donation instructions in the PDF in the link above. Instead, email tokenmaster directly and request the donation instructions. You should receive an auto reply detailing the exact steps and requirements. Follow those and you should get launcher pro 3.x fairly quickly.
Once you have all the software installed per the link above, go here - https://www.bimmerfest.com/forums/sh...d.php?t=983245
I had issues getting Launcher PRO to update the cheat codes, so I went to - https://github.com/packetpilot/bmw-f/tree/master/cheats - and downloaded the repository as a ZIP. I then extracted the contents of the cheats folder to:
C:\Program Files (x86)\TokenMaster\E-Sys Launcher PRO\FDLCodes
Then, in Launcher Pro I selected the Authors I wanted to load. The following are Authors are good to start with for g20 coding (s18a):
  • Almaretto
  • jokinawa
So far, I have successfully coded the following:
  • Remove legal disclaimers (all)
  • m startup animation
  • ASS memory
  • ASD off
  • air con memory
  • video in motion (works using jokinawa's cheats and instructions)
  • close trunk from fob
  • close trunk from door switch
  • full SMS display
  • Coasting
  • Flashing Brake Force Display (need to test)
  • Speed Correction
  • Auto activate heated steering wheel when cold
  • 5x Turn Indicator
  • Lane change assistance (I already had assisted driving view from the factory, thanks to Marcelo_BSB)
  • Comfort+ Mode (these settings are also also selectable in ECO PRO individual)
Hello
Would you have a list with all of the coding you've done ?
I have already done some basic coding, and some that you mention interest me
      12-16-2019, 04:52 AM   #76
SwissTone
SwissTone's Avatar
Drives: BMW G20 330e
Guys,
Some help please, I'm getting the following error message -
The NCD file name "Almaretto.xml" has to contain the SGBMID (z.B. cafd_0000000b_001_000_001) of the appropriate CAF. [C011]
What am I doing wrong?
I have installed and loaded as per instructions, I have a G20 330e if this helps?
TIA
Charlie.
      12-16-2019, 10:53 AM   #77
royhsiao
Drives: f10
Originally Posted by haruny View Post
Same here. No response from tokenmaster. Can't get launcher pro.
reread his instructions carefully
      12-16-2019, 10:56 AM   #78
haruny
Drives: 2020 BMW M340i
2021 BMW X5 45e  [0.00]
Yes. Got a response finally.
2020 M340i RWD | C3Z | MAPQ | ZDA | ZDY | ZPK | ZPP | 1CR | 1PU | 688 | 6NW | 2VF | 316 | 4UR
Visit my Instagram
      12-16-2019, 09:39 PM   #79
zmm12345
Drives: x7 and 330i
Can someone explain how I can save all the code files to my computer for review?
I want to be able to sit at home and browse the cafd folder, without having to sit in the car connected
      12-16-2019, 09:41 PM   #80
zmm12345
Drives: x7 and 330i
[QUOTE=luckyfrederic;25575431]
Getting Started
  • Almaretto
  • jokinawa
  • ASS memory
  • ASD off
  • air con memory
  • full SMS display
  • Coasting
  • Speed Correction
  • 5x Turn Indicator
[COLOR="Blue"]Hello
[/COLOR]
I coded comfort plus, but am skeptical if it's any softer. I tried switching back and forth today, and couldn't tell the difference. I wonder if it can actually get softer without an adaptive suspension
      12-17-2019, 06:38 AM   #81
siegester
siegester's Avatar
345
Drives: '20 M340i
I connected to the car, read each ECU, disconnected, and then browsed them from my desk. Once I found what I wanted to change I went back to the car reloaded and reconnected, then started coding
I have adaptive suspension and it doesn't get any softer. Even in my F06 which had c+ from the factory the ride firmness stayed the same. I believe all that changes is throttle response and steering response. Honestly, I cannot tell if there is a difference for sure on the G20. I feel like there is, but that could just be in my head
Originally Posted by SwissTone View Post
Guys,
TIA
Charlie.
This is a new one for me. Check around some F series coding forums for similar errors (without the specific cafd id)
Hello
The list you quoted is the list I have coded. If you dont see an item in the table I posted, it is available through one of the cheat authors I mentioned. Just read and edit the corresponding ECU and you will see the cheats on the right side of esys
      12-17-2019, 06:55 AM   #82
Marcelo_BSB
Drives: 328
I see everyone setting only 3 codes for track change, but in the video are made 4 changes. You have made 3 or 4 changes to the codes. I haven't seen anyone talking about this: SICHT_ABSICHT_ENABLE
      12-17-2019, 07:00 AM   #83
luckyfrederic
Drives: BMW G20
I only see this in your table:
Feature ECU Property Value
seat heat distribution rear HU_MGU HVAC_SEATHEAT_DISTR_FOND aktiv
seat heat distribution front HU_MGU HVAC_SEATHEAT_DISTR_FRONT aktiv
auto steering wheel heat HU_MGU AKT_Auto_Lenkrad aktiv
BDC_BODY LHZ_CCM_IKF aktiv
BDC_BODY IKF_ENABLE ikf_alle_sitze
lane change assistance BDC_BODY SPURWECHSEL_ASSISTENT aktiv
HU_MGU SPURWECHSELASSISTENT gen_1
SAS2 C_SWA_VORHANDED NR001_VORHANDEN
not others ?
Thanks
      12-17-2019, 05:05 PM   #84
zmm12345
Drives: x7 and 330i
Does anyone know if I can code that remote start should also turn on the seat heaters?
      12-17-2019, 05:14 PM   #85
tommytexter
tommytexter's Avatar
Drives: 2020 M340ix
not others ?
Thanks
Lane change assist only work on hwy for my car
      12-17-2019, 09:23 PM   #86
siegester
siegester's Avatar
345
Drives: '20 M340i
I have been looking when I can, but no luck yet
      12-20-2019, 11:45 AM   #87
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
@zmm12345 ,
I code using my laptop & do "research" & the like on my desktop.
The first time I connected, I saved VO, SVT & all CAFD files (using SAVE file in E-SYS). I then copied to USB drive and further copied to appropriate sub directory on desktop's hard drive. There's a simple to copy all CAFD; I'd post it, but am not near it -- but not hard to just copy the respective directories to USB drive
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      12-20-2019, 03:28 PM   #88
1012067361
Drives: 2019 330ix
How to code comfort+ and sport+ in g20?
