2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Photos / Videos / Journals Have you seen the grill slats opened?
      03-29-2020, 11:45 PM   #1
Bmwphile
Bmwphile's Avatar
Drives: 2020 G20 330i
Has anybody seen or have photographic evidence the radiator slats open? I'm beginning to think it doesn't happen! LOL
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK
2012 F30 328i Sportline (Mineral Grey)
      03-30-2020, 01:19 AM   #2
bcr
Drives: G20 330i
I've seen it once on my 330i: at the gas station, just after testing max speed in Germany. Looks pretty good, actually.
      03-30-2020, 06:42 PM   #3
purpl3ish
purpl3ish's Avatar
Drives: 2023 G80 Velvet Orchid M3
put the car on MAX AC and they open
2020 G20 Twilight Purple M340i xDrive,
2017 F80 30 Jahre, 2011 E92 335i xDrive///M3, 2012 E93 ///M3 -- Retired
      03-31-2020, 12:47 AM   #4
Bmwphile
Bmwphile's Avatar
Thanks Choyboy.
Now I need to see open slats on a 330i!
BMWphile
      03-31-2020, 08:50 AM   #5
Mega8489
Mega8489's Avatar
200
Drives: Bmw 2023 G80 M3 6spd
What lip is that ?the m performance one witouht splitters?
Thanks
      03-31-2020, 08:53 AM   #6
purpl3ish
purpl3ish's Avatar
Thanks
yep!
      03-31-2020, 08:54 AM   #7
Mega8489
Mega8489's Avatar
200
yep!
Thank you !
      03-31-2020, 11:09 AM   #8
VipinLJ
VipinLJ's Avatar
Originally Posted by Bmwphile View Post
Thanks Choyboy.
Here you go
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      04-01-2020, 12:10 PM   #9
Rocket455
Grumpysaurus Rex
Rocket455's Avatar
Drives: 2022 M550i
1972 Firechicken  [0.00]
1969 Toronado  [0.00]
1970 Camaro  [0.00]
May depend on how you drive it. I'm always in Sport Plus and drive it like I stole it; almost never seen the slats closed upon parking and exiting the car.
      04-01-2020, 05:45 PM   #10
oln08
Drives: '19 M2
Thanks Choyboy.
here's another one.
VipinLJ1936.50
      04-12-2020, 02:06 PM   #11
reyoasian
Drives: 340xi MPPSK
What triggers it to open?
Can you code it to stay open?
      04-12-2020, 04:17 PM   #12
advantage20
advantage20's Avatar
France
1872
Drives: 330d
Why aren't they painting the V-brace black so as to make it invisible behind the open grille?!
      04-13-2020, 09:55 AM   #13
StevenX94
Drives: Bmw
Was wondering the exact same thing!
In worst case one should be able to paint them with some kind of black paint when removing the grill I guess?
      04-13-2020, 12:03 PM   #14
purpl3ish
purpl3ish's Avatar
max AC...
      06-15-2020, 10:46 AM   #15
VipinLJ
VipinLJ's Avatar
Finally saw mine open yesterday! Summer temps here in IL caused them to open I guess.
      06-15-2020, 02:59 PM   #16
StevenDS85
I ///M Fan
Drives: BMW 330i M-Sport
Put max AC on and they will open.
VipinLJ1936.50
      06-15-2020, 03:06 PM   #17
Dmejia91
Drives: 14 F30 335 xdrive M Sport
Did some spirited driving and BOOM, lungs opened up
      06-16-2020, 05:26 PM   #18
nola2atx
nola2atx's Avatar
Mine are open every time I park. I drive fast :
///M340i Portimão
My Exes:
E36, E46, F30
      07-01-2020, 11:27 AM   #19
miked1999
2020 M340i  [0.00]
I heard you can pull a fuse (no idea which one) when it's in the open position and it will remain open.
Hoping someone figures out how to disable the shutter and shares this knowledge with the tribe.
      07-01-2020, 12:48 PM   #20
VipinLJ
VipinLJ's Avatar
No idea if you can pull a fuse to leave it open since that might trigger a CEL.
But there’s a thread in the X3 forum where people cut plastic tabs to leave the slats open permanently. A CEL isn’t triggered since the motor works but it isn’t attached to the slats. Only problem is that it is irreversible unless you get new parts.
      07-02-2020, 03:50 PM   #21
miked1999
2020 M340i  [0.00]
I read about the fuse solution in the 5 series forum...don't recall any mention of it throwing a code, at least in the posts I read but not saying it won't. Not opposed to invasive procedures like cutting tabs, but thinking the fuse approach is worth a try initially.
VipinLJ1936.50
      07-02-2020, 04:22 PM   #22
VipinLJ
VipinLJ's Avatar
Ah ok. If there’s a fuse you can pull, I’d be interested. I’m opposed to cutting stuff unless it’s reversible without being too expensive. Which is why I didn’t bother to pursue it further. Though I’d like to leave the slats open permanently and stick some vinyl on the V brace behind it
Edit - Found the link you mentioned. Someone said pull fuse 203. I'll try that and see what happens
