Technical Topics DIYs and Coding Discussions M Logo Coding In Default Instrument Cluster Tutorial
      04-09-2020, 04:26 AM   #1
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [0.00]
Hello
To enable M Logo in default instrument cluster, go to DKOMBI4 and look for LOGO_SCHRIFTZUG, then select msp_logo.
Enjoy M Logo in default instrument cluster!
View screenshots for reference:
Appreciate 12
      04-09-2020, 07:19 AM   #2
JSaid
JSaid's Avatar
Drives: 2022 BMW M340i xDrive
Originally Posted by g20beam View Post
Hello
Wow, so VipinLJ was VERY close! Thanks for this, Ill be doing this during my lunch break
VipinLJ1941.50
      04-09-2020, 08:52 AM   #3
JSaid
JSaid's Avatar
I just added the M logo successfully, Thanks again g20beam
Anyone else get a little nervous every time the ECU restarts after coding? lol
      04-09-2020, 10:54 AM   #4
VipinLJ
VipinLJ's Avatar
I chose the m_logo instead of msp_logo since I didn’t want the M performance lettering (I thought msp was m performance). It didn’t work so I didn’t pursue it further. Glad g20beam posted this here.
Edit - Yes JSaid. I still get worried when the iDrive/live cockpit is restarting after coding.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
g20beam474.50
JSaid286.00
      04-09-2020, 12:27 PM   #5
mmo011
Drives: BMW 320d MSport (G20)
No way for me :-( tried several time starting back from original backup with Bimmercode... tested M_Logo, Msp_Logo, more others... but nothing appear... M Logo appear only with M Style Cockpit that's not ok for my G20 320d-> 8k RPM and 330Km/h scale are too much higher :-(
      04-09-2020, 12:32 PM   #6
mmo011
what about the m stripes near the 0mph gauge into the picture? it's something stock or coded?
      04-09-2020, 12:40 PM   #7
VipinLJ
VipinLJ's Avatar
That is present on 330is with the M sport package. I don’t have it since mine doesn’t have the pack. If someone could find out how to code that in, I’d be grateful. I like those subtle stripes and don’t mind those on the live cockpit
      04-09-2020, 02:20 PM   #8
mmo011
I have MSport Pack on my EU 320d but no stripes at all 😔
      04-09-2020, 03:52 PM   #9
hamzag20
hamzag20's Avatar
557
Drives: BMW G20 330i, BMW G30 540i
Worked great! Thanks g20beam ! Also JSaid I get hella nervous with those weird noises that are made too lmao when the ECU restarts.
      04-10-2020, 02:06 PM   #10
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
I had never noticed this in my car so looked for it today. Found out that it shows in sport mode.......
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-11-2020, 11:53 AM   #11
Fpangalos
Fpangalos's Avatar
Drives: 2019 BMW 330i
g20beam474.50
      04-11-2020, 12:17 PM   #12
VipinLJ
VipinLJ's Avatar
If any of you ever figure out how to code the tri color stripes next to the 0mph on the LC, please post that here. I searched but couldn’t find anything that made sense to me.
      04-11-2020, 12:36 PM   #13
g20beam
g20beam's Avatar
2019 BMW  [0.00]
If any of you ever figure out how to code the tri color stripes next to the 0mph on the LC, please post that here. I searched but couldn't find anything that made sense to me.
You have to change your car's info from a Sport Line to an M Sport line in DKOMBI4, there's some lines in there that differentiates M Sport models from Sport Line.
VipinLJ1941.50
      04-11-2020, 12:41 PM   #14
VipinLJ
VipinLJ's Avatar
I assumed that was it. The reason I didn’t want to do that was because I think that might change the pic of the car on the LC to an M sport pack car while mine is the sport line. Guess I’ll have to live without the stripes then
      04-11-2020, 02:16 PM   #15
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Hi, Does it work on Alpina Cluster as well?
hamzag20 How did you get the G meter showed up ?
      04-11-2020, 02:49 PM   #16
VipinLJ
VipinLJ's Avatar
It should work on the alpina cluster too since that option is present.
And the G meter is already present. Press the BC button on the indicator stalk to go through the various menus and you’ll see the G meter pop up there.
hamzag20557.00
      04-11-2020, 07:40 PM   #17
hamzag20
hamzag20's Avatar
557
What VipinLJ said
VipinLJ1941.50
      04-12-2020, 02:00 AM   #18
g20beam
g20beam's Avatar
2019 BMW  [0.00]
No it actually won't, the modules are separate, the car in the IC and the control display can be selected regardless of the Sport Line or M Sport configuration. I know this because I tried changing the trim and colour of my car in the iDrive control display and the IC changed as a result of the change made to the control display.
VipinLJ1941.50
      04-12-2020, 02:19 AM   #19
MY86
MY86's Avatar
Turkey
15
Thanks for the reply. I have a 2019 M Sport 320i from Istanbul / TR and the G meter does not pops up the way you said Is there anyway to code the G meter via BimmerCode?
      04-12-2020, 07:02 AM   #20
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
On my M340, the tri-color diagonal striping by 0 mph, only shows up in Sport mode.
Al
Retired: 2014 328i
BMW CCA
MAGugs1.50
      04-12-2020, 08:17 AM   #21
igorbutarev
igorbutarev's Avatar
Russia
26
Drives: F30 320i G20 320d
Do you have MGU id7 head unit? I think G-meter might be unlocked in MGU, because yesterday I found G-meter maximum value code in MGU. Parameter is G_METER_MAX_VAL. Default setting for my 320d is 0,8g. Maximum setting is 2.0g. Maybe activation code somewhere in MGU like a code for sport displays in old F30.
This is strange that you don't have g-meter if you have MGU unit, cause in Russia I have this from factory.
Off top: do you have plastic headlight covers under the hood 51767499927 and 51767499928? I found that Bmw don't install it on cars that supplied to Turkey and Russia. Strange thing for me. Price of this plastic covers is 10 $🤔
      04-12-2020, 09:58 AM   #22
MY86
MY86's Avatar
Turkey
15
Off top: do you have plastic headlight covers under the hood 51767499927 and 51767499928? I found that Bmw don't install it on cars that supplied to Turkey and Russia. Strange thing for me. Price of this plastic covers is 10 $��
Hi, yes I have the ID 7 Head Unit. It is weird that none of the cars have the G meter thing over here. We only have 320i's at the moment. Maybe, it will be available on 330i's but it is still weird. I will try changing it to 0.8g to see if it works. Thanks for that.
I did not heard of that plastic headlight cover thing before. I will check it for you and reply.
