05-04-2020, 04:27 AM | #45 |
Rep 1,039
05-04-2020, 10:50 AM | #46 | |
Rep 318
As for the individuals that can't code the logo at all, sorry but at this time there's no way to do it for your specific model. I don't know which code is restricting the logo from showing up in instrument cluster for some users, but maybe when more features are available in Bimmercode it will be possible. |
06-01-2020, 10:08 AM | #48 |
Rep 36
I solved the problem that m logo doesn’t show up in the middle of instrument cluster. If you would like to have m logo in the middle and the small logo in the left bottom next to date/time(this only in sport mode), you have to change scale from 260 to 330 kmh in Instrument Cluster Expert mode. And then change LOGO to msp. in the same module. My car is Europe 320i.
06-01-2020, 10:21 AM | #49 | |
///M SubDriver
1833
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
06-09-2020, 04:48 PM | #51 |
Rep 423
Does anyone know how to code the exit logo? I’m interested in using the alpina dials, but don’t want it to say alpina when you turn off the car. I know how to get rid of it in the center of the dials, but would love to not see it anywhere else.
VipinLJ1941.50 |
06-10-2020, 06:12 PM | #53 |
Rep 423
You can turn off the logo in the center of the cluster, but don't know how to change the car exit logo (same as with the alpina one). Think i'm just going to stick the with the M-cluster with the ///M logo removed in the center. Biggest issue is the speedo going to 200 (which i'm never going to come close to approaching) and the tach goes to 8000 (ditto). If I could figure out how to put the sport cluster as the default and have it never change, i would just do that, honestly.
08-27-2020, 02:53 PM | #54 | ||
Rep 25
1st you search for ag_mpa_msp_view. Then you select msp_ansicht and code. Once this is done and you did the coding with the msp logo you should see it 😃 Thanks for g20 beam for starting this |
VipinLJ1941.50 |
08-28-2020, 09:42 AM | #55 | |
Rep 28
The little three colours "MSP" on left side is working, but logo in center still not |
08-28-2020, 11:25 AM | #56 |
1942
Rep 3,521
Is yours an m sport version?
08-28-2020, 12:36 PM | #58 |
1942
Rep 3,521
Thats why you have the M lines on the bottom left.I believe its standard in cars with the m sport pack.
08-28-2020, 02:40 PM | #59 |
Rep 28
08-29-2020, 04:07 AM | #60 | ||
Rep 25
To enable M Logo in default instrument cluster, go to DKOMBI4 and look for LOGO_SCHRIFTZUG, then select msp_logo. Select this option and press code. It should work if you followed the previous steps! |
08-29-2020, 09:27 AM | #61 |
Rep 28
I did it but no working. I check msp_logo m_logo m3 etc. Only edrive works
09-05-2020, 06:20 AM | #62 |
Rep 15
09-05-2020, 09:57 AM | #63 |
Rep 218
Drives: 2020 M850xi Gran Coupe
Did anybody discover a way to use the Alpina cluster with a different logo? I believe we figured out how to use the Alpina cluster with NO logo but haven't seen a solution to use a DIFFERENT logo.
Current Ride
2020 M850xi Gran Coupe Previous Rides 2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi |
09-06-2020, 09:49 PM | #64 |
Rep 243
I can confirm, i coded a few cars with the Alpina cluster. You either have to have the Alpina logo or nothing at all. For some reason with that cluster, you cant add anything else like the M logo or M340.
Saunders17283196.50 |
09-07-2020, 11:05 PM | #65 |
Rep 423
Can you change the animation when you shut the car off? Don't like that it says Alpina when you shut down..
09-11-2020, 05:15 PM | #66 |
Rep 340
Drives: G20 330ix M Sport
I'm curious is there a way of changing the exit logo from BMW to M like the M cluster? I went back to the default cluster because I wanted to be able to have the driving mode and the 3 m sport colors. I have the idrive has the exit M logo so it would be cool if I could hand the cluster do the same.
