Technical Topics DIYs and Coding Discussions M Logo Coding In Default Instrument Cluster Tutorial
      09-13-2020, 12:54 PM   #67
Wendell_S
Wendell_S's Avatar
Netherlands
10
Drives: G20 330i M pack
Originally Posted by mikeyb74 View Post
I'm curious is there a way of changing the exit logo from BMW to M like the M cluster? I went back to the default cluster because I wanted to be able to have the driving mode and the 3 m sport colors. I have the idrive has the exit M logo so it would be cool if I could hand the cluster do the same.
Unfortunately not (yet). I've tried various ways but the only way I seem to get this when programming the M cluster.
But just like you and others; I like the original cluster way better.
      10-08-2020, 02:15 PM   #68
Msb12i
Msb12i's Avatar
Drives: Coded G21 330E
Originally Posted by 330e View Post
I did it but no working. I check msp_logo m_logo m3 etc. Only edrive works
Same here.
I think , like the Alpine cluster is not able to show M logo, edrive's are also not able to show M logo's.
But hey, we can drive zero emisson with TAX reduction
      10-11-2020, 03:44 AM   #69
Koszal
Poland
Drives: BMW G20
I had a problem with coding the M logo in the center of instrument cluster.
After the Wendell_S post I coded the central logo
Originally Posted by Wendell_S View Post
I just found out how to to do it....
1st you search for ag_mpa_msp_view.
Then you select msp_ansicht and code.
Once this is done and you did the coding with the msp logo you should see it ��
Thanks for g20 beam for starting this
Unfortunately, I can't code a little mpereformance stamp on the speedometer:
Do you have an idea what else I can check? My car is 330i in m package.
//edit
As RSnic wrote:
On my M340, the tri-color diagonal striping by 0 mph, only shows up in Sport mode.
The stripes are visible only in sport / sport + mode. I answered the question myself
      01-13-2021, 08:34 PM   #70
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
Has anyone coded this back after the OTA updates? Just tried didn’t seem to work and it reset my clock. Got aa new to set time and date error.
      01-27-2021, 11:33 AM   #71
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
I have been able to code the M logo back after the last 3 software updates and service reprogramming my 330i.
      01-29-2021, 06:47 AM   #72
Zultan
Drives: BMW G21 m sport
Worked like a charm. M logo and M stripes have been coded in the instrument cluster on a 320d m sport (EU).
Thank you everyone for your help.
      02-11-2021, 09:45 AM   #73
Rux
Rux's Avatar
644
Drives: Little of this, little of that
2024 BMW G42  [0.00]
2022 BMW G82  [0.00]
just to add to this. Using Normal Bimmercode on an M440i xDrive, changing the instrument cluster to the M or Alpina removes the M440i from the center of the screen. I assume going into expert mode and using the previous stated process would restore that?
      02-11-2021, 10:03 AM   #74
VipinLJ
VipinLJ's Avatar
Not sure you can get the M440i logo in either of those two clusters.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-17-2021, 12:03 AM   #75
B530e
B530e's Avatar
284
Drives: 2023 BMW 760xi, 2024 BMW 530i
2021 BMW 540i  [0.00]
2020 BMW 530e  [0.00]
I assumed that was it. The reason I didn’t want to do that was because I think that might change the pic of the car on the LC to an M sport pack car while mine is the sport line. Guess I’ll have to live without the stripes then
https://g30.bimmerpost.com/forums/sh....php?t=1800045
VipinLJ1941.50
      06-17-2021, 03:55 AM   #76
sd_dracula
Drives: 2020 G20 330e
Originally Posted by Msb12i View Post
Same here.
Yeah I tried this also in my 330e and if I code msp_logo it just makes the edrive logo disappear
ag_mpa_msp_view was already coded to msp_ansicht so maybe some other coding is required to make it work or just not supported on the edrives
On another note, I also coded ///M start up logo on the idrive screen but my cluster is still showing BMW text, do you guys know what I need to code inside DKOMBI4 to display the ///M start/leave logo?
      12-21-2021, 04:57 AM   #77
baduefalo15
Drives: bmw 430i m g22
Originally Posted by g20beam View Post
Hello
To enable M Logo in default instrument cluster, go to DKOMBI4 and look for LOGO_SCHRIFTZUG, then select msp_logo.
Enjoy M Logo in default instrument cluster!
View screenshots for reference:
i dont found DKOMBI4 and look for LOGO_SCHRIFTZUG, then select msp_logo
why???
      12-21-2021, 01:41 PM   #78
Andy3661
Andy3661's Avatar
122
I coded M layout which also add the M logo and M start up.
Changes the HUD as well.
      12-22-2021, 11:47 AM   #79
pdxdbo
pdxdbo's Avatar
331
Drives: G20 330i xDrive M-Sport
Has anyone had success tinkering with HUD values? I'd prefer to run the M Performance 160mph display but enabling that configuration does not change the HUD number font to match the display.
Has anyone been able to update the HUD independently via Bimmercode?
      12-24-2021, 04:01 PM   #80
CY330e
Drives: BMW 330e
[QUOTE=sd_dracula;27709266]Yeah I tried this also in my 330e and if I code msp_logo it just makes the edrive logo disappear
On the M mode makes the battery gauge to disappear, did you find any way to be visible?
      12-26-2021, 01:49 PM   #81
Doruk
Drives: 2013 528XI
I looked everywhere with no answer. I have g30 m sport 540. I can appear the m550i logo in comfort mode but cannot bring the M logo in comfort mode using bimmercode. It is there for sport mode. Any idea? From the same options using bimmer code. M550 m440 etc works but the M does not !! So weird.
      12-27-2021, 02:30 AM   #82
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
Using in Bimmercode M Sport layout brings M center logo as well as the colored stripes in Sport modes . When with M layout you get the oil temp in the lower right corner but keep oil temp in the central screen , therefore water temp is not accessible anymore . When you use M Sport layout , you will keep water temp in the main cluster .
      10-04-2022, 12:58 PM   #83
Tzeunis
Drives: BMW 330e M Sport
Did anyone succeed in getting the M logo into the cluster in sports mode on a 2021 330e M Sports?
      12-20-2022, 03:32 PM   #84
Manboy
Manboy's Avatar
Sweden
440
Drives: 2020 M135i Misano Blue
BMW changed something with the latest software for KOMBI. If you chose M Cluster in Bimmer code, and have the latest sofware you are going to get the "3.0CSL" logo by default. If you then try to code another logo via LOGO_SCHRIFTZUG the "3.0CSL" logo will disappear and it will just be a blank space.
I did not have this issue before my update in November.
      12-20-2022, 08:00 PM   #85
okankaymak
Drives: 2021 330xi M Sport
I'm after the same thing. I'm running the M Performance 160mph display as well but the HUD font doesn't match with the cluster font. Did you figure this out?
      12-20-2022, 08:25 PM   #86
pdxdbo
pdxdbo's Avatar
331
Nope :/
I haven’t seen much progress outside of the M module but that still doesn’t solve this particular problem.
      12-23-2022, 07:42 PM   #87
1WickedE90
1WickedE90's Avatar
Drives: 2022 330i
I just got the 11/2022.27 update done last week & can confirm this is true, hoping someone figures this out.
      02-21-2023, 05:41 PM   #88
greg624
Drives: 2021 BMW 330i
2021 BMW 330i  [0.00]
I’m also trying to figure out the hud font… weird how it’s in the actual m cluster but I can’t find the option to have regular m performance display with the same font in the hud
