Technical Topics DIYs and Coding Discussions I added Equalizer Settings on my G20
      06-05-2020, 06:21 AM   #23
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Originally Posted by Ventura24G20 View Post
so i can use both without any issues correct?
It replaces the actual app.
      06-07-2020, 01:08 PM   #24
Swagasaurus-R3X
Swagasaurus-R3X's Avatar
Drives: BMW M340i
Originally Posted by MY86 View Post
No. You don't have to do that.
How did you get the beta mode to access Expert mode in the HU_MGU?
Nevermind. I requested it.
      06-12-2020, 01:09 AM   #25
Chevychong
Drives: BMW 330i G20
Originally Posted by Guns N Roses View Post
Finally after a lot of try and error here is my first post and contribution to this forum after I purchased my g20 last year I noticed the lack of equalizer settings on my Base 330i I was thinking no problem I can add one WRONG ! Well after going to numerous places getting quotes and getting non sense amounts from 2k to 4K you can do it because of the ram radio thanks to bimmercode and research on expert mode here is the procedure go to bimmercode to HU MGU HEADUNIT then expert mode from there pic 3002 then look for AUDIO-SYSTEM then change the parameters from alev2-Ram to alev4-Ram code and you got a free working Bowersand Wilkins settings and working equalizer enjoy,
May I know what adaptor do u use? My one is OBDLink MX+ , but I can’t get the expert mode on HU MGU HEADUNIT.
      06-12-2020, 03:32 AM   #26
VipinLJ
VipinLJ's Avatar
I have the same adapter and mine can access all modules and expert coding just fine
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      06-12-2020, 04:04 AM   #27
MY86
MY86's Avatar
Turkey
15
You need to email to developer from the app in order to download the beta version and reach the expert mode on Head Unit.
      07-20-2020, 09:46 AM   #28
BBH
Drives: BMW G20 330i M-Sport
Just coded this into my car, thanks OP
The change in sound quality is stellar, base & the surround sound is astonishingly good in any sound profiles except "Studio" (mainly cuz the profile disables surround sound). I have the HK system so I can't say it'll work on stock or Hi-Fi systems.
      07-24-2020, 08:01 PM   #29
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
My car has HK audio. I coded this, noting that the starting value was alev3RAM.
Also, I noticed that, in so doing, this replaced the L7 checkbox and is MUCH BETTER!
Al
Retired: 2014 328i
BMW CCA
      07-25-2020, 03:50 AM   #30
rickkap
Drives: 320d XDrive M Sport (G20)
Hi,
I also have the HK audio and not really happy with the sound quality and was thinking of upgrading to Eton.... did you say changing the value to alev4RAM makes the sound better??
      07-25-2020, 04:30 AM   #31
Yossi123
Drives: 330xi G21
And how on earth is this even possible? Is the hardware for HK and B&W the same? (except the speakers ofc) B&W is not even available for 3 series...
      07-25-2020, 05:11 AM   #32
helmet91
helmet91's Avatar
Netherlands
298
I don't think it has anything to do with hardware and everything to do with software.
I have the HiFi 676 in my 330 and this works. I didn't mess with it too much, but to test I cranked the lowest frequency all the way down and my bass went away. So it works...
      07-25-2020, 05:25 AM   #33
Yossi123
Drives: 330xi G21
That is what I meant. For now the HK is the "high end" option and I find it very surprising that BMW decided not to unleash all of the available quality. It is like they've already prepared it for introducing B&W option, by simply reprogramming the head unit (and maybe upgrading the speakers).
      07-25-2020, 05:50 AM   #34
RSnic
RSnic's Avatar
rickkap ,
The surround sound is much better with this then the standard HK L7 and even works with SiriusXM. The only down side I noticed so far is that after coding, the equalizer went back to flat so I have to adjust. Even with that, I like it better than L7
Al
Retired: 2014 328i
BMW CCA
      07-25-2020, 07:38 AM   #35
rickkap
Thanks i'll give it a go before ordering Eton replacements...
      07-25-2020, 02:56 PM   #36
andy5468
andy5468's Avatar
90
Drives: BMW G20 M340D LCI
I have also just coded this to my existing HK sound system, going from alev3RAM to alev4RAM which as others mention has replaced my Logic 7 tick box with the concert, studio, theatre settings etc.
Sounds good and the graphics look slightly better than before too.
Good find.
      07-25-2020, 06:01 PM   #37
VipinLJ
VipinLJ's Avatar
I have the Hifi system too but I didn’t notice any difference between the various options (studio, concert etc etc). They all sounded the same to me.
When you try and adjust the equalizer, only the two sliders on the ends work. The ones in the middle had no effect when I changed it in my car. The Hifi system has only bass and treble IIRC. I assume the ones in the ends are bass and treble. That’s why I mentioned in my previous post that it didn’t work with the Hifi system.
      07-26-2020, 03:43 AM   #38
rickkap
I can't believe what a difference this has made to the sound quality especially the bass now rocks!!
I did this via e-sys (as i have andriod so no expert mode) so if anyone needs the setting it's:
HU_MGU then
CAFD_3E52 then search for
3002 and you will see
AUDIO-SYSTEM change to
alev4-Ram
Great find... thank you dude
      07-26-2020, 10:57 AM   #39
VipinLJ
VipinLJ's Avatar
HU_MGU then
alev4-Ram
Android has expert mode.
And do you have the HK or HiFi system?
      07-26-2020, 02:54 PM   #40
AlexxZeman
AlexxZeman's Avatar
Germany
23
Drives: BMW G20 320iX
OMG, to get equalizer on Hi-fi would be like a blessing ))
Will try it asap ))
      07-26-2020, 05:22 PM   #41
rickkap
My bad... i thought it was on the beta version... anyway it's so much better... i have the HK system and it was lacking bass before but now it does sound a lot better...
VipinLJ1941.50
BBH15.00
      07-27-2020, 04:49 AM   #42
helmet91
helmet91's Avatar
Netherlands
298
Frequencies are frequencies though, right?
This is just giving more options to adjust?
      07-27-2020, 09:24 AM   #43
VipinLJ
VipinLJ's Avatar
Well. It gives us more options but changing those frequency sliders don't change the output. Only the ones on the ends does. That's the treble and bass slider I believe. Also, the preset settings don't work in my car.
This is in my car. Not sure how it works for others with the HiFi system.
      07-27-2020, 08:39 PM   #44
patnaik
Drives: 2019 330i xDrive
It works (or more precisely doesn’t work) in exactly the same way in my car. I coded it off.
VipinLJ1941.50
