Technical Topics DIYs and Coding Discussions Random things I've come across trying to enable M TRACK tachometer
      07-07-2020, 09:42 PM   #1
imported_nick
Drives:
So I'm determined to figure out how to enable the M/Track tachometer in the instrument cluster on my M340i, but so far have been unsuccessful using Bimmercode Expert Mode...
I did however manage to find two things that work (and many others that don't work)
1) xVIEW:
Has working altitude and inclinometer (roll axis only)!
2) Tire Pressure/Temperature widget (with BC button):
It works!
Now for some other things that look interesting but don't actually do anything at all...
3)
I think this is on the right track to enable the M tachometer, but it doesn't save the command or do anything.
4)
Same with the M Menu, doesn't do anything but funny to see on a non M-car
Unfortunately I changed like dozens of settings in Bimmercode so I have no idea which ones caused these features to appear
      07-08-2020, 12:07 AM   #2
VipinLJ
VipinLJ's Avatar
Xview seems interesting
Another member had also managed to code M modes but it wasn't of any use since our cars don't have the M1/M2 buttons on the steering wheel.
Also, can you do me a favor and check your heads up display options in the display settings and see if you have the option to turn on and off the rev/shift light in the HUD? I used to have it but I believe it disappeared after I coded the tyre pressure gauges in the live cockpit.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      07-08-2020, 12:33 AM   #3
woonfah
Drives: Mazda Mx-5, BMW m340i
How did you get the tyre pressure on the BC?
      07-08-2020, 01:17 AM   #4
VipinLJ
VipinLJ's Avatar
https://g20.bimmerpost.com/forums/sh...1713770&page=2
      07-08-2020, 11:25 AM   #5
imported_nick
Drives:
Interesting, I will check it.
I wonder if we can simulate the M1/M2 button with a CAN command?
This may be the trick to turning on the M Mode Tacho
      07-11-2020, 11:27 PM   #6
Swagasaurus-R3X
Swagasaurus-R3X's Avatar
Drives: BMW M340i
1) xVIEW:
[IMG]
View post on imgur.com
[/IMG]
[IMG]
[/IMG]
Thank for your digging around.
      07-12-2020, 09:47 PM   #7
jimmmyzhou
Drives: BMW X3 30i
You'll need low-level data corresponding to M car to have the cluster imo, not just by coding some preset options.
      10-15-2020, 10:46 AM   #8
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [0.00]
Bumping this thread because I was very determined to find out if this is possible as well, glad someone else is on the same page. When I was experimenting, I managed to do all of what you did as well.
If anyone on this forum has a X3M/X4M/M8, all of these cars have M track mode tachometers, perhaps digging into HU_MGU and DKOMBI4 in those vehicles and seeing the differences in configuration in Expert Mode with Bimmercode could potentially yield to a solution for our vehicles.
      10-16-2020, 02:50 AM   #9
ramparts
Drives: M40i
It's likely you'll need to update the vo in esys and reflash the kombi to get it. It'll be missing some of the needed software files on the ecu
      10-16-2020, 06:17 AM   #10
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
imported_Mike ,
Thanks for digging around!
The Xview intrigues me. Were you digging around in DKOMKI(Instrument cluster) or HG_MGU (iDrive)?
Al
Retired: 2014 328i
BMW CCA
VipinLJ1941.50
      10-16-2020, 09:28 AM   #11
VipinLJ
VipinLJ's Avatar
imported_Mike ,
Same here. I couldn't find an option for xview when I searched. I wonder what I missed.
      10-16-2020, 11:11 AM   #12
imported_nick
Drives:
Honestly I forgot, I think it was X_VIEW (Maybe you missed the underscore). Probably in HU_MGU
Hope that helps
VipinLJ1941.50
      10-16-2020, 12:21 PM   #13
VipinLJ
VipinLJ's Avatar
Hope that helps
Let me check that out
      02-27-2021, 11:20 PM   #14
jimmmyzhou
Drives: BMW X3 30i
M widget enabled(in full version)
Hi it's possible to get these M widget by flashing your MGU(Headunit) with M vehicle FA using E-sys!
      02-28-2021, 01:12 PM   #15
VipinLJ
VipinLJ's Avatar
You can get the widget using Bimmercode but the car symbol is missing. You also lose out on some other features.
      03-01-2021, 09:39 AM   #16
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
Would be nice and more useful to get widgets for oil temperature and turbo pressure ; have you find whether that's possible? Thks
      03-03-2021, 12:50 AM   #17
jimmmyzhou
Drives: BMW X3 30i
It's possible:
      03-03-2021, 01:47 AM   #18
helmet91
helmet91's Avatar
Netherlands
298
You mind sharing with the class how to code those widgets??
      03-03-2021, 04:09 AM   #19
Asterix
Asterix's Avatar
21
Great , really what I'm looking for
How do you get them in the main cluster ?
      03-03-2021, 06:02 AM   #20
RSnic
RSnic's Avatar
jimmmyzhou ,
I have coded my car so that tire pressure & temp widgetvappears in Instrument cluster-- from another thread.
Would you be kind enough to share what functions to code to get the oil pressure & turbo pressure widget in Instrument cluster?
BTW, when I coded the tire widget, the option to display tach in HUD disappeared from iDrive, but you get get a choice in iDrive as to HUD -- standard or M,BUT M has nothing to select in it & nav info is gone
Al
Retired: 2014 328i
BMW CCA
      03-03-2021, 10:16 AM   #21
rcz22
Drives: 2024 G80 M3 6MT
I'd like to know as well!
      03-03-2021, 11:26 PM   #22
SG_E90
DaZuc
72
Drives: S65 1M Clone
It's possible:
Is it required to backup FSC codes when you reflash?
