Technical Topics Wheels and Tires Anyone running 9.5 upfront?
      10-02-2020, 08:45 AM   #1
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
Just curious to see if anyone is running aftermarket wheels with 9.5" wide upfront. Or would it be too wide?
      10-02-2020, 10:58 AM   #2
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
Drives: 20' 330i & RX 350
What's the offset?
I'm running a x9" up front with a 255 +32.
      10-02-2020, 11:35 AM   #3
jeegunkim
jeegunkim's Avatar
328
I'm contemplating running 19x9.5 +22 with a square setup. Not sure of the tire size yet but off the bat I'm thinking 245/40 or 255/35. Let me know your thoughts!
If anyone else is running a 9.5 width upfront, share experience and pics please!
      10-08-2020, 05:10 PM   #4
Adam_
Drives: 2020 330i
I'm running 19x9.5 square setup. 40 is the offset. In order to clear the strut I had to run 10mm spacers in the front but it fits quite nicely.
Could use 10mm spacers in the rear as well just to make it a bit more aggressive.
50M105.00
      10-08-2020, 05:18 PM   #5
chenry
Drives: BMWs
Not what you are asking but for what it's worth - I'm running a 19x9 ET20 on the front with a 255/35/19
      10-08-2020, 07:58 PM   #6
jeegunkim
jeegunkim's Avatar
328
Thanks guys.
I was contemplating running a square setup with 19x9.5 +22 but I've figured out my setup and will be running staggered instead of square!
      10-10-2020, 11:32 PM   #7
chenry
Drives: BMWs
Thanks guys.
looking forward to seeing your setup
      10-11-2020, 11:18 AM   #8
cywing1119
Drives: 2010 E92 M3
was trying to run 19x9.5 +22 square set but should not clear the front without installing a spacer, end up going with staggered, wait 3 months for my new wheels to arrive
      10-12-2020, 08:31 AM   #9
jeegunkim
jeegunkim's Avatar
328
We may be on the same path. My wheels won't come in for 3 months either.
      10-12-2020, 08:52 AM   #10
jeegunkim
jeegunkim's Avatar
328
Thanks man, it will be 3 months before the wheels even arrive in the states but will definitely post pics once its all installed!
      10-12-2020, 12:56 PM   #11
cywing1119
Drives: 2010 E92 M3
Can't wait until that day lol, which wheels you end up getting? and the spec of it
      10-12-2020, 01:33 PM   #12
jeegunkim
jeegunkim's Avatar
328
So it's kinda weird, I have a ton of relationships in the industry because I used to work at Nissan North America. Jesus, its been like 11 years since I left? Time flies. I went through my friend at Mackin Industries who is the sole distributer for Rays Engineering in the U.S. so I'm getting pricing at their cost. Been working with him and Rays directly on fitments for G20 and decided to order a set of TE37SL in 19x9.5 +23 and 19x10.5 +34. If Rays didn't get back to him in time, I almost ended up ordering 19x9.5 +22 and 19x10.5 +22 with 5x114.3 PCD's drilled out to 5x112, lol. It would have definitely worked as they did this on a new Supra but I'm glad we waited and got guidance from Rays before ordering, lol.
What did you end up ordering?
      10-12-2020, 08:30 PM   #13
cywing1119
Drives: 2010 E92 M3
i was about to order the same setup too lol, but i talk to one of the rays vendor in SoCal, he told me that it's hard to tell if the front will clear or not, i ended up order gram lights 57fxz overseas, TE37SL is my first choice but Rays only made A90 Supra spec, and i don't want to buy it without test fitting, thats why i go for the safe route, but if your's going to fit, i may going the same route with you lol
      10-13-2020, 08:57 AM   #14
jeegunkim
jeegunkim's Avatar
328
Nice, can't wait to see the setup!
      10-13-2020, 02:25 PM   #15
chenry
Drives: BMWs
I'm running 19x9 square +20 in the front and +25 in the rear. The setup sits pretty darn flush without poke (to my eye) but I've been looking at it thinking I could grab some spacers and bump my fronts to +15 and my rears to +20.
The reason I share this is because your specs helped out - if I ran those spacers I just mentioned I would be 2mm out on the front and the same as you in the rear vs your rays that are on order. Granted wouldnt have that beautiful width you're going to have but at least I would be sitting just as flush
Thanks again for the specs - offset is so critical to these discussions
      10-13-2020, 03:25 PM   #16
jeegunkim
jeegunkim's Avatar
328
The reason I share this is because your specs helped out - if I ran those spacers I just mentioned I would be 2mm out on the front and the same as you in the rear vs your rays that are on order. Granted would have that beautiful width youre going to have but at least I would be sitting just as flush
Agreed, glad I can help. Would love see some pics of your car.
      10-13-2020, 08:43 PM   #17
cywing1119
Drives: 2010 E92 M3
any updates on Rays?
      10-14-2020, 09:00 AM   #18
jeegunkim
jeegunkim's Avatar
328
In terms of my order?
      10-14-2020, 10:53 AM   #19
cywing1119
Drives: 2010 E92 M3
yes
      10-14-2020, 11:37 AM   #20
jeegunkim
jeegunkim's Avatar
328
yes
Nah no updates. TBH, probably won't be installing them until Spring 2021. NYC winters get nasty and the wheels won't get to me until January 2021 anyways. I'm also still waiting on Dinan to release their lowering springs so I can get it all done at once. Can't stand the look of aftermarket wheels with aggressive fitments and not being lowered. If Dinan doesn't release in time I'll have to go with H&R.
When are you installing your set?
      10-14-2020, 02:17 PM   #21
cywing1119
Drives: 2010 E92 M3
i ordered the dinan lowering spring but they out of stock lol, the wheels should be arriving on Jan 2021
      10-14-2020, 02:19 PM   #22
jeegunkim
jeegunkim's Avatar
328
Ahh so you have an M340i, I have an M330i xDrive so it may be a while for me. If Dinan doesn't have anything for my car by March 2021 I may have to just go with H&R.
