BIMMERPOST Universal Forums Off-Topic Discussions Board Health, Fitness, Martial Arts, and Nutrition What is your BMI Index?
      03-25-2009, 10:46 AM   #1
blue-coupe
Drives: 1999 Z3 Coupe
I'm trying to lose a few pounds, so I went to my trainer & had my BMI Index calculated (so we can compare it to my results later).
According to his equipment, I'm at 17.3. I filled out an online one, and it came back at 26.9 kg/m^2.
My trainer has pretty pleased with the 17.3, but we've set a goal of 13 by the end of april.
So, how does this compare to you guys?
      03-25-2009, 10:52 AM   #2
yomama69
Drives: 2007 E90 335i
~24 consistently. BMI is misleading though because it can calculate you as being overweight if you're muscular.
      03-25-2009, 10:56 AM   #3
omgitselainee
Drives: AW E92
I concur. I'm usually in the low to mid teen's no muscles here obviosuly
      03-25-2009, 11:20 AM   #4
mpimping
South Korea
820
Drives: gti
bmi flawed how you look in the mirror is more important...
      03-25-2009, 11:22 AM   #5
blue-coupe
I thought that might be true. I work out quite a bit, I've got good sized shoulders/back/arms/legs, and am pretty lean. I know I could use to lose a few pounds of fat, but I don't think most people would consider me overweight.
      03-25-2009, 11:57 AM   #6
ben14142001
Drives: 2018 M3 ZCP
I got my body fat % tested by some students that needed to do so for their exercise science degrees and I came back 3-3.% body fat every time. When I just used an online tool and typed in my height/ weight (6'2" 170) it told me 21%. Obviously using calipers/ underwater weighing is much, much more accurate.
-Ben
      03-25-2009, 12:49 PM   #7
Blake
Drives: Chevy Aveo
149
      03-25-2009, 12:51 PM   #8
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Originally Posted by Blake View Post
149
      03-25-2009, 01:01 PM   #9
Spec 1
Faster in the Corners
Spec 1's Avatar
Drives: '91 E30, '05 ZX6-R, '06 300C
Online says I'm at 22.9. 6'0" tall at 169lbs.
'91 M42 E30 - All sorts of goodies.
      03-25-2009, 02:23 PM   #10
Zephyr15
Zephyr15's Avatar
Drives: '07 e90 335i
BMI is useless.
'07 e90 335i: Monaco/Lemon ZSP ZPP ZCW (gone)
'02 e46 325ci: BSM/Black ZSP ZPP 5MT
      03-25-2009, 02:45 PM   #11
Seminole
Seminole's Avatar
Drives: Red Flyer
2008 E90 328i  [7.00]
I think I'm around 17-18ish.
      03-25-2009, 03:30 PM   #12
ruxp
Drives: 2008 BMW 335xi
Originally Posted by Zephyr15 View Post
It also doesn't factor in your height.
BMI is useless.
BMI does factor in height.. but yes, it's pretty useless. It really only works OK for women and scrawny men.
      03-25-2009, 03:45 PM   #13
mpimping
South Korea
820
Drives: gti
bmi is ok as long as your body fat is in check...
      03-25-2009, 04:06 PM   #14
Zephyr15
Zephyr15's Avatar
You're right. I don't know what I was thinking about when I typed that.
      03-25-2009, 04:16 PM   #15
jaiman
Drives: very fast
Really? According to BMI Bob Sanders is obese.
      03-25-2009, 07:34 PM   #16
Saintor
Saintor's Avatar
79
Drives: E90
There is some confusion about the BMI...almost impossible to get at 13 in an healthy manner.
At 5'10", I should be between 123 and 174lbs (18.5 and 25). I aim at 153.5lbs, I'll be 85lbs lighter than the maximum I weighted, and at a BMI of 22 or so.
      03-26-2009, 02:28 PM   #17
Spec 1
Spec 1's Avatar
BMI DOES work for the majority of people, we're just such a fat nation we say "That's rediculous it can't work! I'm healthy even if my BMI is 30!". The only place the MBI doesn't work is folks who have very low fat reserves but very large muscles (aka ripped). If you don't have a 6 pack, you still have too much fat to be claiming muscle. I've put on 22 lbs of muscle before and still been at 25.2 BMI. If you think BMI is crap, then you need to lose weight.
      03-29-2009, 11:08 PM   #18
ToothDoc
Drives: 997.2 TTS, CLA 45 AMG
31. I don't have a measly 6 pack, I got a keg!
      03-30-2009, 07:41 AM   #19
earlyapex
Drives: 2008 E90 M3
I think we found the scrawny/nerdy guy. BMI couldn't be more idiotic. I'm in good shape, run/bike/lift 4 to 5 times a week and have consistently measured at 10% body fat via various methods. I can scuba dive basically without or with very minimal additional weight.
Several years ago, I worked out for 3 hours a day for six months and ran a half marathon in an hour and a half. I had like 3% or 4% bodyfat and weighed 182lbs.
I weigh 195lbs and am 5'11". According to the midpoint of the BMI (22), I should be 157lbs.
In other words, the BMI says I should have NEGATIVE 10% body fat. It couldn't possibly be less worthwhile and is completely irrelevant for any man with the slightest bit of muscle.
It works wonderfully if you are scrawny and can bench press the bar and squat a small watermelon.
      03-30-2009, 02:12 PM   #20
blue-coupe
Well, since it seems that BMI is bunk, what is a good measure?
BTW, when my trainer took mine, he used some gizmo that ran an electrical current through me, measuring resistance. I would assume that this device can account for muscle mass vs fatty mass.
      03-30-2009, 02:25 PM   #21
Eazy-e
Dope-like a pound or a key
Eazy-e's Avatar
10
Drives: 09 e82 135i
      03-30-2009, 02:28 PM   #22
Eazy-e
Eazy-e's Avatar
10
Drives: 09 e82 135i
People are right about BMI not being totally accurate. Some people have heavier bones or a lot of muscle.(muscle weighs more then fat)
