01-04-2021, 02:04 PM | #45 | |
Rep 52
Bimmercode is only for Android still, correct? Looking for the best ios solution and I'm hearing Carly might be it? Thanks
01-05-2021, 04:00 PM | #47 |
Rep 383
Has anyone managed to get on the BimmerCode beta recently?
Tried emailing but no reply?
01-15-2021, 10:25 AM | #48 | |
Rep 120
Have you done the Static IP settings on your phone under Ethernet Settings? If your phone is capable of setting a static IP it should work, if you can't make a static IP then it won't work. I couldnt do it with my Huwaei phone, just a Samsung tablet |
01-19-2021, 05:31 AM | #49 | |
Rep 147
I recommend those who have difficulty in getting this Enet Cable to work with Bimmercode try this WiFi Adapter from modBMW. its very reasonable and Function is super and lightning fast. |
01-20-2021, 04:28 AM | #50 | |
Rep 120
From what I gathered only Google phones and Samsung have proper ethernet settings to do a static IP to get cable option to work |
06-05-2021, 08:18 AM | #51 | |
Rep 156
Hey ! I was trying to code my 2021 330i yesterday with a Ethernet cable and lighting adapter , however it wasn’t connecting to my car . I’m pretty sure i followed all the right steps but still got no luck.. So I thought the Ethernet cable wasn’t going to work and was planning on ordered those WiFi obd, but now that I’m reading everyone’s post. Most suggested using a Ethernet cable for strong connection. And since I already spent money on the cable I really want this to work. I don’t know why bimmercode isn’t able to read my car with the Ethernet cable , if there’s any advice please let me know. Was trying to code in sports plus mode. Thank you for ur time! |
06-05-2021, 03:55 PM | #52 |
Rep 1,479
Drives: 2020 M340Xi (G20)
g20_shub ,
First off, after that post I figured out two things: * First, I had been using the incorrect connection. Rather than ENet, I had been using MHD BLACK (which interfered with update to phone-- no broadband or Wi-Fi) * I didn't have all settings for ENet correct After getting that straight, Cable with LAN connection & OBDII connection on either end, along with LAN to USB-C (I have Samsung phone) works great -- beaucoup faster & reliable. Additionally, I use same cable when I go E-Sys BTW, occasionally, though I think the cable is on OBDII port on car, it's not making full contact-- just remember to push cable firmly & uniformly onto car's OBDII port I use an Anker LAN to USB-C adapter that I got on Amazon. Hope that helps
Al
06-05-2021, 09:08 PM | #53 | |
Rep 207
Hi,
Did you set to airplane mode before you connect the cable to your phone? Quote:
06-07-2021, 05:00 AM | #54 |
Rep 384
I had repeatedly problems to connect BimmerLink and BimmerCode with my MHD ENET (black) (I use WiFi), until I used this connection sequence.
Now it works every time. (Car is G22 2021 model.): 1) Phone in Offline (Flight) mode. 2) Car into Diagnose mode (no adapter connected). 3) Only now insert the OBDII adapter 4) Connect WiFi 5) Connect BimmerLink/Code. |
06-12-2021, 03:18 AM | #55 |
Rep 11
I am looking to buy ENET cable, found a lot of offers on Ali, but everywhere they say that it is compatible with F-series only. I read this discussion and still don't understand, if we can use a cable for Android phones for coding G-series? Or our only option is to get yourself a BT/WiFi adapter?
06-12-2021, 06:04 AM | #56 |
Rep 1,479
thekrotek ,
My 2020 M340 (G20) is my second BMW with previous one being a 2014 328 (F30). When I started coding my F30, I bought an ENET cable (OBDII connector on one end & LAN/RJ on other). Subsequently, I used same cable on my G20. When I started using Bimmercode, I eventually switched to using this same ENET cable with an Anker (brand name) LAN to USB-C adapter (I have Samsung phone). The cable still works fine -- haven't had any problems. BTW, got adapter on Amazon & saw there were several ENET cables being sold Hope that helps!
Al
06-12-2021, 05:02 PM | #57 | |
Rep 383
I bought mine from Amazon for use with iPad - £15.99 NiceCheck ENET OBD Cable OBDII... https://www.amazon.co.uk/dp/B07SLLH4...p_mob_ap_share With this adapter for £18.99 RJ45 Ethernet LAN Network Adapter... https://www.amazon.co.uk/dp/B086MQGW...p_mob_ap_share
06-13-2021, 07:32 PM | #58 |
Rep 1,479
thekrotek ,
I started using Bimmercode with MX+ OBDII adapter with my Samsung (Android) phone. Having read about using cable, I got an Anker USB-C to LAN adapter connected to ENET cable. I now use cable to connect my car to my Samsung S21 phone with Bimmercode. This set up works fine!
Al
07-02-2021, 06:07 AM | #60 |
Rep 11
07-02-2021, 06:10 AM | #61 |
Rep 11
I eventually bought ENET cable and Ethernet/Type-C adapter, but it doesn't work. There's no Ethernet option in my phone settings and Bimmercode can not connect to the car. Tried a few options mentioned here, but none helped. Guess, I'll jjust buy Wi-Fi adapter.
07-02-2021, 06:33 AM | #62 | |
BMW Enthusiast
174
Rep 221
https://bimmercode.app/manual/ |
07-02-2021, 06:36 AM | #63 | |
BMW Enthusiast
174
Rep 221
07-03-2021, 05:26 AM | #64 | |
Rep 11
07-03-2021, 06:24 AM | #65 |
BMW Enthusiast
174
Rep 221
They updated the manual...
If your phone updated to Android 11 there is a new way to connect. ENET cable connection (Android 11) Connect the ENET cable with your Android device using an appropriate USB to Ethernet adapter. Connect the cable to the OBD port in the footwell on the driver side in the car. Enable the Airplane mode on the Android device. Enable “Ethernet tethering“ in the Android settings (“Settings“ > “Connections“ > “Mobile Hotspot and Tethering“ > “Ethernet tethering“). Open the settings in the BimmerCode app and make sure the correct adapter type is selected. Tap “Connect” on the start screen in the BimmerCode app. |
07-03-2021, 09:53 AM | #66 |
Rep 500
iPhone 12 and have been using these without drama or issues.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
