Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics How To: Radar Detector Hardwire
      08-13-2020, 10:39 PM   #23
DeathBlade
Drives: 2020 bmw 330i xdrive msport
Figured it out.
Originally Posted by DeathBlade View Post
I just picked up my 2020 330i (Late June production) and I was excited to be able to wire my radar but the housing looks different. I do have the drivers assistance professional package but the housing seems to be different. Looking from the headliner to the plastic trim I don't seem a seam to try and use trim tools to pry apart at like others have described. I do see a seam on the smaller rounded black piece but that does not looks like it would expose the wires. Maybe I just am misunderstanding what comes off but from pictures it looks like two pieces which I don't see.
Does anyone have any idea?
I figured it out. I popped the cover off that is up against the headliner then was to separate the two half's. As others mentioned I did break some small plastic pieces but everything does go back together normally and you can't tell.
      09-01-2020, 03:53 PM   #24
Z4Racer1
Drives: BMW Z4 M40i
Escort Max 360c Stays On in 2020 Z4
I connected my wires according to the photo (What a pain in the A$$). The MAx 360c stays on when the vehicle is off. I am not sure if there is a switched wire in the housing or not. I always remove the detector for security sake it's not a huge deal but I would have liked to leave it on at home.
      09-01-2020, 06:24 PM   #25
tturbolife
tturbolife's Avatar
Drives: None
2020 BMW M340i  [0.00]
It will turn off after a couple minutes, it takes some time to go to sleep
      09-02-2020, 10:49 AM   #26
MurrayB
Drives: 2020 BMW M340ix
The Max360 may have a setting that shuts itself off after a selected time. My RL360c does I think that feature is an Escort standard.
      09-02-2020, 03:17 PM   #27
FrostNixon
Drives: vw golf
Side question, isn't radar hardware illegal where you guys live, because here cops carry anti-antiradar equipment and if they catch you with one there are severe penalties, thus why I use android auto and waze, because people tag radars.
      09-02-2020, 03:19 PM   #28
tturbolife
tturbolife's Avatar
Drives: None
Radar detectors are legal in most of the US, i think just Virginia and Washington DC have them banned.
High end detectors cannot be detected with radar detector-detectors
      09-04-2020, 08:05 AM   #29
MurrayB
Radar detectors are banned in Washington DC & Virginia, not West Virginia.
      09-04-2020, 12:19 PM   #30
tturbolife
tturbolife's Avatar
Drives: None
Thanks, corrected my post.
      09-12-2020, 05:15 AM   #31
plopez12808
Could someone post a video removing the rear view mirror? I simply can't get it off.
      09-12-2020, 01:46 PM   #32
tturbolife
tturbolife's Avatar
Drives: None
You don't have to remove the mirror, just the trim
      09-12-2020, 11:59 PM   #33
plopez12808
I know, but I can't get the wiring harness out either.
      09-13-2020, 12:35 PM   #34
tturbolife
tturbolife's Avatar
Drives: None
It should pull right out. Use one hand (or a tool) to keep the part it plugs into in place and pull on the plastic of the harness
      09-13-2020, 02:43 PM   #35
plopez12808
Yeah it should be easy but for some reason it's not. Even taking off mirror housing I had to put enough force to where the right side literally flew off, it simply wasn't coming off.
The part it plugs into moves around as well correct?
      09-13-2020, 02:44 PM   #36
tturbolife
tturbolife's Avatar
Drives: None
Correct, I had to hold it in place
      09-13-2020, 03:24 PM   #37
plopez12808
I swear whoever put this car together made sure it wasn't gonna a be taken apart easily. I'd like to see a video of someone doing the process so I can see how easy it's supposed to be. Not only am i having a hard time removing the plug, there's no way this mirror is coming off the harness.
VipinLJ1944.50
ztech132.00
      09-13-2020, 10:36 PM   #38
tturbolife
tturbolife's Avatar
Drives: None
You can still do it without removing the cable from the harness, its just easier that way. You just have to push in the pins of the RJ11 adapter
      12-08-2020, 08:31 PM   #39
ThatGTI
Drives: 2020 BMW M340i xDrive
I wired up my Uniden R7 the same way with the same power tap, and it used to cut the power to the radar detector when the car was turned off and the door was opened. Recently I've noticed that now it remains powered on for about 45 minutes or so after locking the car. Has anyone else encountered this?
      12-09-2020, 11:01 AM   #40
MurrayB
Your mirror tap may always be powered on turnoff may be a function of a an R7 setting. Maybe tied to no change in GPS, no motion of the car. Some detectors work that way I am not familiar with the R7.
      01-25-2021, 02:21 PM   #41
MrSoloDoeLow
Drives: 2021 BMW M340i xDrive
Hi, I'm new here, and struggling with the same issue as you. The plug is very difficult to disconnect from the mirror. And I cannot get a good angle to properly plug in the rj-11 cable while the plug is still connected.
Does anyone have any tips on how to remove the mirror so I can get a better angle to disconnect the plug?
      01-25-2021, 04:11 PM   #42
davefromfla
Drives: 2021 M440ix
Check out pneumodoc on first page. That's what I did- very easy.
Previous: E36 M3, E46 M3, 135i, M235i, 440i
      02-06-2021, 04:39 PM   #43
MrSoloDoeLow
Thanks, I did, but I'm still unable to remove the mirror. Can you please clarify in the picture where to apply pressure to release the mirror? Do I first apply pressure in the direction of arrow 1? Then while applying pressure to arrow 1, apply pressure in the direction of arrow 2 on the left and right side of the mirror? Thanks.
      02-08-2021, 10:19 AM   #44
rcz22
Drives: 2024 G80 M3 6MT
I currently have the Uniden R3 - it was hardwired to a driverside fuse in my S4, and sat near the headliner next to the mirror, however, this time I like the cleaner look of the blendmount - can any one post more pics from the drivers perspective?
Some of the other pics I've seen appear to make it look like it sits so low - does anyone find that it blocks your view or is distracting? or is it just a matter of getting used to it?
Thanks!
