02-13-2019, 05:16 PM | #24 |
Rep 1,105
I don’t remember reading in any press release exact numbers except to expect more than 600 HP. Show me the press release you read.
Imho the M8 will get at least 625 HP and M8 Competition even 20 to 25 HP more. Last edited by G4BR13L; 02-13-2019 at 05:26 PM.. |
02-13-2019, 07:39 PM | #26 |
Rep 487
Fuel Consumption Analysis
Combined: 22.40 MPG based on 10,5 l/100 km conversion from the press on F9x (S58), compared to F80 (S55), 20 MPG (manual) and 19 MPG (DCT). With lighter weight construction on G8x, expecting it with much better fuel consumption.
02-14-2019, 01:36 AM | #27 | |
Rep 1,105
Where did you get the 22.40 MPG from? Is that according to WLTP? Because 22,40 MPG would translate to a co2 of approximately 243 g/km and this just can't be correct. Or you mean that this number is based on actual consumption? After 85.000 kilometers (52.816 miles) my average fuel consumption is 10.7 l/100 KM which translates to approximately 20 MPG (US). Last edited by G4BR13L; 02-14-2019 at 01:43 AM.. Reason: I have added the fuel consumption of my F92 |
02-14-2019, 07:32 PM | #28 |
Rep 464
S58 engine
Looks like the G80 will have a nice baseline to start. I figure maybe 530hp for the CS and 550hp for the CSL.
02-14-2019, 08:41 PM | #29 |
Rep 2,577
In the X3M/X4M video, she revved it up to 5k rpm. The sound is overall a bit deeper than S55 ZCP, and more importantly is less raspy - though we're not sure about the last 2k rpm of S58.
Fitted with MPE, or even stock ZCP muffler, S55 sound is acceptable below 4k (and some of us even think it's good) but above that it's terribly raspy.
Lemania 2320
02-15-2019, 02:34 AM | #30 | |
Rep 1,271
02-15-2019, 03:47 PM | #31 |
Rep 660
I don't know too much about turbos vs. compression ratio tuning, but what are the implications of lowering the compression ratio so much from S55 vs. S58? More boost?
02-15-2019, 04:44 PM | #32 |
Rep 483
Yes, the trade-off being the engine will make less power off boost, but that shouldn't be an issue.
02-17-2019, 07:01 PM | #33 |
Cheapskate
4442
Rep 4,992
Are those two high pressure fuel pumps? That makes me nervous on principle, though I probably shouldn't be.
Also curious if the engine versions are simply detuned/less boost or if there are internal differences. I'd be more comfortable with a flash tune than just raising the redline. A lot needs to happen for an engine to safely rev to 7500+. |
02-19-2019, 12:17 AM | #34 |
Barge driver
8618
Rep 12,401
Why? The M3 isn't their flagship model either, nothing to suggest that they will bring more power or will need to it'll weigh 300kg+ less for a start.
730d/Z4C
06-09-2019, 03:13 AM | #35 | |
Law Enforcer
24832
Rep 22,229
Drives: '22 Chalk Gray Porsche C2S
06-09-2019, 05:27 PM | #36 |
Rep 104
Drove the X3M with it in it the other day...this engine is gonna be a beast!! Plus! No more "active sound" they're pulling a play from Porsche and pipe in actual exhaust sound via a flap system like the 911 does (according to the BMW M team guys).
06-09-2019, 11:25 PM | #37 |
Law Enforcer
24832
Rep 22,229
Didn't somebody say the new X has active sound? I could have sworn that I read that.
06-09-2019, 11:29 PM | #38 | |
Rep 104
JTO245246.50 |
06-10-2019, 09:43 AM | #39 | |
Rep 2,359
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Still upset about lower rpm due to ZFat.
Pass me if you can.
06-14-2019, 11:03 AM | #42 |
Rep 3,622
OP might want to update fist post with official S58 tech docs.
https://x3.xbimmers.com/forums/showthread.php?t=1623283 |
06-14-2019, 11:06 AM | #43 |
Rep 3,622
06-14-2019, 11:14 AM | #44 |
Rep 2,554
I believe if you look at the graphics as well as specs sheets for the x3m peak power runs as plateau right to the redline
