Technical Topics DIYs and Coding Discussions M340i Center Speaker Rattle Fix Instructions (with pics)
      01-17-2020, 07:38 AM   #23
Chappati21
Chappati21's Avatar
France
Drives: BMW 330i (G20) M Sport
I think I'm having this exact problem ! Thank you so much for this post I'll try to fix it this weekend.
      01-17-2020, 08:10 AM   #24
john!smith
john!smith's Avatar
230
Drives: M340i XDrive
Originally Posted by pkancel View Post
Perfect fix, thank you so much. Oddly though, dont have the problem in our G20 330i, just the M but maybe the suspension, engine, etc in the M are all drivers of the issue as well.
good work! thank you very much!
      01-21-2020, 01:53 PM   #25
jeremycanada
jeremycanada's Avatar
25
Drives: 2020 BWM M340i
Thanks a lot! Finally fixed mine!!!
2013 Ford Edge-
2015 Golf R-
2017 Audi Q5-
2018 Audi S5-
2020 Bmw M340i
      03-05-2020, 09:23 PM   #26
tazzi831
tazzi831's Avatar
Drives: BMW M340i
2020 BMW M340i  [0.00]
did this today - worked like a charm.
now the passenger door started rattling 2x worse than the damned center speaker ever did. i've pressed and banged on everything - nothing. i think it's inside the door...
srsly.
      03-09-2020, 01:29 AM   #27
imported_nick
Drives:
Finally got around to doing mine. Thanks for this post!!!
The sound system on these cars is amazing
      07-27-2020, 01:57 AM   #28
vipad596
Drives: BMW X5 F15 30D, 3 G20 320D
You are a life saver, perfectly solved. Thank you.
gnr4all62.50
      09-10-2020, 06:53 PM   #29
amallouk
Drives: 2020 BMW M340i
can't get speaker cover off
thanks for the dyi suggestion. I think I have the same problem. However I am having trouble taking off the speaker cover. Can you provide a bit more detail on that step? I'm afraid to cause damage. I am leasing the car and it's only 1 month old but I already noticed the buzzing/rattling noise from that area at high engine rpms.
      09-12-2020, 01:01 PM   #30
amallouk
Can’t get cover off
Originally Posted by gnr4all View Post
First of all thank you to CyclingBroStyle for posting a solution to the speaker rattle problem. I just wanted to post instructions how i fixed it because the noise was driving me crazy and I hope this helps other people with this issue.
Step 1: I found that the cover wasn't easy to just lift up. The speaker cover has 6 clips as shown in the pic below. I used a card to wedge under the speaker cover and to push each clip in. I started with the bottom left clip (closest to steering wheel) I found that I had to push the card into the clip in order to release it and simultaneously lift the cover with a little force. Eventually one at a time, I released all 6 clips. It could be that you can just lift up the cover with pressure but it didn't feel to me as if it would work without breaking the cover
Step 2: Once I lifted the cover off I used felt tape to cover the plastic tab on the top of the speaker cover as shown in the picture below:
Step 3: I then covered those two plastic contact points by the speaker on the sides of where the plastic tab from the speaker cover connects to pictured below:
I then popped the speaker cover back in and now the rattle has gone away. I tested it in Sport+ mode under heavy acceleration and when raising the volume of the stereo under different frequencies.
This is a link to the felt tape I used:
https://www.amazon.com/gp/product/B01455QMX4
Hi, thanks for the detailed solution. However, I’m not able to get the cover off. Can you post more detail as to how you removed it?
      09-12-2020, 04:52 PM   #31
chris_portimaog20
Drives: 2019 Bmw 330xi
turn off active sound design in bimmercode
problem fixed
      11-07-2020, 05:40 PM   #32
HXTX20
Drives: '23 M3 Comp, '23 X5 45E
Removing the cover was harder than I expected. Took 45 mins trying to push each clip in and lift. I tried the basic trim tools but they were too thick to get it to the right spot for me. I ended up snipping an inch off an expired credit card, locating the clip, and jamming it in at ~ 45deg angle. I bent 1/3 of the back of the card to get better grip.
It did fix my rattling that would occur at 1.5k, 3k rpm. Seemed to vary depending on what kind of music and how loud I was playing.
      11-16-2020, 03:30 PM   #33
banyard2000
Drives: BMW G20 330D
Same issue as some other owners - dealer couldn’t find the problem either and just adjusted treble and bass settings.
Applied the felt and refitted cover and rattle has now gone. For any UK owners, the tape and tools I used are linked below:
Car Multipurpose Tape, Car Self Adhesive Anti Squeak Rattle Felt Automotive Wiring Harness Tape Car Accessories(19mm*15m) https://www.amazon.co.uk/dp/B07MKJKW1Z/ref=cm_sw_r_cp_api_fabc_R8USFbHVH30BS?_encoding=UT F8&psc=1
OSAN 4Pcs Plastic Car Radio Door Clip Panel Trim Dashboard Audio Repairing Removal Moulding Tool Set Auto Pry Tool Kit https://www.amazon.co.uk/dp/B012FJE4W8/ref=cm_sw_r_cp_api_fabc_.8USFbNHJ07QT?_encoding=UT F8&psc=1
      11-22-2020, 03:31 AM   #34
pewpew392
Drives: 2021 BMW M340i
Awesome! Thanks for the detailed instructions!! Just did it on mine, but used foam tape instead because that's all I had at the moment. It's a lot thicker and can absorb more so I'm hoping it'll do just fine. Thanks again!
      11-22-2020, 03:32 AM   #35
pewpew392
skip to 17:25 and they show you how they remove the front speaker grill
      01-03-2021, 03:20 PM   #36
djlane16
Drives: BMW M340i, Nissan 350Z
Thank You!
Thank you for the excellent step by step instructions. I thought I had a blown speaker and was going to take my new car to the BMW dealer. I am so glad I found your post. I did use a 45 degree angle slim trim tool and your pictures to pop the speaker cover. I did use self stick velcro tape (soft side) and this worked perfectly. The entire job took last than 10 minutes and likely saved me big bucks. I love this car and now no more rattles. Awesome.
gnr4all62.50
      01-03-2021, 03:27 PM   #37
qmis
qmis's Avatar
Drives: BMW X3 M40i
Great post. You would think BMW and their dealers were onto these types of issue.
      01-03-2021, 06:26 PM   #38
BinH
Drives: F10 M5
I actually had my speakers replaced and did the fix realizing later that it was simply rattles. SMH.
      02-27-2021, 04:14 PM   #39
markonline007
Drives: 2020 BMW 330i xDrive
Just adding my voice to the thank yous. This worked perfectly to solve the rattle. Getting those clips to release was the trickiest part!
      03-10-2021, 01:56 AM   #40
fdopperen
Netherlands
Drives: 3serie / G21 / 330i
i will fix it today also on my 330i very stupid sound
      04-20-2021, 01:08 PM   #41
Mirage_77
Mirage_77's Avatar
Drives: 2023 X3M Comp
Was there a video posted that missed or was removed? PS this is great. Can't wait to get this resolved!
      11-22-2021, 01:04 PM   #42
aquamaster
aquamaster's Avatar
Romania
Drives: G02 3.0d Xdrive
Although I had exactly the same issue on my previous MB E43 AMG built in Burmester HiFi , I have never thought doing it on the actual G20. It seems to be a "central speaker curse" as my ex F10 B&O central speaker was falling when road quality not too good.
On the G20 the job was done only by using the "recommended" card , panel removed in 5 minutes (if you can be accurate in regards to the clips locations from the above pics).
Thank you very much gnr4all !
      12-09-2021, 07:32 PM   #43
Mason Hatcher
Drives: BMW 230i
Just completed this modification. However, I realized the felt I bought was too thick. While I had the cover off I just tried electrical tape, and I can verify it works too.
Thanks to the OP!
      12-09-2021, 07:33 PM   #44
Mason Hatcher
Drives: BMW 230i
Double tap, sorry
speaker rattle fix
