06-09-2021, 02:26 PM | #1 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Ohlins G20, G21 Fits RWD & AWD (xDrive) models
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. General > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty Front > McPherson Strut > Single bleed adjuster > Spring preload adjuster (approx. 20-30 mm lower than standard)> Coil Springs (rate 80N/mm) > Dustcovers > Use with original top mounts Rear > Conventional Shock Absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 20-30mm lower than standard) > Coil Springs (rate 140 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost) > Dustcovers > Use with original top mounts G20 G21 (X-drive and RWD)3-series (F30,F31,F34,F35,G20,G21) Landing Stateside in August. BMS MU00/BMS MU00S1 |
06-10-2021, 10:22 AM | #2 |
Rep 222
Drives: '20 M340iX
I had swapped for Ohlins on my 911 years ago. Amazing products. Glad to see they’ve developed a system for this particular platform.
06-10-2021, 12:19 PM | #3 |
3893
Rep 54,605
Drives: F80 M3
06-16-2021, 09:24 AM | #4 |
Rep 1,934
NEED!!!!
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
09-10-2021, 12:53 PM | #7 |
3893
Rep 54,605
Drives: F80 M3
