09-27-2020, 06:31 PM | #155 |
1949
Rep 3,520
Did you try with your phone again? Maybe someone with the latest iOS can chime in? I use my Android phone so I'm not sure...
09-27-2020, 07:21 PM | #156 | |
Rep 39
09-27-2020, 08:19 PM | #157 | |
Rep 352
Drives: G20 330ix M Sport
09-27-2020, 08:22 PM | #158 |
Rep 352
I have the beta on my XR. But since I can't connect the XR I was trying to use my outdated iPad.
09-27-2020, 09:55 PM | #159 |
Rep 39
Make sure you are not connected to Bluetooth when you connect your network adapter to your phone. It only allows 1 accessory at a time. I'm just taking a swing though as I'd imagine you are in airplane mode. Does your network adapter show up in setting?
09-28-2020, 12:47 AM | #160 |
Rep 123
09-28-2020, 02:14 AM | #161 |
1949
Rep 3,520
09-28-2020, 08:04 AM | #162 | |
Rep 352
I'm think it is phone related at this point. But I need to find someone around here with an iphone that has bimmercode to test out my theory.
09-28-2020, 10:47 AM | #163 | ||
Rep 39
mikeyb74120.50 |
09-28-2020, 11:12 AM | #164 |
Rep 352
New Hampshire is a bit far from Denver.
09-29-2020, 01:53 AM | #165 | |
Rep 11
CB FZG UMGEBUNG FAS -> Aktiv PIA FZG UMGEBUNG FAS -> Aktiv SICHT_ABSICHT_ENABLE -> Aktiv Go into expert mode then DKOMBI then search in the search bar and change these 3 options to AKTIV it will work right away. Don't forget to turn the option on once coding is done. Go into the display and cockpit and change the view on the cockpit from map to assisted driving view. |
09-29-2020, 01:59 AM | #166 | |
Rep 11
CB FZG UMGEBUNG FAS -> Aktiv PIA FZG UMGEBUNG FAS -> Aktiv SICHT_ABSICHT_ENABLE -> Aktiv And yes I'm sure you would need the driving assistance pack to be able to get this view I would think. |
09-29-2020, 02:25 PM | #167 |
Rep 380
Hi guy's!
Hope you can help. I the cluster changes, when selecting the M cluster, does this change it to the M340i digital cluster? I'm confused - I don't have the app yet and don't want to spend the money for the adapter or app if I can't get what I really want. Thanks in advance for your support. |
09-30-2020, 06:12 AM | #168 |
Rep 12
tturbolife235.50 Shoupness23.50 |
10-01-2020, 07:55 AM | #171 |
Rep 352
I ended up emailing Stephan at Bimmercode regarding my issue. He said that the next app update will allow BDC to be read. I was finally about to connect with the enet cable and lightning adapter using my XR. Took forever to connect to the car. So when it finally connected alot of the coding functions were missing from before the software update on my G20. Stephan did not give details on when the next app update will be released.
Update, Stephan sent me a test flight beta so I can get into the BDC works great!
Shoupness23.50 |
10-04-2020, 04:33 PM | #172 | |
Rep 2
10-04-2020, 08:57 PM | #173 | |
Rep 359
https://www.amazon.com/Ethernet-Inte...dDbGljaz10cnVl https://www.amazon.com/ENBIA-Etherne...NsaWNrPXRydWU= |
daniel88br0.00 mikeyb74120.50 |
10-05-2020, 05:22 PM | #174 | |
Rep 2
10-06-2020, 02:26 PM | #176 | |
Rep 352
I purchased the Bimmercode recommended enet cable and ethernet lightning adapter. Enet Cable https://www.amazon.com/Ethernet-Inte...54840370783b07 Ethernet to Lightning Adapter https://www.amazon.com/Amatage-Light...7c0075428ca9c8
