2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions 330i Sport+ and Launch Control?
      05-10-2019, 08:02 AM   #45
bimmer456
Drives: 340i
Originally Posted by F30ZHP View Post
Originally Posted by CyclingBroStyle View Post
I just want sport plus anyone coded it in G20 yet?
Why though? Even I won't use launch control on my ZHP. It puts a lot of stress on the engine. Other than that, Sport + mode only turns off traction control which you can do manually.
Sport plus doesn't just turn off traction control. That was true in pre LCI F30. Or more accurately it turns on DTC on the older models only but also makes the car more aggressive than sport on newer models.
      05-10-2019, 08:19 AM   #46
MT4life
MT4life's Avatar
576
Drives: 2018 340i: Last MT 3er in US
Do you have a link to an explanation of that?
I was under the impression Sport and Sport + has the same throttle map and exhaust flap setting
      05-10-2019, 08:31 AM   #47
bimmer456
Drives: 340i
There have been several threads discussing it and the general conclusion is that that was true pre-LCI
      05-10-2019, 08:35 AM   #48
MT4life
MT4life's Avatar
576
Must be AT thing. I don't feel any difference between Sport and Sport+ like I do when I switch from Comfort to Sport with 6MT
      05-10-2019, 08:46 AM   #49
bimmer456
Drives: 340i
Maybe, I definitely feel a difference in my 340i sport plus vs. sport, so i usually drive in sport plus. But it is not just the trans that shifts differently. I feel like sport plus shifts in D like sport shifts with stick to the left. But also launches harder and less lag off the line and generally speaking.
      06-21-2019, 07:47 PM   #50
luntik
luntik's Avatar
Russia
Drives: BMW F30 320ix -> 330ix
Yes, I can code it if you have a laptop with ENET cable
Sport plus on the G series works differently than on the F
Has anyone tried launch control? Does it work? I didn't find any entry in coding about it
      06-21-2019, 10:13 PM   #51
achk
Drives: BMW U11 iX1 Xdrive 30
Yup no dice in my 330 tried everything. Waiting to have 1200 miles before attempting launching. According to the manual it's sport mode + traction + shifter to left
I can confirm 330i delivered to Australia also has sport+ and launch control.
      06-22-2019, 04:17 AM   #52
luntik
luntik's Avatar
Russia
Sport plus on the G series doesn't combine traction control
      06-22-2019, 08:10 PM   #53
CyclingBroStyle
CyclingBroStyle's Avatar
Launch control confirmed sport mode + dcs off + shift lever in M/S + gas peddle to the floor + foot on brake = LAUNCH CONTROL ACTIVATED 🏁
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
Slideit49.00
      06-22-2019, 08:11 PM   #54
CyclingBroStyle
      06-23-2019, 07:00 PM   #55
mzdial
mzdial's Avatar
Drives: '19 G20 330i & '19 G01 X3
Which module did you code to enable it? I'd like to give it a shot.
      08-01-2019, 02:25 PM   #56
rgallo10
Drives: 2019 330I
i dont see sport + on my 330I either in the US, would be helpful you have details on how to code it if there is on option to do so.
      08-02-2019, 11:20 AM   #57
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
Sat in a Dutch 330i literally an hour ago. Press sport twice and it goes to Sport Plus. If that isn't available in the US, must be something continent specific.
      08-04-2019, 02:48 PM   #58
zote
Drives: 330i M Sport (G20)
Originally Posted by ar2020 View Post
Is there a button for it or how do you activate it?
Hold sport button for a few seconds.
      08-05-2019, 04:09 AM   #59
clipz85
Drives: g20
My g20 has sports plus,sports individual,normal sport mode, 3 different settings. Munich assembled
      02-14-2020, 01:34 AM   #60
andygo57
Drives: BMW 330i 2020
Just picked up my 330i xDrive M Sport. Two questions:
1. Is there a Sport+ mode? If so I can't find it.
2. If there’s no Sport+ mode, is there also no launch control?
There is Sport plus mode available, just press sport on your center console and then go to the main screen, there you should have the options Sport - Plus - Individual, just tap the screen and that’s it.
Not sure about Launch, I was wondering 'bout the same thing...
      02-14-2020, 09:38 AM   #61
VipinLJ
VipinLJ's Avatar
Wait. You have a NA spec car which shows launch control activated and checkered flag on the live cockpit when you do as you said? I’ve done the exact same in my car a few times but no launch control notification. It brake torques to around 3000rpms before launching.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-14-2020, 01:17 PM   #62
JSaid
JSaid's Avatar
Drives: 2022 BMW M340i xDrive
Yep, my NA m-sport 330 shows the checkered flag launch notification as well
      02-14-2020, 01:22 PM   #63
pneumodoc
pneumodoc's Avatar
232
Drives: G20, G01
From my brief reading you need to have the car warmed up, and have been driving for a few miles to ensure it is warmed up before launch control will be available. Not sure if you tried that VipinLJ ?
      02-14-2020, 02:54 PM   #64
Mjlbakker
Mjlbakker's Avatar
Drives: 2023 G21 318i (in order) - 20
Sport+ is linked to adaptive suspension: so only available when equipped with that.
I drive an M-sport 320i without adaptive suspension and only comes with Sport (and sport individual obviously)
Launch control does enable but not in the right way. Following the procedure from the manual the notification "launch control" pops up in the control panel but the revs are not managed correctly. Holding the brake down while applying throttle will instantly send off the car but not in a smooth and efficient manner...
Clutch will be dead soon if you try too often!
Real Wheel Drive
VipinLJ1936.50
      02-14-2020, 04:01 PM   #65
VipinLJ
VipinLJ's Avatar
That is crazy! I’ve tried it thrice till now. I’ve driven the car around for five minutes for it to warm up (like I do/did with my other cars).
Car in sport individual + dtc off + transmission in M/S + brake pedal to the floor + throttle to the floor -> revs rise to 3k rpms before I take my foot off the brake and car flies. But no checkered flag on the live cockpit.
I wonder if it’s because I’m in sport individual mode and not sport mode? My sport individual is everything in sport except steering which is in comfort.
      02-14-2020, 07:34 PM   #66
JSaid
JSaid's Avatar
Try regular sport mode, make sure you really push the brake down hard with your left foot and make sure you floor the gas to achieve kickdown. I had an issue getting it to work the first time you really need to press the brake hard. If that doesn't work, check your manual in the car to see if it had launch control instructions. Otherwise it may only be for m-sport models.
