Technical Topics Cosmetic and Lighting Modifications (exterior & interior) LED door projectors
      06-29-2019, 08:13 PM   #1
johnnyg238
Drive it like you stole it
2020 BMW M340i  [0.00]
LED door projectors
Anyone know why the G20 doesn't have the LED door projectors available for it? Think BMW is working on it? I know it is gimmicky but I really like them.
      06-30-2019, 11:47 AM   #2
nola2atx
nola2atx's Avatar
What do you mean by projectors? Mine shows the 3 line m logo on the ground when I walk up to it at night. Are you referring to the colored BMW logo?
///M340i Portimão
My Exes:
E36, E46, F30
      06-30-2019, 05:25 PM   #3
ballisma
Drives: G20 330i
3 lines on my 320i msport too
      06-30-2019, 07:22 PM   #4
johnnyg238
Mine shows 3 lines but that is not coming from the door. That light appears to come from I. Front of the door. I'm taking about the light at the bottom of the door that other models allow you to swap out lenses for bmw logo or other pictures.
      07-11-2019, 08:05 AM   #5
KimberlyMiller
Drives: Daewoo Nexia
I heard about them and enjoyed for my model. But what is the desired color and size of your one?
      02-04-2020, 01:11 AM   #6
cannonballer5
Drives: BMW G20
BMW G20 door projector lights
When will there be door projectors (that project the BMW/M performance logo) available for the BMW G20 model? And what about other cool mods?
      02-04-2020, 11:51 AM   #7
aguycalleddb
aguycalleddb's Avatar
450
Drives: BMW G42 M240i XDrive
They are available on AliExpress now, don't know what the quality is like
Dan
G42 /// M240i Thundernight
      02-05-2020, 11:01 PM   #8
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
aguycalleddb,
I just looked on Aliexpress & couldn't find them. Would you be kind enough to provide a link?
Thanks
Al
Retired: 2014 328i
BMW CCA
      02-06-2020, 01:06 AM   #9
aguycalleddb
450
aguycalleddb,
Thanks
£7.73 74% Off | For BMW 8 3 series G20 G21 G07 X7 G29 Z4 M8 X4 M G02 2019-2020 Led Car Door Welcome Light Projector Logo Laser Ghost Shadow Lamp
https://a.aliexpress.com/_Us8r2
Dan
      02-06-2020, 11:59 AM   #10
RSnic
RSnic's Avatar
aguycalleddb ,
Beaucoup thanks!
Unfortunately, it will not ship to US -- perhaps it's precautionary for Coronavirus??
Al
Retired: 2014 328i
BMW CCA
      02-06-2020, 12:27 PM   #11
aguycalleddb
450
Possibly, I don't think much will be getting shipped from China any time soon
Dan
      02-19-2020, 03:10 PM   #12
RSnic
RSnic's Avatar
Hi,
An Update. I just ordered door projector lights; got 4500K (a good strong white) with /M logo. Cost was $9.90 plus shipping.
Here's the link: https://www.aliexpress.com/item/4000...2-b5222140bf36
Am sure it will take several weeks to get to me
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      02-19-2020, 03:16 PM   #13
VipinLJ
VipinLJ's Avatar
Where do you install that?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-19-2020, 03:24 PM   #14
RSnic
RSnic's Avatar
VipinLJ ,
Having installed these door projector lights on my F30, my son's Mini & a friend's MDX, it's really easy.
Run your hand along the bottom edge of the door and you should find the existing lights -- I'd say about midway along the bottom edge. To remove the existing light, you'll need a thin blade screwdriver or plastic thin prybar. Start at a corner and work your way around the edge and they usually pop out. The light has a simple 2 pin connector to car's wiring; remove that. Then basically, reverse the process to put new ones in.
For some reason G20s have a different light than other BMWs.
BTW, if you don't have the plain light now, I would not recommend getting these since, I think you have to cut a hole in the bottom edge of door and also wire them in.
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      02-19-2020, 03:29 PM   #15
VipinLJ
VipinLJ's Avatar
VipinLJ ,
Hope that helps!
Ah ok. I have them in my Audis. I didn’t know the G20 had them too. Lemme check it out after I get home and if it does, I’ll probably order them from AE as well. I got some from AE for my A4 and they lasted 3 years without any issues (slight dimming but when I told the seller that, he sent me two sets (4 in all) to keep as backup).
RSnic657.50
      02-22-2020, 12:54 PM   #16
OM3RTA
391
Think this mod with the light carpet maybe a bit overkill but I'd like to see the outcome.
      02-26-2020, 12:33 PM   #17
aguycalleddb
450
For those interested these arrived today...
Took a risk as it only cost a few £££s
Sorry for the bad pics
Dan
      02-26-2020, 12:47 PM   #18
VipinLJ
VipinLJ's Avatar
That looks real good. Did you get it from AE? Which link did you use?
      02-26-2020, 12:51 PM   #19
aguycalleddb
450
Yeah from AE, these ones: £8.31 72% Off | For BMW 8 3 series G20 G21 G07 X7 G29 Z4 M8 X4 M G02 2019-2020 Led Car Door Welcome Light Projector Logo Laser Ghost Shadow Lamp
https://a.aliexpress.com/_dVoq2tv
Took ages for the order to be processed but they came pretty quick once shipped
Dan
      02-26-2020, 12:56 PM   #20
VipinLJ
VipinLJ's Avatar
Yes I’ve ordered stuff from AE before and if you can wait. They deliver. I’ve never had an issue with them.
Btw how is the visibility in broad daylight? I had bought a similar set for my A4 and at night, it was very bright. But it was almost invisible in the morning. The OEM is really nice and very clearly visible even in broad daylight.
      02-26-2020, 01:30 PM   #21
aguycalleddb
450
I don't know yet, it was dusk when I put them in, I had some a few years ago in my old Merc and you couldn't see them in the daylight
Dan
      02-26-2020, 04:43 PM   #22
VipinLJ
VipinLJ's Avatar
Thank you for the input.
I tried ordering from your link but they don’t ship to the US. Damn COVID-19
