2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions When, exactly, does the Active Grille open?
      01-16-2020, 08:50 AM   #1
elijahgaraz
9
Drives: 2020 330i Msport Portimao Blue
Hi guys. Just a quick question as I’ve searched the threads on this topic but with no success. How does the grille on the 330i Msport operate? I had a loaner back in August 2019 and it used to open the grille when I put it in sport mode or sport plus. I’ve tried this with my current vehicle (December 2019 production date) but nothing happens. Asked the Bmw technicians at my local dealership and they said it only opens when the engine is at a certain temperature. Can anyone confirm this ?
Cheers
      01-16-2020, 09:50 AM   #2
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
I was told the same...
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      01-16-2020, 10:18 AM   #3
john!smith
john!smith's Avatar
230
Drives: M340i XDrive
Cheers
yes, it opens when the engine is hot and need cooling.
normally it should do a self diagnosis at start up. should open and close.
      01-17-2020, 06:13 AM   #4
NoSUV4Me
NoSUV4Me's Avatar
61
Drives: G20 330i M Sport
Hi guys. Just a quick question as I've searched the threads on this topic but with no success. How does the grille on the 330i Msport operate? I had a loaner back in August 2019 and it used to open the grille when I put it in sport mode or sport plus. I've tried this with my current vehicle (December 2019 production date) but nothing happens. Asked the Bmw technicians at my local dealership and they said it only opens when the engine is at a certain temperature. Can anyone confirm this ?
Cheers
Yup when it wants to breathe it will open - try going in sport plus around some curlies for about 20min and you'll see it in action. Just to get to optimum operating temperature need at least 10 minutes of ordinary driving
      01-17-2020, 09:08 AM   #5
240Newbie
Learning
Drives: 19' M240 M Performance
I'm sure it's the same as all other manufacturers, it's only supposed to aid the engine in warm up. The faster the warm up the less pollutants. Once it's warm it should stay open.
      01-17-2020, 10:10 AM   #6
oz555
oz555's Avatar
671
Drives: M340i x-drive
2021 BMW M340iX  [9.00]
I do not understand why active grill at all. Can not make any significant benefit and only complicate the things. Doesn't look good neither.
eluded3002.00
      01-17-2020, 10:31 AM   #7
HighlandPete
Drives: BMW F11 535i Touring
Years ago folks used to use radiator blinds in winter, to aid/speed warm up, get cabin heat and extra mpg. They knew a thing or two. I'm surprised it has taken so long to get automatic OE shutters.
Of course they makes a difference.
There is a big push for faster warm ups, helps emissions, reduces parasitic drag within the engine, as the oil warms faster.
Reduces energy demand, less use of the 'assisted' electric cabin heating, now fitted in many models.
Improves the aerodynamics, again all about efficiency.
      01-17-2020, 10:58 AM   #8
Weiner0123
Weiner0123's Avatar
Drives: 2020 m340i. 2013 328i
Yeah also makes for a annoying trip to the dealer, had a extreme cold snap here in Calgary and it tried to engage and open the binds and just broke while doing so... lol keep an eye out.. at least it triggered a check engine light
eluded3002.00
      01-17-2020, 12:20 PM   #9
themnmd
themnmd's Avatar
Drives: 23 X5MC
+1
      01-17-2020, 01:20 PM   #10
x986
I'm still trying to figure the 340 grill. I thought it opened, but can't figure it out.
      01-17-2020, 04:19 PM   #11
VipinLJ
VipinLJ's Avatar
Originally Posted by premier3is View Post
Don't think it opens on the 340i only on the 330i
It opens in the M340i too
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-17-2020, 04:23 PM   #12
premier3is
premier3is's Avatar
1628
Drives: 2019 BMW 330i M-Sport
Ahh, I had no idea since the grill doesnt look slotted. Thanks for clarifying, I will remove my original post.
      01-17-2020, 04:25 PM   #13
VipinLJ
VipinLJ's Avatar
You’re welcome. No need to remove posts. We’re all here to share and learn
And yes. It doesn’t look slotted but it opens up behind the diamond pattern. It’s kinda like doors opening (or vertical louvers except the front portion is the attached part and the rear swings back)
      01-18-2020, 10:17 AM   #14
oz555
oz555's Avatar
671
I seriously doubt that benefit is significant. Someone should make real world test to prove that. New cars have different cooling system than the old cars. Second closed grill looks too cheap for one BMW.
      01-18-2020, 11:29 AM   #15
HighlandPete
It's a case of "every little helps". Reducing emissions, even if it may be as little as 3 g/km per vehicle, adds up across the fleet fitted with active shutters. One comment I've read, suggests that the CO2 saving in 2018, from vehicles fitted with active shutters was something like 25,000 tonnes.
There are tests, studies and papers, giving the data on reduction in aerodynamic drag, warmup benefits, etc. It is why active shutters are coming to most ICE vehicles.
      01-18-2020, 01:00 PM   #16
oz555
oz555's Avatar
671
In that case I approve the change even though I don't like them asthetically. 25.000 tonnes less per year is significant achievement.
      01-22-2020, 02:30 AM   #17
A6bullet
Germany
337
We should invest more in our education system.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      01-22-2020, 06:25 AM   #18
CrownRoyal79
CrownRoyal79's Avatar
Drives: BMW 435i
Cheers
During the hot summer months my grille stayed open all the time after the car got up to operating temperature. In the colder weather it's not open as much after I park unless I've been doing some spirited driving in sport+.
I assume that it closes on the highway to improve aerodynamics but of course I can't see it so who knows.
      01-23-2020, 10:11 PM   #19
the_mpd
Drives: 2015 F30 328i
Hi all,
I have an M340 that I just swapped the ugly diamondplate-looking grill out in favor of a more traditional black one. This has brought my attention to the active shutters - mine don’t appear to open, ever. One of the prior posts mentioned that the shutters actuate when the car is started. When my car starts, my shutters make some noise and open a little, but definitely nowhere near a 90 degree pivot. More like “cracking the window,” just barely angled from flat. After a few seconds they go back to fully closed. They don’t seem to open after driving either. I’m trying to figure out if this is normal behavior or if I should take it to the dealer. When others’ shutters actuate on engine start, do they fully open or just crack themselves? I should note that I’m in about 40 degree weather right now, which may be contributing.
Thanks in advance.
      01-23-2020, 11:40 PM   #20
NoSUV4Me
NoSUV4Me's Avatar
61
Originally Posted by the_mpd View Post
Hi all,
I have an M340 that I just swapped the ugly diamondplate-looking grill out in favor of a more traditional black one. This has brought my attention to the active shutters - mine don't appear to open, ever. One of the prior posts mentioned that the shutters actuate when the car is started. When my car starts, my shutters make some noise and open a little, but definitely nowhere near a 90 degree pivot. More like "cracking the window," just barely angled from flat. After a few seconds they go back to fully closed. They don't seem to open after driving either. I'm trying to figure out if this is normal behavior or if I should take it to the dealer. When others' shutters actuate on engine start, do they fully open or just crack themselves? I should note that I'm in about 40 degree weather right now, which may be contributing.
Thanks in advance.
Doesn't sound like your description is out of keeping with the functional objectives of the active grille - ie temperature mx and aerody optimisation
Excerpt: yes it's from the 7 but the concept surely isn't that diff
      01-24-2020, 04:46 PM   #21
rjwojcik
rjwojcik's Avatar
282
Drives: 2016 VW Golf GTD
Hi all,
Thanks in advance.
Any pics and which grills did you use (part numbers would be good).
      01-25-2020, 12:03 AM   #22
premier3is
premier3is's Avatar
1628
What's wrong with them aesthetically? I mean you're never gona be looking at them while driving, I see no issues. Only thing is it's hard to clean the grill, I tend to be more careful with them.
Also makes for a good discussion point lol.
oz555671.00
