Technical Topics Cosmetic and Lighting Modifications (exterior & interior) M Performance Side Skirt Fitting Question
      01-18-2020, 03:31 AM   #1
BMKILLA
Drives: BMW G30 530e
Hi Guys,
New G20 owner here. I have only just picked the car up but have already received some of the original m performance parts I plan to fit to the car. After looking at the side skirts which run 3/4 of the sill length I can see there are 14 rivet holes and also what seems to be a small 5mm channel running along the top of the inside of the part, this looks like it will take either a 5mm wise piece of double sided tape or maybe even a bead of sealant of some kind.
Does anyone have an understanding of how this is correctly fitted please? My dealer was helpful to a point but would obviously want to fit the kit themselves. I found a video on YT of someone fitting a set of carbon ones but they just used tape underneath and popped a few screws in, the problem with that is when I dry fit the skirts they do not fit air tight to the side of the car, when you push them they move a little, the same if you put any tape there as the tape thickness allows a 0.5 or 1mm push (or thicker depending on the tape thickness).
If anyone has a set installed and can see if there is any movement against the side of the car or any information on how the dealer would fit it would be greatly appreciated.
I do have them temporarily fitted to me car but can’t see how to upload from my iPad, once I figure out I will pop them up.
Cheers guys,
JJ
      01-18-2020, 03:34 AM   #2
BMKILLA
Some images.....
      01-18-2020, 05:05 AM   #3
WXdrivefun
WXdrivefun's Avatar
Drives: G20 330Xdrive
Link below, scroll to 'Installation Instructions' there's pdf file.
https://www.getbmwparts.com/oem-part...MtMGwtbDYtZ2Fz
      01-18-2020, 05:20 AM   #4
john!smith
john!smith's Avatar
230
Drives: M340i XDrive
      01-18-2020, 05:48 AM   #5
BMKILLA
Managed to find this post here that helps shows the parts needed https://g20.bimmerpost.com/forums/sh....php?t=1641301
      01-18-2020, 05:50 AM   #6
BMKILLA
Mega, thanks so much for taking the time to share this
      01-19-2020, 07:27 AM   #7
WXdrivefun
WXdrivefun's Avatar
No problem! I had some M-Performance goodies added to my G20, but went to third party BMW autobody shop for install. Made sure they did it as per OEM instructions..
Have fun for your install! Looking forward to final reveal!
      01-23-2020, 01:41 PM   #8
BMKILLA
Here she is, clean photos to follow!
