2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Grinding noise when reversing with AutoHold
      01-31-2020, 02:15 PM   #1
newway
Drives: BMW 320i M SPORT
Hi fellow BMWers,
I am a new BMW owner for only 2 weeks, mine's a BMW 320i G20 M SPORT, this is my first auto car so I am still getting used to it.
Everything seems fine except this one small thing, I noticed that whenever I put the gear in R and start pressing the pedal, the car would make a moderate grinding noise (similar to that noise you hear when start driving after car wash/rain). Sometimes the noise also occurs when I start the engine and start turning the wheel. After I start driving the noise will go away, no noise e.g. after waiting for a red light.
This only happens when the auto-hold is on, if I turn off the auto-hold feature and do the manoeuvre (e.g. reversing) the noise also went away.
Is this normal?
      01-31-2020, 04:02 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Is this on a very slow move off, as if the brakes are still partly engaged?
What if you are a bit quicker to move, still the same?
      01-31-2020, 05:59 PM   #3
newway
Good point, I will have a try later.
      02-13-2020, 04:17 AM   #4
newway
Just an update, I've been to the service center and I was told this is normal.
      02-14-2020, 06:51 AM   #5
cnichols138
X3M Comp is a beast
89
Drives: 2022 BMW X3M Comp
Mine tends to lock up the rear brakes when its cold out. I can put it in gear and it just sits there until I give it gas to break the brakes loose. I hope that is normal.
      02-14-2020, 08:56 AM   #6
vincechase
vincechase's Avatar
Drives: G20 330 M Sport
I think this is movement in the opposite direction when the parking brake is applied to the rotors.
Happen to me a few times in a huracan I left the parking brake on and tried to reverse. So im sure its the same concept
      02-14-2020, 09:20 AM   #7
VipinLJ
VipinLJ's Avatar
It’s normal. All my cars do it when it’s freezing outside.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      11-24-2020, 04:31 PM   #8
merlin99
Drives: G20 330i
Originally Posted by newway View Post
Hi fellow BMWers,
Is this normal?
I have this issue when switching from R to D makes like a grinding noise , think it's the electronic handbrake
      11-25-2020, 03:40 AM   #9
HighlandPete
Not sure what noise that is. Autohold uses the hydraulic system, not the electronic parking brake.
      01-31-2021, 03:25 PM   #10
merlin99
Drives: G20 330i
So when I switch from D to R the electronic handbrake isn't on . However if I engage the handbreak manually and then do the D to R no sound. So like you said the auto hold is forcing against the brakes but it does sound awful and still not right
autohold grind grinding
