12-18-2020, 05:30 AM | #485 |
Rep 43
Hi Shawn,
Could I please get the latest PSDZData links? Thank you very much. One question. I am unclear as to whether a new version of Esysx is needed every time we get a new iDrive version. I just move from 03/2020 to 07/2020 and lost all of my coding. Can I use the same Esysx version to restore the coding I had? I understand that when a new iDrive version comes out mappings need to be redone but is that only for what is new functionality? Thank you. |
12-18-2020, 06:17 AM | #486 | |
General
10483
Rep 40,939
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-18-2020, 07:28 PM | #487 |
Rep 176
Drives: 2019 BMW 330i
I still can't figure out how to apply cheat xml's but I'm wondering just for conveience if this is the screen I go to in order to edit the settings to apply them later? Would make life a lot easier if I don't have to have the car connected and running to read the values, set them and later program.
I went to Editors -> FDL-Editor and opened an NCD file. Not sure if this is the correct NCD or how I know which one to use, this does have the HU_MGU which is what I do want. Thanks for any help!! |
12-18-2020, 09:27 PM | #488 | |
General
10483
Rep 40,939
The .ncd filername is same as the corresponding ECU's CAFD name.
juhcobywankenobi36.00 |
12-18-2020, 09:46 PM | #489 | |
Rep 176
Also got the cheat xml's to work too, just need to make sure it's the correct series, so for my car S18A. So I think the last thing I need to make sure of, before I risk it, is that the coding of the car is the correct sequence. For manual modifications I do the following: 1. Connect to car 2. Read VO, Read ECU 3. Find Target CAFD file (i.e. under HU_MGU), right click the CAFD file, Read Coding Data 4. Edit NCD 5. Change desired value, then save 6. Go back, Code NCD. But if I use a cheat XML or modify the CAFD with the FDL editor, it looks like I don't want to subsequently read the coding data, because that will overwrite what I just changed (this is what I observed). Now I need to know if the following is the correct method to code values that I saved in the NCD file without reading from the car first: 1. Connect to car 2. Read VO, Read ECU 3. Find Target CAFD file and click on it (i.e. under HU_MGU) 4. Click 'Code', the Code NCD is greyed out Thanks again, this will make my life a lot easier. |
12-18-2020, 09:51 PM | #490 | |
General
10483
Rep 40,939
To write .ncd to ECU: Right-Click ECU CAFD File => Select New FDL => Navigate to C:\ESysData\CAF and select matching .NCD file => Left-Click on Inserted CAFD => Select FDL Code (Code NCD).
12-18-2020, 10:00 PM | #491 | |
Rep 176
Btw I think on newer Esys (3.34.0), or maybe it's just EsysX, doesn't have "New -> FDL", I've seen that referenced before. It has "New -> NCD", my guess is it's the same process because I now see "Code NCD" not being greyed out. |
12-18-2020, 10:08 PM | #492 | |
General
10483
Rep 40,939
12-18-2020, 10:29 PM | #493 |
Rep 176
Yea that's what I figured. And it worked! Thanks so much for all the help.
Btw, EsysX has a manual now: https://esysx.com/manual/ That proved to be pretty useful too for other questions I had. |
12-18-2020, 10:32 PM | #494 | |
General
10483
Rep 40,939
12-26-2020, 11:20 AM | #496 |
General
10483
Rep 40,939
PM sent.
12-27-2020, 07:41 AM | #497 |
Rep 5
Hi guys,
Trying to code "Situativer Abstand", guess I need your help on this one: - E-Sys 3.34 (latest supported for Launcher Pro) - Tokenmasters Launcher Pro 3.7 (latest available from Dec 2019 I guess) - v.4.27.20_PSdZData_Lite - Car is on 2020/07 Ffs, I just don't see SITUATIVERABSTAND in 3E52 HU_MGU. I can search for whatever I want, but nop.. Nothing. Nothing at all. Next option would be to contact EsysX as I cannot log in to my account anymore, no chance to access my EsysX license anymore. Or i'll just buy myself the dongle to get rid of my macOS Bootcamp installation. edit: Based on this reply (https://g05.bimmerpost.com/forums/sh...13&postcount=9), it's because of the old Launcher which hasn't got the codes mapped. Ordered a EsysX Dongle, let's see when it will arrive. Last edited by FabPod; 12-28-2020 at 05:46 AM.. |
12-28-2020, 11:37 AM | #499 |
General
10483
Rep 40,939
PM sent.
12-29-2020, 04:50 PM | #501 |
General
10483
Rep 40,939
12-30-2020, 11:26 AM | #504 |
General
10483
Rep 40,939
PM sent.
01-02-2021, 01:08 PM | #505 |
Rep 46
Drives: 2020 G20 330i
Just wanted to shout out to Shawn for answering my silly questions and linking the latest PSDZData file
Managed to code in, - anti-dazzle headlights (yet to test of course it's daytime) - automatic lane change assistant with driving assistance view - default to sport individual |
01-02-2021, 08:39 PM | #506 | |
Rep 46
So as poster above stated: 1. Connect to car 2. Read VO, Read ECU 3. Find Target CAFD file (i.e. under HU_MGU), right click the CAFD file, Read Coding Data 4. Edit NCD 5. Change desired value, then save 6. Go back, Code NCD. That is the normal process to make any coding changes, I understand that But now what happens next time I want to make a change. If I follow the steps above, is it loading the ECU file WITH the changes I've already made I read the instructions for loading the new FA into the car , with calculating FA -> Write FA FP to master Once that is the done the FA is now what the car loads everytime is my understanding, but does the FA contain all the ECU data, or is that the SVT ? Do I need to save the modified SVT file to the car so it loads the proper ECU data each time? Just trying to avoid having to code things if I make a change, having to recode things I've already done because it got changed back to factory default |
