BIMMERPOST Universal Forums Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..) F1 2022: Italian GP - Imola (Apr 24)
      04-16-2022, 02:02 AM   #23
M5Rick
General
M5Rick's Avatar
60986
Drives: M5 F10 DCT Gunmetal
Originally Posted by ///M Power-Belgium View Post
The new Ferrari 'diffuser upgrade ..
It seems like only this year Ferrari is splashing the cash meaningfully as opposed to the many previous they have wasted on garbage 1
F87source7310.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 02:09 AM   #24
F87source
F87source's Avatar
Drives: Bmw M2
Lol and don't forget their race engineers have finally woken up this year, no more "copy we're checking". It's almost as if they want to win again.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242
M5Rick60985.50
      04-16-2022, 02:48 AM   #25
M5Rick
General
M5Rick's Avatar
60986
FTFY
F1 veteran Mark Surer has said that RB simply had a too weak fuel line part, either that or it was not properly fitted leading to Max's race retirement.
DrFerry6731.50
NYG10841.50
      04-16-2022, 03:23 AM   #26
F87source
F87source's Avatar
Drives: Bmw M2
If it is a "too weak part" that could be a consequence of trying to make the material "just strong enough" for weight savings. Which isn't a good thing when redbull need to shave another 10 kg.
      04-16-2022, 03:57 AM   #27
M5Rick
General
M5Rick's Avatar
60986
Probably not much to be saved by a just fuel pipe lol, it's more likely it wasn't fitted well, a human error as Surer suggests. It's bad enough on the M cars as you know thinking you made a connection when it's not in properly.
DrFerry6731.50
NYG10841.50
      04-16-2022, 04:15 AM   #28
F87source
F87source's Avatar
Drives: Bmw M2
Yeah but when every gram matters they will shave weight off of the weirdest spots, like removing paint saves them 300ish grams. So if making the lines thinner saves weight they will do it.
I'm not sure how fuel lines are on other M cars, but on the n55 m2 and s55 it is quite easy, the clips won't snap down unless the fuel line is all the way in. Then the rest are threaded fittings.
It's possible for human error to be a factor, but that's really hard to believe because even a low pressure line would provide enough pressure that it will blow off if not fitted properly. So upon startup it should have failed immediately or started leaking immediately if it was human error. I'm thinking it is a parts defect, because if it was human error redbull would have said so immediately upon realizing no hoses were broken and it looked more like a leak due to cross threaded hoses fittings or a hose that has fallen off. But since there has been no real news as of late, I would think the issue is more complicated than it seems meaning it is more likely to be a part issue.
irunalot1518.00
      04-16-2022, 04:22 AM   #29
M5Rick
General
M5Rick's Avatar
60986
Well then the part in question was either weak or the connection was not strong enough, we must remember the fuel pressure is far more than in our cars so weighing up lightness and strength in the part is a tricky decision.
DrFerry6731.50
NYG10841.50
      04-16-2022, 04:35 AM   #30
F87source
F87source's Avatar
Drives: Bmw M2
Yes the HPFP on an F1 engine makes the regulated max fuel pressure of 500 bar. The HPFP on my n55 m2 makes a max of 200 bar, and the s55 about 260 bar. So pretty much double the pressure that DI street cars see (I think the F10 m5 runs around the same pressure as the s55 but likely more due to it requiring 8 injectors vs 6).
However those lines from the HPFP to the direct injectors tend to be made of stainless steel piping not hosing, because hoses can't tolerate 500 bar of pressure (even on street cars it is stainless steel), and the failure is reported to be from the lift pump or low pressure side to the high pressure pump. This low pressure side is much much much lower in pressure, as its job is to deliver volume and the HPFP's job is to pressurize it.
So the main focus is on the LPFP side, sure pressure isn't as high as the HPFP but it can still fail if the material was too weak due to weight savings, or it could have been a bad connection who knows. But my point is this is the side where expertise should be the highest from all the knowledge of port injection and prior f1 engine building. So it would be really strange to see this part fail because it is really common now, and probably not as changed as the HPFP parts. Maybe the ethanol weakened the hose, but I doubt that they would use anything not made of teflon or teflon lined.
irunalot1518.00
      04-16-2022, 07:17 AM   #31
GuidoK
#buildnotbought
GuidoK's Avatar
10980
Drives: Z4 3.0i ESS TS2+
apparently RB won't have enough time to complete the planned updates before Imola, so no new parts for Max and Checo this race.
So I'm altering my prediction:
1. LEC
2. SAI
3. VER
4. PER
5. ALO
6. HAM
BTW the HPFP in my Volvo diesel does 1800 bar. I win
NYG10841.50
      04-16-2022, 07:49 AM   #32
M5Rick
General
M5Rick's Avatar
60986
Isn't it 5 bar not 500. ie 5 bar equals 72.5 psi.
NYG10841.50
      04-16-2022, 07:51 AM   #33
M5Rick
General
M5Rick's Avatar
60986
1. LEC
2. SAI
3. VER
4. PER
5. ALO
6. HAM
I'm afraid I can only take your first prediction
GuidoK10979.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 08:00 AM   #34
iamwingman
Drives: 21 Carrera S, 23 Tesla Model S
I’m in.
Ver
LeC
Russel
Sainz
Perez
Lando
Ham
Alonso
Mags
DannyRic……
M5Rick60985.50
GuidoK10979.50
      04-16-2022, 08:01 AM   #35
M5Rick
General
M5Rick's Avatar
60986
Originally Posted by iamwingman View Post
I’m in.
Ver
LeC
Russel
Sainz
Perez
Lando
Ham
Alonso
Mags
DannyRic……
GuidoK10979.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 09:03 AM   #36
///M Power-Belgium
General
///M Power-Belgium's Avatar
Drives: ///M3-E92-DCT Silverstone II
"Toto Wolff questions legality of Ferrari engine" !
=> https://gp33.nl/toto-wolff-zet-vraag...ferrari-motor/
Toto that wont help you ...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
M5Rick60985.50
GuidoK10979.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 09:39 AM   #37
///M Power-Belgium
General
The weather prediction for next weekend is rain ...
M5Rick60985.50
GuidoK10979.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 10:38 AM   #38
3798j
3798j's Avatar
11563
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
“It’s still pretty early to think about the championship."
“[We will] just focus on ourselves, try to maximise the package and I think [the next race at] Imola will probably be a better track for our car.” ---Charles Leclerc
NYG10841.50
      04-16-2022, 01:12 PM   #39
M5Rick
General
M5Rick's Avatar
60986
Wonder how Lec will be in the rain against Max, the bulbous red car could be a bit 'jumpy' in the rain
GuidoK10979.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 01:40 PM   #40
///M Power-Belgium
General
More HP and a new rear wheel suspension for the Ferrari in Spain => https://gp33.nl/ferrari-introduceert...link-meer-pks/
It won't be easy for MAX to beat the Ferrari...
GuidoK10979.50
DrFerry6731.50
NYG10841.50
      04-16-2022, 02:09 PM   #41
GuidoK
#buildnotbought
GuidoK's Avatar
10980
More HP
Toto must be going mad.....
NYG10841.50
      04-16-2022, 02:17 PM   #42
F87source
F87source's Avatar
Drives: Bmw M2
No, the hpfp on F1 cars run 500 bars. Yeah it's crazy, street cars run 200 bars or more.
The lpfp side might be around 5 bar.
M5Rick60985.50
      04-16-2022, 03:07 PM   #43
GuidoK
#buildnotbought
GuidoK's Avatar
10980
They limit GDI to approx. 200 bar due to wear on the injectors.
This is not a real issue on F1 engines as they run 3000km?, not 300.000km which is normal for a street car.
Of course diesel is a lubricant itself (it's an oil) so 10 times that pressure is no big deal for injectors.
M5Rick60985.50
NYG10841.50
      04-16-2022, 03:13 PM   #44
///M Power-Belgium
General
DrFerry6731.50
M5Rick60985.50
irunalot1518.00
NYG10841.50
