Technical Topics DIYs and Coding Discussions Different coding
      02-05-2022, 09:13 AM   #89
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
Originally Posted by siegester View Post
What software version are you on?
Car is on 07/2021.40
Well, I just might wait until I'm on 11/2021.xx to try it out then 😕. Our redlights are the same way here.
      02-09-2022, 06:16 AM   #90
samcrooks182
Drives: BMW F30
I have coded aSLA on BimmerCode on my G20 but it doesn’t work. Can this function work without DAP? I don’t have adaptive cruise. It originally had SLA and I could manually press set, just no auto changing.
Thanks,
Sam
      02-09-2022, 01:30 PM   #91
Bambazonke
Bambazonke's Avatar
Drives: 2017 X5 & 2020 X5
  [0.00]
You need DAP (5AU) for aSLA to work and BC can only code 2 of the 4 ECU's (BDC & HU _MGU's) that need to be coded. Have to use ESysx to change settings in the SAS3 & DSC_VIP ECU's for aSLA & TLA to work
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
val200049.50
      02-10-2022, 01:58 AM   #92
samcrooks182
Drives: BMW F30
That makes more sense thanks! Does the G20 have the SAS3 module if it doesn’t have DAP?
      02-10-2022, 02:16 AM   #93
Bambazonke
Bambazonke's Avatar
  [0.00]
I have a G05 which comes std with DAP in Australia so I cannot give you a definite answer
I think the SAS3 or equivalent in the G20 is part of DAP and is not fitted to vehicles that don't have DAP fitted from factory Maybe some G20 owners without DAP & have access to Esysx software can confirm my assumption
      02-10-2022, 05:10 AM   #94
Bambazonke
Bambazonke's Avatar
  [0.00]
@Siegster
I coded aTLA in my car some time ago and turned it off. While it seemed to work, the major problem is where traffic lights are positioned. Here in VA, they are mostly on the far side of the intersection, occasionally hanging in the middle of the intersection and my car would attempt to stop in the middle of it -- not good!:
I noticed there are some TLA distance offset parameters in the KAFAS ECU which may be worth investigating I think your current settings are configured for European traffic lights
siegester344.50
SaNGRia990.00
      02-10-2022, 12:52 PM   #95
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Car will still have SAS module.
      03-30-2022, 07:16 PM   #96
SaNGRia
SaNGRia's Avatar
990
Drives: LCI E93 M3 + F85 X5M
Appreciated. Can i get the FSC from any source to activate this ? I would like to gain GWW and WWA.
Originally Posted by ifr View Post
Yes U need the FSC plus KAFAS coding.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      04-18-2024, 01:07 PM   #97
larrybml
Drives: X3 F25 2011
Please help.
Hello guys , I'm back in business as I just bought an G20 2021 with Drive Assistant Proffesional, so it has all the things like eTLA, TLA ... etc, but the problem is that I live in Romania and some services are working only in some country. As I understand from reading this tread, there are some codings that can be done for removing land locked options. Can someone please help me with these codings? and in witch modules they need to be done?
Thank you in advance.
