2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK G21 key fob tailgate opening
      03-21-2024, 04:28 AM   #1
Phil1703
18
Drives: BMW 320D Touring G21
Is there a way to disable the key fob button that opens the tailgate?
On several occasions I have accidentally opened it without realising until someone knocks on the door and says “did you know your boots open”🙄
      03-21-2024, 04:35 AM   #2
willougs
willougs's Avatar
267
Drives: BMW 330e
Apparently so...
For cheaper charging, switch to Octopus Energy using this link and get £50 free credit
      03-21-2024, 04:43 AM   #3
Phil1703
18
Unfortunately I only get the first 2 options 🙄
Mine is a late 2019 model.
      03-21-2024, 04:50 AM   #4
lnlyssg
58
Drives: BMW 320i
Have you got a physical boot button on the driver’s door? I would guess that the option to disable the fob is only applicable to cars that have that button.
      03-21-2024, 05:45 AM   #5
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
My 2021 G21 doesn't even give the first two options - I simply get "driver's door" or "all doors". Doesn't even mention the tailgate.
Ian
      03-21-2024, 06:05 AM   #6
willougs
willougs's Avatar
267
Drives: BMW 330e
Yeah. Does say some options may not be available. Guess as usual UK market gets shafted. I've not checked mine but I don't recall seeing it.
      03-21-2024, 08:18 AM   #7
Stokeybry
Stokeybry's Avatar
Drives: 320d M Sport G21
That should be available through bimmercode or bimmer utility
      03-21-2024, 08:37 AM   #8
lnlyssg
58
Drives: BMW 320i
You can change the delay up to 10s in Bimmercode. I had a quick look through the expert settings too, a number contain BOOTLID but I didn't see anything that was immediately obvious in there.
      03-21-2024, 08:38 AM   #9
Phil1703
18
Yes I’ve got button on drivers door
      03-22-2024, 04:00 AM   #10
Rhino at Work
Rhino at Work's Avatar
714
Drives: G21 330i Portimao Blue
Had a play with mine and found that if you assign it to Lock Tailgate Button it just goes dead so would give the result you want.
Previous: EB F30 340i Shadow Edition
Previous: EB F30 330d xdrive
zlatko117.50
      03-22-2024, 01:05 PM   #11
Phil1703
18
Unfortunately the only 2 options I get are tailgate or tailgate and doors.
I wonder whether the additional options are available with later software updates that keep failing to install on my car - but that’s another story 🤬
      03-22-2024, 01:20 PM   #12
Rhino at Work
714
Well that's a bummer. Just for reference I'm on 11/2023.50 but, not surprisingly, I've no idea when those additional options appeared.
