11-05-2022, 04:07 PM | #155 |
Rep 51
I installed one in my 2020 330i. just turned it in (lease) and bought a 2023 with one installed. so i have one to sell that works fine. easy to install and code via bimmercode. works great. dm me if interested in buying
11-11-2022, 01:21 AM | #156 |
Rep 137
Did your 2020 have the connector to plug into the bottom of the tray when you installed it?
11-11-2022, 04:31 PM | #157 |
Rep 51
11-12-2022, 11:05 AM | #158 |
Rep 137
12-21-2022, 06:28 PM | #159 |
Rep 6
Hey, Gaushell. Is the wireless charging pad from your ‘20 still available? Apologies for not DMing…new to the forum and it won’t let me! If you still have it, I’m interested in taking it off your hands. How much would you like? Not sure if I’m able to receive DMs. Thanks in advance…and sorry to all for the spam!
12-21-2022, 07:28 PM | #160 | |
Rep 51
12-22-2022, 05:45 AM | #161 |
Rep 6
All good; thanks for the quick response, gaushell.
Unless anyone out there recommends otherwise, I think I’ll purchase a new “Charging Device 619900, Part # 84-10-5-A3E-813” and swap it out with my factory NFC pad. Appreciate all the great info on this thread. Happy holidays to all! |
12-24-2022, 12:32 AM | #162 | |
Rep 137
If you're interested I can sell you my charging pad as mine wasn't manufactured with the cables to plug it into. |
XXXcdi0.00 |
12-24-2022, 06:52 AM | #163 |
Rep 6
12-24-2022, 07:28 AM | #164 |
Rep 6
Hi, Jan. Thanks for reaching out. I received your PM, and attempted to respond multiple times. I guess I’m still too new here for such a privilege! I’m actually planning to pick one up later this AM locally, but would happily take yours off your hands.
I can receive DMs, just not respond. Please hit me up again via DM and perhaps we coordinate via text. Sorry to all for having a two-way conversation on this thread; not my intent! |
02-09-2023, 07:22 AM | #165 |
Rep 54
Drives: 2020 M340i X & 2011 335i X
The LTE compensator #2 is to boost the cellular signal. It isn't needed for charging. I would like to add the compensator as well. Does anyone know where this usually is installed and if the wiring harness is already in place?
Thanks |
04-22-2023, 01:50 PM | #166 |
Rep 3
I am trying to do this on a g23 430i... I cannot for the life of me get the old NFC-only tray removed. It seems to be anchored somehow. Anyone know how to do about doing this?
edit --- there are two downward facing tabs on the front plastic. i had to pull them towards me a significant amount while simultaneously moving the tray upwards. if all 3 things are not done carefully it doesn't budge. Last edited by rv0760; 04-24-2023 at 02:17 PM.. Reason: added my own fix |
06-26-2023, 02:28 AM | #167 |
Rep 73
Drives: BMW 2023 G82 xDrive
does this end up making the phone too hot or how is the phone’s temperature after usage?
06-26-2023, 02:57 PM | #168 | |
Rep 80
Are these options in esys? Also what is VO? Everyone keeps mentioning it |
12-27-2023, 02:52 PM | #169 |
Rep 79
12-27-2023, 02:53 PM | #170 |
Rep 79
01-03-2024, 08:44 PM | #172 |
Rep 28
When changing the charge pad out do I need to take out all of the trim around the shifter? Or do I just need to take cupholder up and then will be able to get old pad out? Vehicle is 2022 m440i coupe.
Thanks |
01-28-2024, 05:44 AM | #174 |
Rep 7
I successfully installed wireless charging pad in my 330i (2019), coded through the bimmercode app and everything works fine , previously I had pad only with nfc.
Part that I have been used: 84105A3E813 Last edited by Nikolaslogs; 01-28-2024 at 06:16 AM.. |
01-30-2024, 01:26 AM | #175 |
Rep 28
