10-20-2020, 07:12 PM | #111 | |
936
Rep 4,327
Drives: M340
It successfully separates the turn signals from brake lights but I still get hyper flashing. I wonder if having lasers light option upfront makes a difference. Do you have laser lights up from on your car? And do you have front foglights? I am assuming all of those would change the parameters.
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired Last edited by TTG; 10-20-2020 at 08:04 PM.. |
10-21-2020, 10:31 AM | #112 | |
Rep 22
I have laserlights, but no foglights |
10-21-2020, 10:34 AM | #113 |
936
Rep 4,327
Drives: M340
OK thank you, then sounds like our cars are the same. Also, dealer installed the 7/2020 software update on my cars as well.
10-21-2020, 04:08 PM | #115 |
936
Rep 4,327
Drives: M340
Yup, I can code with no problems.
10-21-2020, 11:18 PM | #116 | ||
Luxury at the redline :)
9108
Rep 7,563
Just a thought, try to locate the "warm bulb check(s)" for the turn signals and disable them. This resolves the hyper-flashing on the F gen vehicles, when retrofitting the LED LCI taillights.. |
10-22-2020, 10:57 AM | #117 | |
936
Rep 4,327
Drives: M340
It couple be a wild goose chase if you start going through all the bulb checks. It is a very good idea though.
Poochie9107.50 |
10-22-2020, 08:57 PM | #118 | ||
9108
Rep 7,563
10-24-2020, 09:27 PM | #119 |
Rep 751
So I had this working on 07.2019 with @larrylam646's values, but I get hyper flashing with those values after being updated to 07.2020. Attached is the new diff of 5665 that I generated between ECE (5U71) and US (5U73). Yellow are unchanged differences from 07.2019, green are new value differences, and red are values that are still different, but have changed. There were a few previously different values that are now the same, and thus are not listed in my sheet. After making these new changes the rear turn signals function independently without hyper-flashing. Maybe these values will help others with the hyper-flashing issues too.
For a more copy/paste friendly version, view the PR I have up for Esys cheats here - https://github.com/packetpilot/bmw-f...0783afcf8f2eb0 Last edited by siegester; 10-25-2020 at 05:11 PM.. |
NYC_340i208.00 |
10-25-2020, 02:35 PM | #120 | |
Rep 22
It works thanks larrylam646! I'm afraid it's not possible with bimmercode. Not every option is visible |
10-25-2020, 04:31 PM | #121 | ||
9108
Rep 7,563
12-07-2020, 01:56 PM | #123 | |
Rep 22
NCD/CAFD Tool from Tokenmaster doesn't work with G20 files. Or maybe I'm doing sth wrong.. |
12-07-2020, 02:25 PM | #124 | |
Rep 464
I am currently using EsysX (launcher), Esys 3.34 and Notepad++. In Esys, the FDL-Editor and Coding-Verification tools can write-out CAFD ".fwl" files. Use Notepad++ to compare CAFD ".fwl" files. See https://f30.bimmerpost.com/forums/sh...44&postcount=2 Or purchase the "Expert" version of EsysX. It integrates a CAFD file comparison tool. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
BigMofoFrog181.50 |
12-07-2020, 03:57 PM | #125 | |
Rep 22
12-28-2020, 07:44 PM | #126 | |
Rep 173
Drives: 2021 M340i
Am running on 07.2020 software and used EsysX and Esys 3.27.1. Unfortunately, some of the parameters were not available via Bimmercode, but since I had experience with Esys on my previous F30, it wasn't too difficult to FDL code the changes between NA and ECE parameters!
Current - 2021 G20 M340i xDrive - Saphira
Retired - 2015 F30 328i - Celine |
12-31-2020, 07:13 PM | #127 |
Rep 547
Thanks to larrylam646 , jk1112, siegester and anyone else for sharing the coding they found. Was able to code the euro turn signals pretty easily on my car which is on 7/2020.
Also I added in the extra values to change to get the anti-dazzle lights working better. Before all I did was remove 5AP and FDL code and then change COUNTRY_VARIATION, C_FLA_BS_ENTER_THRESH and C_FLA_BS_EXIT_THRESH and it worked fine but being in NYC it still rarely went off due to car reflectors or signs. I didn't get a chance to test the additional changes yet to see if they make a difference but can't wait!
Current: 2020 M340xi Previous: 2016 340xi |
10-08-2021, 01:21 PM | #129 | |
Rep 47
This is exactly what I am looking for! What do I have to do, as a person that has no idea how to code, to get this done? Is there somewhere where I can learn to code? Is there anyone in Colorado I can pay to do this for me? Please help! My only alternative is to just not use my turn signals at all! LOL
10-09-2021, 02:26 PM | #130 | ||
Rep 751
10-12-2021, 02:16 PM | #131 |
Rep 47
10-17-2021, 08:49 PM | #132 | ||
Rep 751
Also, I had to generate a new diff for 2021.07 as none of the previous value combinations worked. I'll post the new values once my desktop works again |
