10-23-2014, 10:05 AM | #1 |
2714
Rep 7,300
BMWPartsPros.com | BMW 2 SERIES M PERFORMANCE BRAKE KIT + FREE SHIPPING!
AVAILABLE IN RED, YELLOW, AND ORANGE. Brembo high-performance 4-piston aluminum fixed caliper on the front axle and 2-piston aluminum fixed caliper on the rear axle. Improved thermal resistance thanks to larger, internally-ventilated, lightweight-construction sports brake discs. Drilled (dimpled) and grooved brake discs also reduce water film build-up between the brake lining and the disc surface. Available in M Performance Red, Yellow or Orange – all with an M logo on the outside of the caliper. Drilled and grooved, internally-ventilated lightweight brake disks with riveted aluminum hat measuring 370 x 30 mm (diameter x thickness) on the front axle and 345 x 24 mm on the rear axle (rear brake discs must be ordered separately). [COLOR="RoyalBlue"]LINKS: RED: http://bit.ly/F22BMWRED YELLOW: http://bit.ly/F22BMWYELLOW ORANGE: http://bit.ly/F22BMWORANGE Last edited by PARTS@STBMW; 02-22-2022 at 11:48 AM.. |
03-04-2015, 04:48 PM | #2 |
10861
Rep 27,630
update your breaks and keep your warranty! These look awesome in person!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-17-2016, 11:21 AM | #4 | |
2714
Rep 7,300
01-18-2016, 01:24 PM | #5 |
2714
Rep 7,300
STOCK M235i BRAKES VS M PERFORMANCE BRAKES
GOOD MORNING,
YES ITS A SLIGHT UPGRADE. ITS THE SAME PERFORMANCE CALIPER, BRAKE PADS AND HARDWARE. THE ONLY DIFFERENCES IS THE M PERFORMANCE COMES WITH SLOTTED ROTORS AND THE COLOR OF THE CALIPERS. REGARDS, DAVID@BMWPARTSPROS.COM |
11-10-2017, 03:02 PM | #6 |
Rep 1,161
The front disc diameter is increased to 370mm
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
04-19-2018, 07:47 PM | #7 |
Rep 66
Drives: 2018 M240i
I'm interested, but ad indicates "rear brake discs must be ordered separately"; photo on website clearly shows 4 discs. What's up with that?
04-20-2018, 12:18 PM | #8 |
2714
Rep 7,300
07-16-2018, 10:52 AM | #10 |
2714
Rep 7,300
07-30-2018, 09:24 PM | #11 |
Rep 10
Will these be the right fitment for a 2017 BMW 230 Xdrive with normal brakes currently not M performance ones. My rims are 18". Please confirm as I have not found a clear answer for this. Also what are the shipping rates for Toronto Canada? Any extra customs charges to deal with? Also I read that rear disks are extra? The photo shows all 4 in the set.
07-31-2018, 11:33 AM | #12 | |
2714
Rep 7,300
This kit will not fit on your model due to rim size being too small. This performance brake kit requires a size 19 and up to fit. We do not ship to Canada, but do except U.S. registered payments and addresses. Yes, rear rotors are sold separate. Picture shows everything that is required for the kit. -Britney |
Ronco0.00 |
