02-17-2019, 07:09 PM | #1 |
REP 1,447
G20 USB-C max power output?
Anyone know what is the max power output of these usb-c ports in centre arm rest and back of center console? I don't think it supports 87W or 60W for 15/13 inch macbook pro charing. Maybe 30W? 18W? If it only supports 12W, it is really lame. As the car is not 48V mild hybrid, it only output max 12V, so power delivery with 9V*2A=18W? Maybe? Can only charge you iPhone and nothing else. Just my speculation. could be just 12W
02-18-2019, 01:38 AM | #2 | |
REP 1,090
USB C without PD is 5v * 3amp. if its usb PD there are rules as to what voltages must be supported, I know if its higher than 15W it must support 5v * 3 and 9V * 2. 30W needs 15v support. I bet its just 5v * 3amp. Though you CAN charge a macbook or laptop very slowly with that so I guess its not entirely useless. |
02-18-2019, 09:44 AM | #3 | ||
REP 428
If that's not enough power for you I use this in my G30: https://www.amazon.com/Charger-Anker...way&sr=8-3 Charges even my MacBook Pro 15 (takes awhile of course and can't really charge while on), works well charging son's switch and MacBook 12 Here's a page from G05 tech update:
G30 540i Msport
G05 X5 xDrive40i Msport Retired '03 330i, '10 335d |
hans007625.50 |
02-18-2019, 11:50 AM | #4 |
REP 2,292
So newer BMW's have fully adopted USB-C? Cool!
Eagle Creek139.00 |
02-20-2019, 03:39 PM | #5 |
BMW Client Advisor
3,510
REP 2,503
Yes G20 has 3 USB C ports and one USB A
Pauleebe383.00 Eagle Creek139.00 |
02-22-2019, 08:41 PM | #6 |
REP 2,359
I use one of these
https://www.cygnett.com/products/chargep-pro27k-60w I leave it in the car during the week which charges it slowly (my F13 M6 seems to output about 2A at 5v) and when I need to charge my X1 Carbon the battery bank is able to charge it at 60w. The one thing that I've found that is quite funny is that it can do pass-through charging for phones just fine, but when you're feeding it 5v it can't output more than that to a laptop - not that it matters much as 60w out and 10w in will still discharge it really quickly. I also use it as a charger for the smaller battery banks I use on a hike or something and I know they'll be full the next time I come back to the car and I don't need to carry a bit heavy unit around.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
03-28-2019, 02:41 PM | #7 |
REP 3
Jay P
I heard that the two rear USB-C ports are only for charging, and that the USB-C in the center console can charge & perform data transfer with Nav. My dealer said that only the USB-A port in the dash/coffee cup area can be used with an iPod (or similar). Is this true? Thanks |
Eagle Creek139.00 |
10-17-2019, 01:44 AM | #8 |
REP 259
I managed to charge my 13" MacBook Pro from 28% to 75% using one of the rear USB C today over an one hour drive. I think that's pretty good.
Eagle Creek139.00 |
10-20-2019, 11:04 AM | #9 | |
REP 490
10-20-2019, 11:20 PM | #10 |
REP 56
From the online owners manual:
(Sockets section) The total load of all sockets must not exceed 140 watts at 12 volts. (USB interface section) A USB interface is located in the center armrest. Properties: USB port Type C. For charging of mobile devices. Charge current: max. 3 A. With navigation system: for data transfer. A USB interface is located in the center console. Properties: USB port Type A. For charging mobile devices and for data transfer. Charge current: max. 1.5 A. A USB interface with two USB ports is located in the center console in the rear. Properties: USB port Type C. For charging of mobile devices. Charge current: max. 3 A per connection. |
Eagle Creek139.00 pedro_no118.50 |
08-05-2020, 07:20 AM | #12 | |
REP 250
However if you are installing a map update downloaded from BMW connected drive onto a USB you must use the USB C in the armrest. I have an adapter that converts a USB A to C. Took me ages to work out to use the USB C for Maps. For adding music onto the iDrive hard drive you can use both. The ones in the back are charge only.
Current: 2020 M340i
Past: M140i, Z4 35is |
pedro_no118.50 |
08-05-2020, 07:25 AM | #13 | |
Grumpy Old Git
439
REP 923
Retired:
08-05-2020, 09:34 AM | #14 |
REP 80
08-05-2020, 03:35 PM | #15 | |
REP 250
Manual also seems to say USB C for map update. It didn't make sense at the time and even less so now. Next update I'll try A. Thanks.
Current: 2020 M340i
08-06-2020, 06:30 AM | #16 |
Rep 3
Did you use a USB C Power Delivery (PD) cable or non PD?
03-20-2023, 02:11 PM | #19 |
REP 61
This post aligns with my measurements on a 2023 M340i: https://x3.xbimmers.com/forums/showp...7&postcount=13
10-24-2024, 04:31 PM | #20 |
REP 21
Is there a way of getting 2x usb c ports I. The arm rest? I find the front usb a port can barely add a charge to an iPhone that’s being used for CarPlay on a journey
10-27-2024, 12:06 PM | #21 | |
REP 177
If you have data in the armrest- then source a double usb-c port from a u11 bmw. That can support two data ports and charging ports. If you don’t have data in the armrest, then you can just find the rear seat double usb-c for charge only, and that will fit in the armrest (plug and play) |
10-27-2024, 12:37 PM | #22 |
REP 480
If cables from the cup holders works for you, try a dual "USB-C PD" plug that connects to the 12V outlet. I haven't tried if there is sufficient cooling, but there are some models in metal and sits almost flat with the outlet.
