E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Newbie Question Again!
Reply
      08-03-2008, 12:39 PM   #1
que2k
Drives: 335xi Sedan
My E90 should be here in about 10 days and I've started shopping around for a deal on winter tires.
I'm getting a 335xi sedan with sport-kit and it comes with the Style 162 18" rims.
In a previous thread I was told I can run 225/45/17 winter tires. My question is I'm still confused about the wheel size, especially the whole off-set thing.
Will at 17x8 rim with 38mm offset & 5x120 bolt pattern fit?? Tirerack says yes, 1010 tires says no.
"Her name is Naomi, that's I moan backwards"
      08-03-2008, 01:10 PM   #2
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
17x8 should fit, someone correct me if i'm wrong but that is the same size as oem 17's right?
      08-03-2008, 11:33 PM   #3
TurboFan
Ski bum
TurboFan's Avatar
317
Drives: sideways
8.5 is stock on the 17's but you'll be fine. My 19's are a 22mm offset with a 9.5 inch wheel in back.
1999 e46 328i Ti Silver / Black[retired]
2007 e90 335xi Jet Black / Black[retired]
2011 e70 X5 35d Vermillion Red / Cinnamon
2011 e92 M3 LeMans / Fox Red extended
      08-03-2008, 11:57 PM   #4
msinfo_us
msinfo_us's Avatar
Drives: 335Xi ZSP, ZCW, PDC
The issue is with an oversize breaks we've got. Going by just the numbers it will be hit and miss, some models fit and some don't. I've got my winter setup om M3 replicas and they fit fine. No rubbing. My advice would be to choose style/model you like and call tirerack or even better hit our "local" expert in a wheels and tires section of this forum.
07 e90 335Xi, SB/Black, ZSP, ZCW, PDC
06 e91 325XiT, TS/Black, ZSP - Sold
      08-04-2008, 05:55 AM   #5
nyc3r
nyc3r's Avatar
Drives: E90
that offset is fine, don't worry about the breaks, they fit in the stock 17"s.
      08-04-2008, 03:03 PM   #6
Nikolas
Drives: 996 TT
Not all 17" designs will fit over the brakes. It will depend on the design of the wheel.
Reply
e90post
