Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics HK equalizer settings
      06-12-2019, 07:51 PM   #1
bones
Drives: 2020 M340 RWD
whaddya got? any audiophiles want to share their setups?
      06-15-2019, 12:52 AM   #2
Xsapper
Xsapper's Avatar
233
Drives: G20 330i M Sport
As we all know this is a personal preference. I found this on another site and its my current configuration. I also use the flac file format for my recorded music.
Treble Flat, Bass +2. Logic 7 on
100 hz +3
200 hz +2
500 hz Flat
1 khz -2
2 khz -1
5 khz Flat
10 khz +2
      06-15-2019, 10:52 PM   #3
bones
thank you!
      06-15-2019, 11:45 PM   #4
claykin
Drives: various BMW
Referencing the above settings, try
Logic 7 - off
200hz - - 1 or - 2. HK tends to sound muddy when 200hz is flat or +anything.
bones122.50
      06-18-2019, 11:55 AM   #5
PandaMobile
PandaMobile's Avatar
Drives: 2020 M340i TB II
2020 BMW M340  [0.00]
100 hz +3
200 hz +2
500 hz Flat
1 khz -2
2 khz -1
5 khz Flat
10 khz +2
What kind of music do you listen to?
      06-19-2019, 02:04 AM   #6
Xsapper
Xsapper's Avatar
233
I guess mainly classic rock as I am old school.
themnmd1691.00
      06-21-2019, 10:45 AM   #7
PandaMobile
I listen to Hip hop and I notice that at certain tones the center speaker buzzes of rattles. Kind of annoying. Do you think the mid tones could be causing this or should I have then replace the center speaker?
      06-22-2019, 09:41 AM   #8
Xsapper
Xsapper's Avatar
233
I guess that they could but I would explore other reasons first before changing the speaker. Take the grille off and see if it stops. Check that the speaker mounts are tight.
      04-09-2020, 08:11 PM   #9
Sergeant Skinner
Sergeant Skinner's Avatar
166
Drives: 2020 BMW M340i XDrive
It’s been a while now, and while I do think the HK in the G20 is vastly superior to the F30 but has anyone worked out what their best settings are?
      04-09-2020, 10:50 PM   #10
shawntech
The Wolf
shawntech's Avatar
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
I run the hk bass treble nearly full then a V for the rest sounds alright, hk still a lot better in f32 imo
      04-10-2020, 07:34 AM   #11
Burrcold
Drives: 2024 M3 Comp xDrive
Same here.
      04-11-2020, 01:42 AM   #12
Sergeant Skinner
166
Same here.
Yeah, I'm finding this is the best setting too. The surround setting creates a nice depth to music as well (but I'm sure it's blasphemous to have it on for most people due to the added sound processing).
      04-13-2020, 01:37 PM   #13
msalisbu
Drives: 2023 m340i
Is there any difference in audio quality/codec when using Car Play versus bluetooth only? I use Tidal for streaming.
      04-13-2020, 03:33 PM   #14
cls49bmw
Drives: 2023 X3 M40
Carplay uses WiFi to transfer data between your phone and the car's system. I read on another thread here that WiFi "moves" more data, and faster, than a bluetooth connection. Thus, audio quality is enhanced using Carplay, and should sound better than just streaming over bluetooth.
The other person posting about it cited numbers, but anecdotally, I've done it both ways, and listening with Carplay has a "richer" sound.
Search this forum for Carplay and you'll find more discussion.
      02-26-2022, 08:33 PM   #15
Ratledge
Ratledge's Avatar
21
Drives: 2023 BMW 430iX GC / G26
2023 BMW  [0.00]
Lightbulb
Logic 7 - off
The best solution here is to put a bass kicker in the back, which works especially well with the GC models because the leads and amp are in the "trunk".
Something like a 12" (or larger) kicker will work best. You always want a self amplified ("active") unit, not passive because it needs mo' power!
      03-03-2022, 04:59 PM   #16
bossfan61
bossfan61's Avatar
24
Drives: BMW m440i
I recently coded my 2022 M440i Gran Coupe with HK and discovered an option to turn on Bang & Olufsen sound settings (Concert Hall, Studio, Lounge, etc). If you code, you might find this option on your models.
      04-08-2023, 11:02 AM   #17
JITH
Drives: M440i
https://www.songstuff.com/recording/...q_frequencies/
Maybe this can help somebody.
      07-07-2023, 12:04 PM   #18
Gladius Nova
Gladius Nova's Avatar
78
Drives: G20
  [0.00]
I use the V.
