Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Mirror memory
      06-16-2019, 11:16 AM   #1
vicfalc09
vicfalc09's Avatar
223
Drives: M340i xDrive
Mirror memory
Has anyone had any issues with the passenger side mirror not going back into the memory position. My driver side seems to remember the setting but the passenger side does not.
      06-16-2019, 11:41 AM   #2
vicfalc09
vicfalc09's Avatar
223
Can someone check and report back. Want to see if I broke something when I swapped my mirror caps.
      06-16-2019, 02:27 PM   #3
xraymd
xraymd's Avatar
Drives: 23 M2, 22 Lincoln Navigator
No issues with mirror memory. I have tilt down on reverse activated.
      06-16-2019, 02:29 PM   #4
vicfalc09
vicfalc09's Avatar
223
So if you move around the passenger mirror then hit your number 1 setting it goes back to your adjusted setting...
      06-16-2019, 10:04 PM   #5
xraymd
xraymd's Avatar
Oh, not that.
The mirror dips down when I reverse. It returns to correct position in drive. This feature is activated with the same switch you use to select which mirror you want to adjust. I’m can’t remember if I have it pushed left or right.
I haven’t tried moving between 1 and 2. I put the mirror where I wanted it at delivery and haven’t moved it. I’ll try tomorrow.
      06-17-2019, 08:35 PM   #6
dpod25
Drives: 2019 330i xDrive
No issue here, it works fine for me. Does your passenger mirror tilt-down when you put the car in reverse? If not, then might be a problem with your motor.
      06-18-2019, 06:02 AM   #7
vicfalc09
vicfalc09's Avatar
223
Yes tilt for reverse works fine. What is not working is pressing the number 1 position and only the passenger side mirror going back into its preset position. Works on driver side but for some reason passenger will not go back.
      06-23-2019, 10:32 AM   #8
vicfalc09
vicfalc09's Avatar
223
I replaced the mirror motor with a previous gen 3 series and all functionality is back. I broke the motor when I did the mirror cap install.
Here is the part that work in my G20:
https://rover.ebay.com/rover/0/0/0?m...2F183251745757
xraymd314.00
VipinLJ1965.50
      02-25-2020, 06:11 AM   #9
Rimefe
Turkey
Drives: BMW 3.20i 2019
Memory function for both mirrors does not work in my car. Do you think there is a solution that I can do myself?
      02-25-2020, 01:03 PM   #10
NoTanks52
Drives: M340i
how do you set the reverse position of the mirror? Just change the setting while in reverse, or is there another way?
      02-25-2020, 01:12 PM   #11
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
442
Is this what you are after? This is for a RHD car it’s the opposite position for LHD.
The switch it refers to is tho switch you use for selecting which mirror you want to adjust.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-28-2020, 12:52 AM   #12
Cosmico72
Drives: X3M Performance
Hi All,
it seems it is not possible to adjust the tilt for the passenger side mirror in reverse gear, but it goes down at much possible... making the function simply useless (unless for me).
Could someone confirm or better... explain how to set a different position (not with 3rd party software).
I have an X3 G01, I think is the same with other recent model.
Thanks a lot.
      05-28-2020, 03:49 AM   #13
Tam the Bam
Grumpy Old Git
442
Originally Posted by Cosmico72 View Post
Hi All,
Thanks a lot.
It can be set using https://bimmercode.app/cars/g20/
There is nothing in iDrive to change this.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      06-04-2020, 09:23 AM   #14
hottroc
Drives: BMW 330e
I don't have mirror memory, but I seem to be having a similar issue....when I put the car in reverse the passenger mirror view drops as it should but when it reverts to normal driving position it doesn't go back to the same position, its too low, and I have to readjust using the control. Not sure if coding can fix this?
