| 10-26-2019, 10:43 AM | #1 |
Rep 1,037
After a couple tries, I finally found a power source that switches off (after around 6-10 minutes).
Disclaimer: I am not responsible for any damage you might cause to your vehicle. Parts used: RJ11 Mirror Wire Tap - I used the smaller tap inserts. BlendMount BMX-2018 (for Escort Max 360) Instructions: Step 1 - Remove the plastic mirror housing. This can be done by using a plastic trim removal tool. I started from the top and slowly separated the trim. Step 2 - Remove the bottom plug. This can be difficult to remove. I had to use the plastic trim removal tool to keep one side of the plug down while pulling on the other side. Be careful while removing it. Step 3 - Insert the wire taps. The red tap (12v) inserts into the red/blue wire plug socket. The black (ground) inserts into the brown/black wire plug socket. Step 4 - Reinstall the bottom plug and hide the wires. I ran the cable out by the mirror stem. Step 5 - Reinstall the plastic mirror housing trim Step 6 - Install BlendMount
24
ProfoundTwitch7.50 A6bullet334.00 Eagle Creek138.00 Calamari263.00 xraymd316.00 cruzer6661238.50 Bmwguy199427.50 Hysnbrg205.50 Banana Clipper354.50 luv2learn22.00 getrusty26.00 Snoopy852.50 MAKH 594.00 superfuel22.50 Ruebarb531.50 aiursblade82.50 Existence71110.50 CSBM53124.00 ehartnet0.00 sfgator105.00 RedMem0.00 tmdals0213227.50 zorrro453.50 JOSE FERREIRA0.00 |
| 10-26-2019, 12:21 PM | #2 |
1058
Rep 4,400
Drives: M340
Exactly what I have done already. Thanks for the write up.
2016 F10 535i xDrive - AW - Retired ![]() 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
| 11-12-2019, 08:01 PM | #4 |
Rep 26
After doing the same, now getting a “Battery Malfunction” check control message. The message stays even when I disconnect the wiring for the RD. Any ideas? I can’t get my Carly to work (either the car or ios13 issue) or would have the code detail as well.
Current: 2024 BMW X5 M60i (G05): Marina Bay Blue / Silverstone
Retired: 2022 X3M Competition (F97), 2021 M3 Competition (G80), 2021 X3 xDrive 30i (G01), 2020 M340i xDrive (G20), 2018 M3 (F80), 2016 428i xDrive (F36), 2007 335i (E90), 2005 325i (E90) Last edited by bblank; 11-14-2019 at 10:00 PM.. |
Stellarxz20.50 |
| 11-14-2019, 07:40 PM | #5 |
Rep 1,037
Sorry, I have not had that issue.
| 11-28-2019, 08:20 AM | #6 |
![]() 35
Rep 132
Rear view mirror housing pics
Thanks tturbolife for post. Thought I'd return the favor and share pics of rear view mirror housing for others to see the clips that need to get undone and pulled apart.
The housing is 2 pieces with clips along the middle that need to be undone. I inserted a screw driver between the headliner and top right area of the housing. Pried gently outwards where after the first clip got undone then used my hands to undo and pull apart the remaining clips. Wasn't very difficult and after taking off the right side housing, I pulled the left side housing off with my hands. Also no need to pull out the wiring harness to put the mirror tap spades in. The rear view mirror itself just slides off. Push the mirror downwards and it will just slide off. Last edited by DEL451; 11-30-2019 at 01:02 PM.. |
| 11-30-2019, 01:41 PM | #7 |
![]() 35
Rep 132
Will also confirm that power does auto shut off after 6 minutes.
Do have issue where laser alarm randomly goes off. Don’t have gesture control. May need to tape rear sensor or turn off laser altogether in V1 setup. To previous post as to warning message after hard wiring - no I did not get. |
tturbolife247.00 Bmwguy199427.50 |
| 12-01-2019, 02:18 PM | #8 | |
Rep 1,037
| 12-02-2019, 09:18 AM | #9 |
![]() ![]() 352
Rep 393
I can also confirm that this works and it shuts off, my mirror housing is huge as I have the assisted driving package but the clips are the same.
I also spliced into the same wire for my USB powered dash cam (because BMW still has not launched the drive recorder for my car). My dashcam is USB powered so I just soldered in a small DCDC converter on that line to go from 12v to 5v and soldered directly into the USB cable.. works perfectly. Also confirmed with a multi meter that: Red/Blue = +12v Brown/Black = Ground This is the DCDC I used: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Current: 2025 G45 X3 M50
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive > 2023 G20 LCI M340i xDrive WE ARE! |
| 12-04-2019, 04:26 PM | #10 |
![]() ![]() ![]() 289
Rep 467
Just bought the escort 360, blendmount, and RJ11 adapter. Going to try this in 2 weeks. Thanks for the write up!
tturbolife247.00 |
| 12-04-2019, 05:41 PM | #11 |
Rep 124
Drives: 2020 BMW M340i
I wonder if this is applicable to a dashcam setup as well.
What's the voltage output at that connector? What's the accepted voltage for the radar device? |
| 12-16-2019, 06:12 PM | #13 |
Rep 28
Thanks much for pulling this info together guys. Wanted to add another success to the thread. Just completed install in my M340.
Also wanted to highlight the suggestion to remove the mirror. This is 100% the way to go but watch out for sudden release or you might unnecessarily strain the wire harness you’re trying to use. Put two hands on the mirror base right up against the windshield and apply gentle, progressive force down the plane of the windshield. There is minimal slack to the wires so as soon as the mirror is free it’s pulling on them. Immediately bring one had around and disconnect. |
tturbolife247.00 |
| 12-16-2019, 07:14 PM | #14 | |
Rep 467
tturbolife247.00 |
| 01-05-2020, 02:44 PM | #15 |
![]() 11
Rep 31
I just did this earlier. Broke a number of those small clips keeping both the left and right pieces of the housing together. Luckily, it all went back together and is holding as if nothing happened.
| 03-19-2020, 09:25 PM | #16 |
Rep 1,207
Drives: 2023 BMW i4 M50
It's a $25 part if you want to replace it[IMG][/IMG][IMG][/IMG]
| 05-25-2020, 04:20 PM | #18 |
Rep 3
Problems with Homelink garage door opener after mirror tap
Has anyone lost homelink functionality after performing the above-described mirror tap for a radar detector? My radar detector is working fine (HT OP!!), but now it looks like my homelink circuit is dead. Any suggestions?
| 05-25-2020, 05:40 PM | #19 |
Rep 1,037
Sorry, I've had no issues with homelink
| 07-14-2020, 04:22 PM | #21 |
Rep 16
I powered it from the lighter, so I could install a hidden microswitch to switch it off sneaky. Here, the use of radar detectors is not allowed:
https://photos.app.goo.gl/sSHE3DRo9RPnvCyu8 https://photos.app.goo.gl/yyESWHc3LqUV8f687 https://photos.app.goo.gl/TCDLye16pyVC1G6D8 |
| 08-13-2020, 02:01 AM | #22 |
Rep 10
Change to mirror housing?
I just picked up my 2020 330i (Late June production) and I was excited to be able to wire my radar but the housing looks different. I do have the drivers assistance professional package but the housing seems to be different. Looking from the headliner to the plastic trim I don't seem a seam to try and use trim tools to pry apart at like others have described. I do see a seam on the smaller rounded black piece but that does not looks like it would expose the wires. Maybe I just am misunderstanding what comes off but from pictures it looks like two pieces which I don't see.
Does anyone have any idea? |
| Bookmarks |
| Thread Tools | |
