12-16-2019, 05:17 PM | #1 |
Rep 30
Ceramic Coating - Yes or No?!? M340
I need some feedback... I'm new to the BMW family. Getting ready to get delivery of the M340, is good idea to do the ceramic coating? I love to have my car clean. Majority of the time the car is cover at home and at work.
Thanks in advance. Ed |
12-16-2019, 08:17 PM | #3 |
Rep 424
I did paint protection film (Xpel ultimate) on the hood, front bumper, front fender door cups and tail gate. Also had ceramic coating on the car. Overall very easy to clean, looks dynamite when freshly cleaned, but you still have to put the work in. Won’t be a simple rinse off every two weeks, but does make a maintenance wash easier. Pricey but I’m glad I did it.
12-20-2019, 01:38 PM | #4 |
Rep 81
Drives: 2020 BMW M340i
I did the ceramic coating on the car and I just do the booster spray when I wash the car, its just so much easier to keep clean and so much easier to clean once its been coated.
12-20-2019, 04:37 PM | #5 |
Rep 75
pmanzonfotos67.00 |
12-22-2019, 06:16 PM | #6 |
936
Rep 4,326
Drives: M340
If your car's paint isn't damaged or if you do not have any swirl marks, ceramic coating is way easier than applying a coat of wax.
It is pricy bec most detailers will have to do a full paint corrections before applying ceramic coating. I did mine in less than 2 hrs but my paint was perfect. Highly recommended as others stated. PS: Use the search function as many of these things have already been discussed! https://g20.bimmerpost.com/forums/sh....php?t=1645510
pmanzonfotos67.00 |
12-23-2019, 04:45 PM | #7 |
Rep 81
I ended up doing it my self, it is time consuming, but once you get it on make sure you let it cure for 24 hours. If I have time, I can take a picture of the difference between a wax vs ceramic. My 330e has the chemical guys butter wax vs. my m340i which has a ceramic.
01-02-2020, 03:44 PM | #8 | |
Rep 30
01-02-2020, 07:04 PM | #9 |
Rep 2,699
Drives: 23 X5MC
01-03-2020, 12:25 AM | #10 |
Rep 170
I operate my own business doing paint correction and ceramic coatings, it's definitely worth the investment if the installer is good, prep is everything, and of course the product, I did my 340 bumper to bumper, wheels, brakes, leather, carpets, windows.
Plus ceramic infused self healing ppf on full front end, skirts. Full back bumper, and more. Feel free to pm me if you have any questions about products, upkeep etc. |
Carib_Sailor17.00 |
02-28-2020, 05:23 PM | #11 |
Rep 307
Do it. Just please don't wrap your car in godforsaken plastic!
Bimmerftw003.00 |
02-28-2020, 07:15 PM | #12 |
Rep 3,959
Are you referring to PPF? If so, what's your issue with it? I have Xpel on my entire front end and the entire car ceramic coated. The Xpel is seamless and you would never know it's there. It's already saved my hood from a few stone chips!
Preciseyyc160.00 |
02-29-2020, 09:27 AM | #13 | |
Rep 1,261
02-29-2020, 09:30 AM | #14 | ||
Rep 170
You should be planning at least a day with an installer for paint correction, Surface prep and then the ceramic installation as well. I typically keep a Car 4 hours after install, but over night when ever I can as you want them to stay dry for minimum 12 hours ideally 24. |
RedKloud736.00 |
02-29-2020, 09:42 AM | #15 | |
Rep 1,261
02-29-2020, 09:46 AM | #16 | ||
Rep 170
For reference my packages are $1000-2000 CAD. Depending what's done. But I'm technically mobile based, so I don't have a shop increasing my operating costs so I can stay on the lower side. Just make sure you read fine print. Lots of prices are coating only and paint correction is on top of that. |
RedKloud736.00 |
02-29-2020, 10:09 AM | #17 | |
Rep 3,959
Preciseyyc160.00 |
02-29-2020, 10:19 AM | #18 | ||
Rep 170
02-29-2020, 11:32 AM | #19 | |
Rep 307
DISCLAIMER: Just my own opinion. Do not be offended. |
02-29-2020, 11:47 AM | #20 | |
Rep 3,959
Preciseyyc160.00 |
02-29-2020, 04:26 PM | #21 | |
Rep 307
02-29-2020, 04:33 PM | #22 |
Rep 3,959
During the winter yes. Much like most of the northern US states, sand/salt is a way of life. You have to adjust when driving behind large trucks or you are basically a firing range of salt pellets and debris. It'll all be over by next month hopefully and on to normal nice conditions
