Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Active Autowerke | M340I Tuned & Catted Downpipe Dyno
      01-29-2020, 10:17 AM   #1
Andrew@ActiveAutowerke
Andrew@ActiveAutowerke's Avatar
1051
Drives: 17 F80 M3 YASSS
BIMMERPOST
     Featured on BIMMERPOST.com
Active Autowerke M340I Dyno
Run 1: AA Catted Downpipe Stock Tune
Run 2: AA Catted Downpipe AA Stage 1+ Tune
Run 3: AA Catted Downpipe AA Stage 2 Tune
*Mustang Dyno Reads +or- 10% of Dynojet numbers*
We have our stage 1 Stage 1+ and stage 2 tune files ready to go. It also includes a flashing cable for the end user to flash at home. Pm me for more info.
      01-29-2020, 11:11 AM   #2
Dima_RUS_M340iX
Russia
Drives: M340iX_2019
Hello.
Very low power rates.
Stage 1 from Mission Performance 460 HP.
https://missiontuning.com/bmw-engine...lash-tune.html
      01-29-2020, 12:02 PM   #3
1051
Originally Posted by Dima_RUS_M340iX View Post
Hello.
Hello,
Your findings and comparison of mission tuning m340 dyno making more power than ours is incorrect. I'll explain.
1. The stage 1 number of 460 you are referencing is crank the actual number on their website is 418 whp on a dyno jet.
2. This Dyno is highlighting how well our Epa catted downpipe works with our tune. For max hp numbers we suggest going with our Cattless Downpipe.
3..They are using a dynojet which reads much higher than a mustang dyno typically 10% to 15% more. We can go with the lower of the two to try and compare as best we can. Giving our tune a peak of 473whp +or - and 507 wtq + Dynojet Estimated.
Max Hp Dyno Estimate
-Active Autowerke Peak Max hp stage 2 473whp and 507 wtq (Epa certified catted downpipe)
-Mission performance Peak Max hp Stage 2 473 whp 485 wtq (cattless downpipe Assumed)
6500 rpm near redline Hp Estimate.
-Active Autowerke Stage 2 @ 6500 Rpm 467 whp & 347 wtq (Catted downpipe with 10% dynojet conversion
-Mission performance stage 2 @ 6500 rpm 440whp & 350 wtq (cattless downpipe Assumed)
Appreciate 16
VipinLJ187.00
SAMM3Y1278.00
65lim13.50
VCP1200.00
spuntyb1262.50
jdg5460.00
M-Pilot4404.50
maxnix205.00
F85MTuNED456.50
otay679.50
      01-29-2020, 12:09 PM   #4
john!smith
john!smith's Avatar
127
Drives: M340i XDrive
hi and thank you for the dynochart. i have one question, shouldnt the run be in 5th gear? when i understand correct you did in 4th gear?
      01-29-2020, 12:12 PM   #5
Dima_RUS_M340iX
Russia
Drives: M340iX_2019
Read.
I need time to digest the information)
      01-29-2020, 12:38 PM   #6
PunkSinatra
Switzerland
11
Drives: M340i
Hello,
1. The stage 1 number of 460 you are referencing is crank the actual numberon their website is 418 whp on a dyno jet.
Thank you for the precise explanation of your tune.
Very similar numbers, but i'm quite shure mission performance numbers are with stock downpipe.
But very good numbers from your tune.
Can you guys remote flash the latest bmw anti-flash software?
      01-29-2020, 12:41 PM   #7
john!smith
john!smith's Avatar
127
mission was with vrsf downpipe
      01-29-2020, 12:45 PM   #8
PunkSinatra
Switzerland
11
Drives: M340i
Here you go.
Stock hardware, no vrsf downpipe.
Just a tune and 93 gas.
Last edited by PunkSinatra; 01-29-2020 at 01:28 PM.. Reason: False when writing 91 cali gas with e85 mix insted of the correct 93 gas.
      01-29-2020, 12:55 PM   #9
john!smith
john!smith's Avatar
127
oh sorry, i saw a user post with vrsf thats why i was wrong
      01-29-2020, 01:16 PM   #10
1051
Their website says 93 octane and the insta post says e85 mix not apples to apples.... Not sure why you would tune for stage 2 on a stock downpipe but either way they should have better descriptions.
When creating the tune for m340i our goal was to create a safe, reliable and smooth curve to redline. I think we have succeeded on all of those points.
Here is a dyno for fun m340 vs stock m4 6 speed. A fbo M4 makes 477whp on our dyno.
dezzracer391.00
      01-29-2020, 02:16 PM   #11
jstnstr
jstnstr's Avatar
Drives: M340i xDrive for PCD 4/3
It says on your site "OBD Flashing Option" can you provide some more detail into what that means? Is it available on all ECU software versions and updates? Or is bench flashing required first?
On order: 20 M340i xDrive | Now: 16 GTI | Then: 18 M3 ZCP / 17 M3 6MT / 15 M235i
      01-29-2020, 02:29 PM   #12
chenry
Drives: BostonWhaler,340+18 BMWs sofar
Sorry if I missed it but what fuel were you running for these results - thanks!
      01-29-2020, 02:51 PM   #13
1051
93 octane from the pump.
      01-29-2020, 02:59 PM   #14
1051
Yes of course. We flash this model with a Enet cable. We will send you one or if you already have one or want to purchase one from Amazon we will credit you $20 bucks.
From their you just need a laptop running windows and we will send your custom file to you once give us your software version .
      01-29-2020, 03:08 PM   #15
1051
Good question! We always attempt to use 5th gear but in this case since we have a loaded mustang dyno the run time was just way to long. 5th gear does typically produce higher numbers just an fyi.
      01-29-2020, 03:11 PM   #16
chenry
cool thanks :-)
so to provide a CliffsNotes version for everyone of the results using your info (Max) I am seeing the following (please tell me if I'm reading the results wrong in that i'm mobile and text is small) are these deltas correct?
  • 93 octane
  • AA catted downpipe
  • Stage 1 vs stock: +46HP & +73 Ft-LB
  • Stage 2 vs stock: +58HP & +86 Ft-Lb
Last edited by chenry; 01-29-2020 at 03:11 PM.. Reason: replaced a 0 with a o - it was a typo
      01-29-2020, 05:06 PM   #17
1051
cool thanks :-)
  • 93 octane
Not exactly because we dont have a 100% stock run. All runs were done with our high flow catted downpipe. The only variable being the tune.
Also above is a stage 1+ file or 1.5 what ever you wish to use. We do have a stage 1 file that we use for completely stock cars as well which will be a little less aggressive.
      01-29-2020, 05:13 PM   #18
john!smith
john!smith's Avatar
127
i really would like to know the numbers with our good ol 100/102 octane petrol here in germany
i think you can add easily 25+ hp on top
      01-29-2020, 05:48 PM   #19
nola2atx
nola2atx's Avatar
Why not? I'd like to see tune without since I'm unlikely to modify the down pipe on a leased car...
///M340i Portimão
My Exes:
E36, E46, F30
      01-29-2020, 05:54 PM   #20
chenry
okay got it thanks for the clarification that makes sense - so the delta's are correct - but the baseline (represented by "1" on your dyno chart) would be a stock car with an AA catted downpipe vs a 100% stock car.
      01-29-2020, 06:10 PM   #21
nola2atx
nola2atx's Avatar
Also, how are the different modes affected? (Comfort, eco, etc.)
///M340i Portimão
My Exes:
E36, E46, F30
      01-29-2020, 10:44 PM   #22
oreoOozZz
oreoOozZz's Avatar
31
Drives: 2020 BSM M340i xDrive
Does remote start and launch control work with your tune? Do you need to do the key card trick?
Copyright ©2000 - 2020, vBulletin Solutions Inc.
