Technical Topics DIYs and Coding Discussions added wireless charging tray and coding for phone reminder
      05-06-2020, 12:54 AM   #67
minakoto00
minakoto00's Avatar
Drives: G20 330i xDrive Luxury Line
Originally Posted by pneumodoc View Post
I coded WCA to active and the reminder setting shows up in idrive, however whenever I left my phone in the charging tray as i turned off the car, it didn't warn me...so not sure if I did something wrong.
Originally Posted by Fpangalos View Post
Wca to active in mgu for the display portion but one more code is needed in kombi to activate the sound side. Reached out to Greeks and waiting for a response to hear what he coded in kombi using esys, might point me in the right direction...
Guys I found a post here https://cartechnology.co.uk/archive/...ead-63755.html.
It seems that these are all the FDL coding parameters to enable enhanced BT and phone reminder on G30. But I'm not sure what those options are on G20. I'm seriously thinking of starting learning Esys and it seems a lot more easier when you just need to code the FA....
Disclaimer: Don't try those options since those are unverified on G20 and it may mess up some security features etc.
      05-12-2020, 02:18 PM   #68
minakoto00
minakoto00's Avatar
I received the charging tray today and tried to install it. And I have a stupid question.
After removing the cupholder, the plug on the NFC pad seems to be extremely hard to remove, I tried to pull very hard but cannot get it unplugged. This process in the video on youtube seems to be nothing but directly unplug it.
Does anyone have ideas of how to properly unplug that? Thanks in advance.
Edit: I'm not sure if there is any locking mechanism on the plug, and I did try to use the screwdriver to stick and hold into the little hole at the bottom of the plug base though I didn't push it too hard in case of damaging happens.
      05-13-2020, 01:30 PM   #69
minakoto00
minakoto00's Avatar
I may sound a little silly but I finally got the wireless charging pad installed on my second try.
it seems that the plug on the NFC pad got no locking mech, many thanks to Fpangalos for the info!
If anyone feels it's hard to remove that final plug (it is for me), a screwdriver may help a lot as you could pry the plug up by levering the edge with it. Holding your finger at the other side of the plug could prevent uneven force being applied to 2 sides of the plug and making it easier to come out.
Like this:
Appreciate 7
greekcs773.00
37b86.00
VipinLJ1941.50
ssgm1x418.50
XXXcdi0.00
      05-13-2020, 01:32 PM   #70
Fpangalos
Fpangalos's Avatar
Drives: 2019 BMW 330i
Like this:
Nice! Glad you got it! I like the diagram
#pinchhardandpull
      05-13-2020, 01:49 PM   #71
minakoto00
minakoto00's Avatar
#pinchhardandpull
Hoping it would help ppl with similar issues, but I would say that plug is damn solid lol.
      05-13-2020, 02:25 PM   #72
hottroc
Drives: BMW 330e
At least you got a plug! Where do you get a plug if you don't currently have the NFC pad?
      05-13-2020, 03:23 PM   #73
possible335i2008
Drives: 335i
Did anyone get the nfc pad working too?
      05-13-2020, 05:24 PM   #74
Fpangalos
Fpangalos's Avatar
My NFC works just as before
      05-14-2020, 07:27 PM   #75
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
NFC should work just as before.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      05-14-2020, 09:34 PM   #76
minakoto00
minakoto00's Avatar
Mine NFC also works as before.
Hi greekcs, I have a question for coding with Esys. I'm a noob on this but I was trying to set up all those software recently according to the listing mentioned in the Esys thread. I didn't hear back from tokenMaster for the Launcher Pro licensing. For the VO coding part (for this case adding 6NW and coding HU_MGU and KOMBI) is it necessary to use Launcher Pro or it could be done w/o it?
Sorry if this has been asked in some other threads. Thank you so much!
37b86.00
      05-15-2020, 06:33 PM   #77
minakoto00
minakoto00's Avatar
Ah. After some experimenting, I finally got the phone reminder to work.
My work computer crashed this afternoon so I turned to chill out and play around with bimmercode during my computer reinstalling the software.
To enable both display option and audio/visual reminder in the gauge cluster, code the following params,
1. BDC -> WcaWirelessChargingAblage-> WCA_ENABLE -> aktiv
2. HU_MGU -> 3000 HMI_SPEECH -> WCA -> aktiv
Then I tested it by turning off engine and pull the door handle, both sound and the popup appeared.
I didn't try to enable the EBT though, looks like bimmercode has not support coding for Bluetooth module on G20 yet.
greekcs773.00
37b86.00
VipinLJ1941.50
zanicwb12.00
      05-16-2020, 05:17 PM   #78
pneumodoc
pneumodoc's Avatar
235
Drives: G20, G01
This worked! Thank you!
      05-16-2020, 05:23 PM   #79
minakoto00
minakoto00's Avatar
Glad this helped! Enjoy!
pneumodoc235.00
greekcs773.00
Osheatwo206.50
      07-03-2020, 01:50 AM   #80
helmet91
helmet91's Avatar
Netherlands
298
Is there a comprehensive list of part number revisions?
Any idea what the most recent number is?
Thanks!
      07-07-2020, 10:06 AM   #81
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
Thanks!
84 10 8 722 754 oldest
84 10 8 707 868 older
84 10 8 729 771 old
84 10 9 437 712 old
84 10 9 434 000 New is the most current
helmet91297.50
lemos19.50
      07-07-2020, 01:03 PM   #82
helmet91
helmet91's Avatar
Netherlands
298
84 10 8 729 771 old
84 10 9 437 712 old
Great, thanks!
Looks like I can get one for around $200... or a bit less if I order a few more things to be able to file a VAT refund claim.
It will be a good purchase because my iPhone8's battery is getting wrecked.
      07-07-2020, 01:15 PM   #83
mikeyb74
mikeyb74's Avatar
Great, thanks!
No problem! Always out to help others. I want to do this retrofit in my G20 as well.
      07-07-2020, 01:23 PM   #84
hottroc
Drives: BMW 330e
I bought one off eBay to retrofit, but I'm having a real job trying to find a connector/connecting cable.
Seems to be part no 616033 shown here:
      07-17-2020, 08:10 PM   #85
AtticusHoy
I wasn't able to activate my NFC key card for the first time using the retrofitted wireless charger, so I reinstalled the default NFC plate and activated the NFC key card. After activating the NFC key card, I reinstalled the wireless charger and verified that the NFC key card still worked to unlock the car and start the car. Kinda strange but whatever.
greekcs773.00
      07-25-2020, 08:19 PM   #86
NTOwens
Drives: 2022 X5 M50i
I have a Samsung Note 10 Plus.
Your Note 10± fits okay in the wireless charger? Do you have any kind of case on it? I have a reasonably slim Spigen case, but I'm worried it might not fit.
      07-26-2020, 10:41 AM   #87
greekcs
greekcs's Avatar
I have the Spigen Ultra Hybrid S Case on my Note 10 +; Fits well on the charger with very little wiggle room.
      07-27-2020, 08:50 PM   #88
gaushell
Drives: 2023 G20 330i Black
bought my 84-10-9-434-000, from getBMWparts.com - installed during lunch today. Was pretty easy - except for disconnecting and reconnecting the usb power to the cup holder to make it easy to swap charger with nfc pad. works great!! thanks for all of the info!
