04-04-2020, 04:51 PM | #45 | ||
Rep 62
Drives: 2019 330i XDrive
04-04-2020, 05:02 PM | #46 |
1945
Rep 3,521
MGU expert coding is available on android bimmercode beta as of today
youthsonic40.00 |
04-05-2020, 09:14 AM | #47 | ||
Rep 1,426
04-05-2020, 10:05 AM | #48 |
1945
Rep 3,521
Make the change below for comfort plus on iDrive
04-05-2020, 02:22 PM | #49 |
1945
Rep 3,521
I found AKT_Auto and IKF_ENABLE. I couldn’t find LHZ_CCM under any of the sub modules. I activated the two I found. It brought up the option on the iDrive but I couldn’t select the option or set the temperature probably because I couldn’t activate LHZ. I probably missed it but I don’t mind as of now since it’ll be spring and then summer and I won’t need heated steering
04-05-2020, 03:00 PM | #50 |
Rep 328
How'd u code the M logo at the top of the instrument cluster?
04-05-2020, 03:02 PM | #51 | |
Rep 3
VipinLJ1944.50 |
04-05-2020, 03:24 PM | #52 | |
Rep 9
04-05-2020, 04:16 PM | #53 |
1945
Rep 3,521
I’ll check that out tomorrow. Thank you very much for the info!
04-05-2020, 06:01 PM | #54 |
Rep 299
Yeah I found it under BDC Expert mode, it should be there. I can confirm that once enabling, auto steering wheel heat will function as expected.
I'll post a screenshot of mine as soon as I get a chance Update: Can confirm that LHZ is in BDC, maybe it isnt on android? Last edited by JSaid; 04-05-2020 at 06:53 PM.. |
VipinLJ1944.50 |
04-05-2020, 07:37 PM | #55 | |
1945
Rep 3,521
The problem is that in android, you can’t search from the main expert coding page. You have to open each sub module and then search there. There were like a hundred sub modules under the two modules and it got the better of me. I’ll check it out again tomorrow and update my findings on here
04-05-2020, 09:50 PM | #56 |
Eleet Tech
183
Rep 295
04-05-2020, 11:36 PM | #58 | |
1945
Rep 3,521
PS - That’s how I did it when I removed the logo from the top when I coded in the alpina cluster. I’m assuming it should be the same to code in a logo.
04-05-2020, 11:44 PM | #59 | |
Rep 299
VipinLJ1944.50 |
04-05-2020, 11:50 PM | #60 |
1945
Rep 3,521
Damn. I was hoping that would work. When I coded the alpina layout, I changed the global layout variant option too. But since you guys don’t want that (and want the stock layout), I didn’t mention that. I’ll take a look tomorrow and see if I can code in the M logo. I’ll report back once I’ve found something new.
04-05-2020, 11:54 PM | #61 | |
Rep 299
VipinLJ1944.50 |
04-06-2020, 04:33 AM | #62 | |
Rep 6
I've not tryed to change layout to M or Alpine due to different scale issue... :-( |
04-06-2020, 04:46 AM | #63 |
Rep 6
Anyone knows how to scale the M instrument to the „normal" scale?
i would like to have M but not with the scale, or is it possible to code the normal Sport cluster to every mode like adaptiv? |
04-06-2020, 03:58 PM | #64 | ||
1945
Rep 3,521
To remove the speed correction, follow what JSaid has mentioned below.
04-06-2020, 03:58 PM | #65 |
1945
Rep 3,521
That worked. I was able to code it all in today and make auto steering heat work. Thank you very much!
04-06-2020, 07:12 PM | #66 |
Rep 7
Coding sport plus
I successfully coded sport plus on my car, while browsing in the FES menu I saw two more options with the names; 1.SPORT_CONF_STEERING_SPORTPLUS
2. SPORT_CONF_ATTENUATION_SPORTPLUS Does anyone know what those two options are for? |
