2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Favour needed, picture of SOS speaker/wiring
      04-01-2020, 07:50 AM   #1
Alanli722
Drives: G20 M340i
When installing my dashcam I took off the cover just above the pedals to gain access to the fusebox. As it was 2am in my cold garage I couldn't get the cover l connector off the SOS speaker in the panel with my fingers so tried using some needle nose pliers, I ended up being the connector plug.
I've got a new connector now but need to find out which wire goes on which side of the 2 pin connector (one white and one white with blue stripe wire).
Would anyone be kind enough to take a picture of the wiring for me or if possible take a picture of the plug. On the plug there's a number 1 and 2 for the pins for each wire.
To take the panel off its just 2 thumb screws/latches to the remove the panel. Then just pull the panel down and out, there is a clip on the wiring loom that is attached to the panel which can be just prised off and unclipped for some slack (see pics).
Any help would be greatly appreciated and thanks in advance.
      04-01-2020, 09:03 AM   #2
hamera
hamera's Avatar
442
Drives: 320i M Sport (G20)
      04-01-2020, 09:05 AM   #3
Alanli722
Drives: G20 M340i
Originally Posted by hamera View Post
Thanks very much! Can get rid of the message in the dash now
