VRSF Charge Pipe Upgrade Kit for your 2016+ F & G Series
120i, 125i, 220i, 230i, 320i, 330i, 420i, 430i, 520i, 530i, 630i, 730i, X3 20i, X3 30i, X4 20i, X4 30i, X5 30i, X6 30i & Z4 30i BMW with the B46 & B48 engine.
Increase throttle response and decreases turbo lag with the VRSF Charge Pipe Upgrade for your F or G Series BMW with a B46 & B48 engine. Please refer to the chart below for exact fitment. Every VRSF Charge Pipe is constructed from mandrel bent, T6061 grade aluminum including the flanges. Each flange is precision machined from CNC billet aluminum, including the throttle body, intercooler and vacuum connections. After these are welded, theyre test fitted on multiple jigs in order to ensure proper fitment and a reliable, leak free connection.
Each VRSF charge pipe is finished in a durable wrinkle black powder coated finish that blends in perfectly with the engine bay. We also include two plugged 1/8″ NPT bung that can be used for methanol injection, boost leak testing or as a boost source. The OEM charge pipe is prone to failure at both stock and tuned boost levels which is why we include everything necessary to replace your flimsy OEM chargepipe including high quality, 4-ply silicone couplers as well as stainless steel t-bolt clamps.
Additionally, we offer and recommend replacement throttle body c-clips and o-rings in case your original clip and gasket are lost or worn.
Features:- Increase throttle response and decreases turbo lag.
- Durable wrinkle black powder coated finish.
- 4 ply silicone connectors & stainless steel t-bolt clamps included.
- Constructed from T6061 tig welded aluminum.
- Includes two 1/8″ NPT bungs for meth/water injection.
- Throttle body matched mandrel bent piping.
- Billet precision machined CNC flanges for a leak-free connection.
- Includes everything necessary to upgrade from factory charge pipe.
- Lifetime warranty.
- OEM BMW Part Number: 13718601683
This item fits the following BMWs:- 2018+ G20 BMW 320i (B46 & B48 Engine)
- 2018+ G20 BMW 330i & 330iX (B46 & B48 Engine)
- 2018+ G20 BMW 330e & 330e iX (B46 & B48 Engine)
- 2018+ G21 BMW 330i & 330i iX Touring (B46 & B48 Engine)
- 2016 2020 F20 & F21 BMW 120i (B46 & B48 Engine)
- 2016 2020 F20 & F21 BMW 125i (B46 & B48 Engine)
- 2015 2020 F22 BMW 220i (B46 & B48 Engine)
- 2015 2020 F22 BMW 230i & 230iX (B46 & B48 Engine)
- 2016 2020 F23 BMW 220i Convertible (B46 & B48 Engine)
- 2016 2020 F23 BMW 230iX Convertible (B46 & B48 Engine)
- 2015 2020 F30 BMW 320i & 320iX (B46 & B48 Engine)
- 2015 2020 F30 BMW 330e & 330e iX (B46 & B48 Engine)
- 2015 2020 F30 BMW 330i & 330iX (B46 & B48 Engine)
- 2015 2020 F31 BMW 320i & 320iX Touring (B46 & B48 Engine)
- 2015 2020 F34 BMW 330i & 330iX Touring (B46 & B48 Engine)
- 2015 2020 F34 BMW 320i & 320iX Gran Turismo (B46 & B48 Engine)
- 2015 2020 F34 BMW 330i & 330iX Gran Turismo (B46 & B48 Engine)
- 2015 2020 F32 BMW 420i & 420iX (B46 & B48 Engine)
- 2015 2020 F32 BMW 430i & 430iX (B46 & B48 Engine)
- 2015 2020 F33 BMW 420i Convertible (B46 & B48 Engine)
- 2015 2020 F33 BMW 430i & 430iX Convertible (B46 & B48 Engine)
- 2016 2020 F36 BMW 420i & 420iX Gran Coupe (B46 & B48 Engine)
- 2016 2020 F36 BMW 430i & 430iX Gran Coupe (B46 & B48 Engine)
- 2016+ G30 BMW 520i & 520iX (B46 & B48 Engine)
- 2016+ G30 BMW 530e & 530eX (B46 & B48 Engine)
- 2016+ G30 BMW 530i & 530iX (B46 & B48 Engine)
- 2016+ G31 BMW 520i & 520iX Touring (B46 & B48 Engine)
- 2016+ G31 BMW 530i & 530iX Touring (B46 & B48 Engine)
- 2016+ G32 BMW 630i Gran Turismo (B46 & B48 Engine)
- 2016+ G11 BMW 730i (B46 & B48 Engine)
- 2016+ G11 BMW 740e (B46 & B48 Engine)
- 2016+ G12 BMW 730i (B46 & B48 Engine)
- 2016+ G12 BMW 740eX, 740Le, & 740LeX (B46 & B48 Engine)
- 2017+ G01 BMW X3 20i & 20iX (B46 & B48 Engine)
- 2017+ G01 BMW X3 30eX (B46 & B48 Engine)
- 2017+ G01 BMW X3 30i & 30iX (B46 & B48 Engine)
- 2017+ G02 BMW X4 20iX (B46 & B48 Engine)
- 2017+ G02 BMW X4 30iX (B46 & B48 Engine)
- 2018 2020 G05 BMW X5 30iX (B46 & B48 Engine)
- 2018 2020 G06 BMW X6 30iX (B46 & B48 Engine)
- 2018 2020 G29 BMW Z4 20iX (B46 & B48 Engine)
- 2018 2020 G29 BMW Z4 30iX (B46 & B48 Engine)
