Technical Topics DIYs and Coding Discussions RDC widget on 6U3 live cockpit professional
      04-22-2020, 07:59 AM   #1
igorbutarev
igorbutarev's Avatar
Russia
Drives: F30 320i G20 320d
Hi. Has someone knows the parameter in DKOMBI4 to code this ?
      04-22-2020, 01:13 PM   #2
Alex2020g20
Alex2020g20's Avatar
Drives: 2020 BMW 330i M-Sport
I would love to find out too, that looks awesome!
      04-23-2020, 06:32 AM   #3
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
Is this widget displaying tire pressure & temperature of all tires -- sorry, I can't read Cyrillic?
Thanks
Al
Retired: 2014 328i
BMW CCA
      04-23-2020, 06:33 AM   #4
phillyd2
Drives: 2020 M340i XDrive
Nyet
      04-23-2020, 10:45 AM   #5
igorbutarev
Russia
Hi,
Thanks
Yes
      04-23-2020, 10:47 AM   #6
tommytexter
tommytexter's Avatar
Drives: 2020 M340ix
What to know too!! Possible to code M8 track mode gauge too?
      04-24-2020, 05:29 AM   #7
sddz6269
China
42
Drives: BMW G20 325i
I checked his instagram and asked him if this could be coded on G20 330i and he said yes. But still dunno how to do that.
      05-04-2020, 09:59 AM   #8
Rastlein
Drives: BMW 320i
Has anyone been able to encode this with Bimmercode? I've also seen a widget with turbo pressure, oil temperature, etc. I would be interested to know how to code it too.
Andy3661129.50
      05-04-2020, 03:33 PM   #9
victordura
330i M
victordura's Avatar
Spain
Drives: 330i M
Hi! I have coded it but only partially. Display only shows temp and pressure but not the car with green tires.
I can’t remember which parameter is in bimmercode but I will try to remember or search for it on weekend.
VD
      05-04-2020, 10:29 PM   #10
sddz6269
China
42
VD
That would be great. But how did you find how to code that then?
      05-05-2020, 01:23 AM   #11
victordura
330i M
victordura's Avatar
Spain
Drives: 330i M
I modified some parameters of the Instrument Cluster module that seemed interesting because the name. I think the RDC widget involves two lines of coding because the car image is missing in mine.
If O find some time I will try to find out the other line and remember the one I modified.
I will write it here.
VD
VipinLJ1982.00
RSnic708.00
      05-07-2020, 10:22 AM   #12
RSnic
RSnic's Avatar
VD
@victordura ,
Using E-Sys, I just scoured DKOMBI4 CAFD (Instrument Panel) for anything with RDC, Reifen (tire) Druck, Safefy & RDC_Safety and unfortunately came up dry
Do you recall what function you changed?
Thanks
Al
Retired: 2014 328i
BMW CCA
      05-07-2020, 05:37 PM   #13
victordura
330i M
victordura's Avatar
Spain
Drives: 330i M
@victordura ,
Thanks
Not yet! I haven’t got any time this week. I hope to be able to check it again on weekend.
I will find it again for sure. I hope, because I need to remove 2 widgets that appeared after coding another to lines but don’t work properly.
One is turbo pressure and water temp.
The second widget I have to get rid of is M widget for steering, brakes and engine configuration.
VD
      05-08-2020, 03:26 AM   #14
Ibo24
New BMW owner
Ibo24's Avatar
Drives: BMW 316d, BMW F40 116d
If you can, can you send me the ncd file of the dkomb so I can search for it to?
Haven’t had a G20 yet to code. So it will help allot to search actively to!
      05-08-2020, 06:05 AM   #15
Rastlein
Drives: BMW 320i
VD
Haven't you seen any widget to show the oil temperature? It would be great.
Thank you!
      05-08-2020, 07:02 AM   #16
MY86
MY86's Avatar
Turkey
17
Drives: G30 520i G20 320i
Unhappy
VD
Hi,
Do you also have any idea about how to enable the G- Meter widget on the live cockpit and the ID 7 ?
Could you also take a look on that?
My car did not come with this widget enabled from the factory
      05-09-2020, 01:53 PM   #17
RSnic
RSnic's Avatar
Hi,
Went exploring through DKOMBI4 with Bimmercode in Expert mode and ran across CB_WIDGET_GWSZ_TWSZ, under Configuration function & it was not active
Anyone have any idea what this is? Is this the tire pressure & temperature widget?
Thanks
Al
Retired: 2014 328i
BMW CCA
      05-09-2020, 09:30 PM   #18
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [10.00]
Hi,
Thanks
I'll test later but that might be it, thanks for that, I will confirm if it works
      05-10-2020, 02:27 AM   #19
igorbutarev
Russia
Hi,
Thanks
Now checked it. Don't work(( I will continue finding solution
      05-10-2020, 07:03 AM   #20
sddz6269
China
42
Hi,
Thanks
I coded every item that contains "WIDGET" into "aktiv" but nothing seemed to change
VipinLJ1982.00
      05-10-2020, 03:07 PM   #21
RSnic
RSnic's Avatar
Hi,
Thanks
Well, thanks to Stephan from Bimmercode for the following: GWSZ is “Gesamtwegstreckenzähler” and this is “total distance counter” in english.
Therefore, what I thought was a good lead is a not
Sorry!
Al
Retired: 2014 328i
BMW CCA
      05-12-2020, 05:00 AM   #22
sddz6269
China
42
VD
victordura Hi, do you remember if these parameters contain similar elements, like, do they all start with "CB" or something like that. Muchas gracias!
