2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions G22 4 Series Coupe First Technical Specs and Preproduction Drive Reviews
      04-28-2020, 06:33 PM   #1
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
BIMMERPOST
     Featured on BIMMERPOST.com
BMW Press Release:
Close to the finish line – and to home: new BMW 4 Series Coupe enters final phase of dynamic testing
April 29, 2020
Munich. The concept of sporty driving pleasure in the premium midsize segment is being redefined and will soon be available to experience in the new BMW 4 Series Coupe. Following a series of exhaustive test drives held as part of the development process to prepare it for series production, the latest incarnation of the two-door model is now embarking on the final phase of dynamic testing. After having their driving qualities honed at the winter testing centre in Arjeplog, Sweden, at the BMW Group’s test centre in Miramas in France, on the Nürburgring’s Nordschleife circuit and at various other race tracks, the prototypes are now returning to their roots: engineers will put the final touches to the chassis technology of the new BMW 4 Series Coupe on the motorways and country roads around the BMW Group’s Research and Innovation Centre (FIZ) in Munich.
Like its overall vehicle concept and design, the 4 Series Coupe’s chassis technology is a more individual composition than ever before. The proportions, aerodynamic properties and weight distribution of the two-door car provide the ideal basis for a chassis set-up focussed unerringly on exhilarating dynamic performance. A direct comparison with the new BMW 3 Series Sedan highlights the new model’s unique profile particularly clearly. The sedan’s impressive drag coefficient, for example, is undercut by 0.015. Plus, the new BMW 4 Series Coupe is 57 millimetres lower than its four-door counterpart and its centre of gravity is 21 millimetres closer to the road as a result.
This all combines with the increased negative camber at the front wheels and the 23-millimetre wider rear track to sharpen the car’s handling characteristics by a significant degree. The sports sedan already boasts extraordinary dynamism, but the new BMW 4 Series Coupe raises agility and lateral acceleration by a sizable margin again.
The development team for the new BMW 4 Series Coupe also took a model-specific approach to incorporating the chassis technology and connecting the suspension to the body. The fruits of their labours will launch the new two-door model straight to the top of its segment in terms of sporting prowess and the driving experience. At the same time, the double-joint spring strut front axle / five-link rear axle configuration means the dialling up of dynamic performance doesn’t come at the expense of excellent comfort on everyday drives and long journeys. Lift-related dampers – which made their debut in the new BMW 3 Series Sedan and offer continuously variable, progressive damping control as a function of spring travel – have been tuned for an even sportier drive. Custom-made tower-to-front end struts and an additional shear panel on the bulkhead optimise steering precision and response, while bracing elements have been added around the rear axle to increase stiffness for improved straightline stability and lateral acceleration.
The model line-up provides another indication of the new BMW 4 Series Coupe’s unwavering commitment to class-leading driving dynamics. The range will now be spearheaded by a BMW M model in the shape of the new BMW M440i xDrive Coupe. Powered by a potent straight-six engine delivering maximum output of 275 kW/374 hp, it will also feature 48V mild-hybrid technology, with a 48V starter-generator and a second battery employed to both ease the load on the engine and act in unison with it. Besides improved efficiency, the principal benefit here is punchier power development when the driver hits the accelerator hard. The additional 8 kW/11 hp generated by the electric boost effect underpins lightning-fast off-the-line getaways and in-gear sprints. The engine’s stunning power delivery, the standalone vehicle concept and the optimised chassis technology’s model-specific configuration combine to endow the BMW M440i xDrive Coupe with outstanding performance credentials. Harnessing the race track expertise of BMW M GmbH, the various elements have been woven together into an overall package of supreme handling agility, precision and poise.
The power generated by the engine in the new BMW M440i xDrive Coupe is channelled to the road via an eight-speed Steptronic Sport transmission and the car’s intelligent all-wheel-drive system. The M Sport differential is also on hand to make sure that drive power is deployed to optimum effect in demanding driving situations. The locking effect generated by an electric motor limits speed equalisation between the inside and outside rear wheel when cornering, thereby enhancing traction and handling stability while enabling the driver to power out of bends with considerable dynamic verve. The custom-tuned chassis elastokinematics, exceptionally powerful M Sport brakes and 18-inch M light-alloy wheels with mixed-size tyres are likewise contributory factors in the precisely controllable dynamics of the new BMW M440i xDrive Coupe.
The final round of testing on the car’s home ground will allow the engineers to fast-track their latest findings into the fine-tuning process at the Research and Innovation Centre. The focus here is on ensuring that the dynamic performance attributes of the new BMW 4 Series Coupe crafted on race circuits can also be experienced in normal driving conditions on public roads. Whether darting along winding country routes around Munich or constantly switching between motorway and urban traffic, the new BMW M440i xDrive Coupe epitomises how the unequivocally sporty design of the body and chassis, the bespoke set-up of the steering, brakes and all-wheel-drive system, the pinpoint feedback from the dampers and the precise interventions of the chassis control systems together serve up driving pleasure that thrills and delights – day in, day out.
BMW G22 4 Series Coupe Prototype Official Photos
Car And Driver
https://www.caranddriver.com/reviews...ototype-drive/
Motor 1
https://www.motor1.com/reviews/41892...-drive-review/
Autocar
https://www.autocar.co.uk/car-news/n...ries-prototype
Autoexpress
https://www.autoexpress.co.uk/bmw/4-...ototype-review
Bimmer Today Translated
https://translate.google.com/transla...s-skalpells%2F
      04-28-2020, 06:35 PM   #2
DocWeatherington
Drives: F90 CP
Looks promising....
Bring on the M4... please
      04-28-2020, 06:55 PM   #3
stein_325i
Blocked from G80/G82 for having an opinion
stein_325i's Avatar
Drives: BMW/Mercedes-Benz
Ouch...
"Because, while the M440i passes all of our dynamic tests with flying colors, it can't shake a certain synthetic quality.
It also feels more jittery and nervous, and not everyone (myself included) is a huge fan of that feeling.
The steering isn't the best in terms of feel at hand, it's still a bit heavy and rubbery, but it responds well to what's happening underneath you. That works."
That Motor1 review wasn't particularly glowing, and the 4er's design could kill all hope of this car no matter how good it is for many including myself.
Daily: 2019 Mercedes-Benz CLS 53 Weekend: 2008 BMW Z4 M Wife's: 2020 Mercedes-Benz GLC 300
Retired:1995 E36 325i 5MT / 2004 E46 330i 6MT / 2011 E90 335xi / 2017 G30 540i / 2017 982 Boxster S 6MT / 2019 F87 M2C 6MT
Nomana1288.50
Pinkoboe212.00
      04-28-2020, 07:01 PM   #4
DocWeatherington
Drives: F90 CP
Originally Posted by jstein55 View Post
Ouch...
Yeah, I think in time.... steering is a line of code... the question is will BMW fix it. Also, this is not a full-on "M4" so I expect something to be left on the table for the M, M Comp, and the CSL or whatever the top tier is called.
The design is TBD... I am going to pass judgment once photos and it can bee seen in the flesh.
cfm56d7b2646.00
      04-28-2020, 07:05 PM   #5
stein_325i
stein_325i's Avatar
Originally Posted by DocWeatherington View Post
question is will BMW fix it?
Sadly, I'm 100% confident the answer to that question will be no. BMW has had 10 years to fix their EPS, and have yet to do it.
Appreciate 6
      04-28-2020, 07:08 PM   #6
solstice
Drives: 2015 M3 6MT
Ouch...
Car and driver must have been more active at the bar after the event
“there will likely be some cross-shopping with the Porsche Cayman and 911. If you are interested in any of those, the new BMW 4-series will deserve a very close look.”
Back in the real world it sounds like a good platform for the M4 with the already Increased ALU use, wide track and low cog. Nevermind that C&D drunk talk
stein_325i9020.50
AlexFL4765.00
JTO242967.00
clee1982734.50
      04-28-2020, 07:17 PM   #7
stein_325i
stein_325i's Avatar
Ouch...
"there will likely be some cross-shopping with the Porsche Cayman and 911. If you are interested in any of those, the new BMW 4-series will deserve a very close look."
If there's one thing I've learned with C/D its to never trust their press drives. They are always extremely positive and never look at the negatives. Once they get the cars in their own hands for a review they tell it how it really is. Just look at the difference in F30 and G30 press drives and then instrument tests/reviews, they go from glowing to critical.
Fuller1212.50
clee1982734.50
Germanauto5684.00
      04-28-2020, 07:23 PM   #8
DocWeatherington
Drives: F90 CP
Haha, unless they know something we don't.... then again when your drunk a 1 is 10
stein_325i9020.50
solstice3457.00
      04-28-2020, 07:24 PM   #9
DocWeatherington
Drives: F90 CP
Haha probably sober
stein_325i9020.50
      04-28-2020, 07:46 PM   #10
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
"You wouldn't say the second-generation coupe offers a night-and-day contrast to the driving experience in the 3 Series. But at the point where its sedan sibling slowly but surely pulls down the curtain, the 4 Series continues to sing a little while longer."
Sounds promising, if its actually stiffer and more dynamic than the already rigid G20.
Too bad it has a face only a BMW designer could love..
clee1982734.50
      04-28-2020, 07:52 PM   #11
DocWeatherington
Drives: F90 CP
Sounds promising, if it actually stiffer and more dynamic than the already rigid G20.
BMW could pull it off.. they didn't go crazy on the LCI 5 series so IDK..... June needs to hurry up or someone needs to leak a bunch of official photos.
Poochie5994.00
      04-28-2020, 08:34 PM   #12
praxis218
Drives: 2017 M3 DCT
It looks athletic even through the camo. Something I can't say for most cars.
Current: 2017 F80 M3
Retired: 2016 340i, 2015 335i, 2011 335is, 2007 328i
Sedan_Clan7039.50
      04-28-2020, 10:12 PM   #13
am3r1ka
am3r1ka's Avatar
Drives: 2011 335d
2011 E90  [0.00]
Don't forget this
Retired: 2011 328i
      04-28-2020, 11:18 PM   #14
pbar
pbar's Avatar
688
Drives: 2017 M4 ZCP (DCT)
Originally Posted by am3r1ka View Post
Don't forget this
Red line at 6500rpm?
      04-29-2020, 03:06 AM   #15
Colinv6
Colinv6's Avatar
3291
Drives: E92 M3 competition
Those digital gauges are sooooo awful.
Is that the only mode, or can you at least have twin round dials? I detest those spaceship style bars and one is back to front FFS.
2012 Mineral white/fox red competition package
Instagram mineral_e92comp
Appreciate 6
scrammer389.50
stein_325i9020.50
Jockey2579.00
maxim7712.00
en1gma50.00
Germanauto5684.00
      04-29-2020, 03:28 AM   #16
G21-M340i
Drives: M340i Touring
You get used to them but ‘real’ dials were better.
You can run ‘minimal mode’ to hide some of the noise.
clee1982734.50
      04-29-2020, 08:12 AM   #17
DocWeatherington
Drives: F90 CP
E-boost M3/M4 please
      04-29-2020, 09:56 AM   #18
duky
The Tanzanian
duky's Avatar
Drives: BSM F80
2016 BMW M3  [5.00]
Woooooo June is around the corner. Can't wait!! M4 come to me
Current: 2016 F80 Black Sapphire Metallic on Silverstone
Former: 2007 E90 335i Barbera Red on Terra Dakota
      04-29-2020, 10:04 AM   #19
m3welt
m3welt's Avatar
Drives: 2018 M2
Is it me or does it look like the grills are going to be smaller and more in line with the 3 series? I thought they were going to share the massive ones on the leaked m3/m4's?
18 F87 M2 LCI BSM 6MT
84 R100 RT Café
Past:
2015 F80 M3 Mineral Grey DCT
2005 E46 ZCP M3 Silver Grey 6MT
1998 E36 M3 Silver 5MT
1968 E10 2002 Roundie Grey 4MT
      04-29-2020, 10:16 AM   #20
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Ouch...
Same here - so many unknowns at this early stage. Reserving my opinion until a production model can be driven.
Whoever designed and approved digital gauges must have been a fan of Honda's Civic Cyber Night Japan Cruiser 2020. How about thoughtfully offering drivers a choice and providing at least a digitized rendition of analog gauges with orange on black color scheme? Breitling Old Navitimer never went out of style.
      04-29-2020, 10:16 AM   #21
Ghostriderf80
Got Tools?? Use them.
Ghostriderf80's Avatar
748
Drives: Just a BMW
This sounds like a nice car. It sounds very promising. Sounds like the M4 Comp is on my list.
1980 VW Rabbit 8v- 4spd - #1 First car - Thanks Dad
2014 M5 past 2016 M3 Comp DCT
Porsche Cayenne S
Porsche Macan S
Future Porsche 911
      04-29-2020, 10:24 AM   #22
TheM3Boy
TheM3Boy's Avatar
Drives: 335i M-Sport
Looking forward to the Gran Coupe!
Copyright ©2000 - 2021, vBulletin Solutions Inc.
