05-09-2020, 10:09 PM | #1 |
Rep 771
What size wheels can II use on 19x9.5 all around? M340 x drive
Hi guys,
Wanted to know if it would be safe for me to run 235/35/19 (fr) and 255/35/19 on x drive? I just got my new wheels shipped to me 19x9.5 all around.
Instagram: Bmw_Captivate
05-10-2020, 12:12 AM | #3 | |
Rep 771
05-10-2020, 06:34 AM | #4 |
Rep 210
It's only a 1/2" but will the different overall tire heights work with the x-drive?
05-10-2020, 09:37 AM | #5 |
Rep 28
Hmm I’m afraid that your inset in the front wheels are too big and it’s going to rub against the front struts. Your new wheels’ inset are 155.7mm which is 27.1mm Closer to the strut compared to stock. I am running a square 9 et30 and I ended up running 3mm spacers up front because even mine were sitting too close for comfort. So mine are now 9 et27, which gives me an inset of 141.3mm (12.7mm closer to strut than stock).
You are running 235 up front so that should help with clearance but also give you a stretch look on 9.5. Did you try a test fit with the wheels to make sure you have enough clearance up front? |
05-10-2020, 10:41 AM | #6 | ||
Rep 771
05-10-2020, 01:13 PM | #7 |
Rep 28
I see, right now the difference in diameter is >2% which is not recommended for X-drive. So i think your safer bet would be to go 235/40 or even 245/35 as these have difference in diameter of 1.4% and 1.1% respectively, much safer choices for the x-drive differential.
Also if you are okay with going square setup then do it so you can also rotate all 4 tires. That’s what I did, and I am running 255/35/19 in all 4. |
M340_pilot88.00 |
05-10-2020, 01:23 PM | #8 | |
Rep 771
05-10-2020, 04:54 PM | #9 | |
Rep 2,369
05-11-2020, 03:13 PM | #10 |
Rep 28
Yeah of course here is a pic. I also have more pics on my Instagram @510_m340i If you want to take a look at the progress!
https://www.instagram.com/510_m340i/ |
Mr.G20 M340222.00 M340_pilot88.00 |
05-11-2020, 09:55 PM | #11 | |
Rep 2,369
05-11-2020, 10:13 PM | #12 | |
Rep 28
As far as the grill, the car actually came with the black grill from factory as an "extra" option. I actually would consider getting the all black diamond grill but can't quite justify spending money to go from all black classic slats to the diamond lol. Also, in person the gray of the wheels and the cerium gray accents do not actually match. I am in the process of trying to get rid of all cerium gray accents on the car lol. First, got the black lower grill accents and have some black mirror caps coming in soon too |
05-12-2020, 08:06 AM | #13 | |
Rep 2,369
07-07-2020, 09:05 PM | #15 |
Rep 189
For xDrive i'd try to get as close to the same diameter as possible. Looks like stock 225/40/19 and 255/35/19 have only 0.1" of difference in diameter.
https://tiresize.com/comparison/ |
