2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions BSM w/ Shadowline M340i G20 vs M440i G22 Visual Comparison
View Poll Results: Which do you prefer?
G22 M440i 43 26.22%
G20 M340i 121 73.78%
Voters: 164. You may not vote on this poll
      06-03-2020, 08:23 AM   #1
unfoundnemo
Drives: 2018 M3 (F80 ZCP)
2020 BMW X7  [0.00]
2018 BMW M3  [0.00]
BIMMERPOST
     Featured on BIMMERPOST.com
BSM/shadowline is the best way to mute that grille and give the new 4 some visual help, so here's are some visual comparisons of each using the UK configurator:
2018 M3 / F80
2020 X7 / G07
Gone: 2017 X5/ F15
Gone: 2016 X6 / F16
Gone: 2015 4 series GC / F36
Last edited by unfoundnemo; 06-03-2020 at 08:25 AM.. Reason: fixing image extensions
Appreciate 6
      06-03-2020, 08:57 AM   #2
SteveX3M40i
SteveX3M40i's Avatar
United Arab Emirates
253
Drives: BMW X3M40i
Hi,
I think an M440i in all black would look pretty good!
In above photos - actually makes the 340 look pretty old fashioned, by comparison!
Cheers
Steve
Checkout my Instagram @carsandheels
www.carsandheels.co.uk
Appreciate 6
      06-03-2020, 09:01 AM   #3
mkoesel
Moderator
Drives: No BMW for now
I still think the aftermarket is going to come through will G22/G23/G26 grill replacements that effectively cut the grill in half top to bottom, remove the texture from the lower portion of the grill, and allow it to blend in with the lower air inlet.
These will work best with black paint and black grill surrounds as seen here, but even for other colors it will help. And if you go further and come up with replacement grills/surrounds that change briefly to body color starting at the top of the license plate area and finishing at the bottom of it, it'll work on any color.
Of course a replacement front bumper with a shorter grill would be an even better solution, but I think that something simple like the above could work as a quick, easy to install fix for those who don't like the OEM look.
pz6192614.50
dezzracer608.00
      06-03-2020, 09:18 AM   #4
unfoundnemo
2020 BMW X7  [0.00]
2018 BMW M3  [0.00]
Of course a replacement front bumper with a shorter grill would be an even better solution, but I think that something simple like the above could work as a simple, easy to install fix for those who don't like the OEM look.
Seeing the the European license plate itself does a somewhat decent job of splitting the grill, I could imagine a simple trim piece going in that location (sort of an elongated H shape with some curves) that wouldn't even require a grill replacement, just a couple of bolts mounting it like that plate and you're good to go.
2018 M3 / F80
2020 X7 / G07
Gone: 2017 X5/ F15
Gone: 2016 X6 / F16
      06-03-2020, 09:27 AM   #5
mkoesel
Moderator
Yep, that's certainly another possible solution. But, since it would sit on top of the existing parts it might look a bit unsightly from the side or other angles. My thought was that a product that incorporates replacement grill/trim would perhaps offer the best combination of easy DIY-installability and positive visual impact.
I'm sure the wizards who design all the popular aftermarket items like US reflector deletes and other cosmetic mods will come up with some great ideas.
      06-03-2020, 09:29 AM   #6
kalien34
Drives: 2017 X5 40e CB M Sport
It seems shadow line can only go with the jet black wheels according to the UK configuration?
      06-03-2020, 09:35 AM   #7
mkoesel
Moderator
Even If that's the case it could be unique to that region.
Unfortunately, in the US, I think you still can't even get an M340i with black trim from the factory, so the same might apply to the M440i. I suppose it's possible they could offer it port installed starting later this year though, even if just for the G22.
      06-03-2020, 10:00 AM   #8
kalien34
I think for 2021MY you can. There's a new separate Shadow Line package you can choose, and it's $350 or $300.
mkoesel6402.00
      06-03-2020, 10:33 AM   #9
TheGreatestDane
Drives: 2015 F32
3 to 4 is...Jaw dropping?
      06-03-2020, 10:37 AM   #10
low135
low135's Avatar
2280
Drives: E88 135i
I just wish the G80 followed the G20 front end styling
Fitzy4GC109.50
AlexFL3489.00
      06-03-2020, 10:40 AM   #11
Loma
Loma's Avatar
Poland
283
Drives: BMW
G20's front looks more aggressive and sporty.
      06-03-2020, 10:46 AM   #12
Ice M4n_f82
Drives: F82 M4 Bmw
I'm sorry but I hate the grille. The car had so much potential but I just can't see past it.... maybe the M will be better.... but I'm not optimistic
      06-03-2020, 10:48 AM   #13
velvet_F82
Individual Enthusiast
velvet_F82's Avatar
Drives: 2020 M4 Heritage Edition 6MT
G20 is where it's at for this generation. Still doesn't hold a candle to F8x though.
2020 BMW M4 Competition
Edition ///M Heritage
Individual Velvet Blue Metallic
6MT, H&R VTF Kit, 15mm Spacers F/R
low1352279.50
      06-03-2020, 10:54 AM   #14
bimmer_335
Drives: 540 mSport
I've never seen such a busy front end on a bimmer... they went over the top with lines and angles. My head hurts looking at the front end alone...
      06-03-2020, 10:55 AM   #15
bluzbra
bluzbra's Avatar
Drives: '20 X5 40i / '18 M3 Comp.
G22 all the way. Looks super sleek and 10x better than the G20 in every angle, IMO. Excited to see what the GC will look like.
Current BMWs - '20 X5 sDrive40i xLine Alpine White/Coffee Extended Merino, '18 M3 Comp. BSM/Black Extended Merino
Past BMWs - '19 440i GC M-Sport, '18 X5 sDrive35i, '18 340i, '17 X3 sDrive28i, '15 335i xDrive Sport Line, '14 428i Coupe
      06-03-2020, 10:59 AM   #16
praxis218
Drives: 2017 M3 DCT
The 4-series looks so much better. And finally they've made the side profile interesting enough where it doesn't suffer from long slab syndrome like in E92/F32.
Current: 2017 F80 M3
Retired: 2016 340i, 2015 335i, 2011 335is, 2007 328i
oz555220.00
Fhey414.00
ring0r96.50
      06-03-2020, 11:12 AM   #17
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 15 X5, 15 535i MSp, 17 M6GC
2017 BMW M6 GC  [0.00]
2015 BMW 5 series  [0.00]
2015 BMW X5  [0.00]
Paint that fking G22's face in Vantablack already.
The rest of it doesn't look too bad, keeping in perspective it's being compared to a G20.
      06-03-2020, 11:13 AM   #18
emulajavi
emulajavi's Avatar
Spain
232
Drives: MINI JCW F56
4 series vs 3 series
Kidneys done wrong vs kidneys done mostly right
Hood line done wrong vs hood line done right.
      06-03-2020, 11:19 AM   #19
Fhey
Drives: BMW 430i
2016 BMW 430i  [0.00]
It's region specific. The Belgian configurator allows you to select the shadow line package regardless of wheel choice.
      06-03-2020, 11:19 AM   #20
pz619
Drives: F87 M2C
When I turn the backlight and contrast on my laptop all the way down, the 4 series grill doesn't look half bad!
      06-03-2020, 11:24 AM   #21
DPHTOY
Drives: 2020 M4 Vert. 2019 X5 40i M-Sp
The front looks they they tried to one up Edsel, by putting two hideous Edsel grills side by side. Hoping they do something to make the M4 look better or I will sadly be replacing my current F83 with something other than a BMW.
      06-03-2020, 11:25 AM   #22
f32spaceship
f32spaceship's Avatar
Drives: 2013 328i sportline
I like the shape of both and the grills of the 3.
2015 black sapphire 435i m sport. Matte black AG m359's. Matte black grills and side sills. 18% tint. Bm3 stage 1.
retired-
2013 "jetblack_f30" 328i sport line
Copyright ©2000 - 2020, vBulletin Solutions Inc.
