BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Bouncy ride at high speed.!
09-23-2008, 01:18 AM | #1 |
PuffPuffPass
52
Rep 1,096
I've been noticing that my car seems really bouncy at high speeds when i hit a smallest bump or dip or even change lanes.
The car feels like the top of the cars going up and the wheels are gripping the road. When going kinda fast and i hit the smallest dip or a bump the car bounces so much you kinda feel like body is getting airborned somewhat. Also when i switch lanes and hit like a dip the car bounces so much that feels like i might lose control sometimes. Is this because its an xi? Would lowering the ride cure this issue? Or does this have anythign to do with the RFT's maybe?
My right foot weighs more than my left for sure. |
09-23-2008, 02:22 AM | #2 |
Ez tur90
189
Rep 3,191
Ive been having the same problem! I asked my friend why hasnt my car been handling like it usetoo he said it might be from the tires. Since we both have falkens on our car and he Im guessing it is the tires. He drives a s500 and he has the same problem as I do. Are your rims stock?
09-23-2008, 02:32 AM | #3 |
PuffPuffPass
52
Rep 1,096
Yup stock 17's with rft. Conntinetal i think. It feels more like the cars suspension is really bouncy high.
09-23-2008, 10:07 AM | #4 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
It's the xi suspension. I dont think tires have anything to do with the car feeling "airborne", which i do experience at times. because our ride height is very high, the center of gravity will increase as well, giving you that "not so sure it's on the ground" feeling when going over dips.
solution? coilovers. or drive slower
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
09-23-2008, 10:53 AM | #5 |
Rep 3,523
The suspension on xi sucks ass at high speed, not just the tires.
Depressions bottom the car out and any rise almost throws the car in the air. Xi suspension is the worst I have ever had, nothing sport about it, it is shitty. |
09-23-2008, 10:48 PM | #8 |
Surf Caster Extraordinaire
30
Rep 672
its def the suspension set up...soft springs and shocks.
I took care of that with KW V3 right away. It is really night and day difference. Actually i feel that the Xi stock suspension is unsafe for highway driving. |
09-25-2008, 09:38 PM | #9 |
Live life in this lane....
13
Rep 327
BS its the xi-suspension. And who ever posted above me, softer suspension translates into more energy absorbtion by the fluid in the shock, thus a numming affect occurs. A stiffer set up creates a harsher ride.
Tires definitely have something to do with it. RFT's are known for having a more harsh ride. Also, the 335 utilitzes very high body sensitivity values and the front suspension is designed to let the driver know what type of pavement is below. Easy solution: if you see a bump/dip in the road, drive around it, thats why you have a steering wheel.
'08 E92 335xi: the girlfriend
'04 Yamaha R6: the mistress '99 Mustang Cobra: the wife |
09-25-2008, 09:58 PM | #10 |
Rep 3,983
I felt that way about it even at low speeds. Not smooth and very floaty
09-25-2008, 11:06 PM | #11 | |
Rep 2,576
If the only solution short of replacing the whole suspension is steering around obstacles, I'm getting a new car. |
09-25-2008, 11:50 PM | #12 | ||
Gearing
86
Rep 3,965
I cannot tell how disappointed I was when I bought this car. I thought it was broken. It is likely my last BWM for that reason .... I digress. Since I replaced the suspension with the KWv3, it now behaves normally and has very respectable track capabilities.
If at first you don't succeed ...
09-26-2008, 12:10 AM | #13 |
Rep 8,745
I have the Sport Suspension on an I (not XI). I had same jumpiness as you describe, so it's not just an issue with the XI. I believe the OEM suspension sucks.
The runflats don't help because they are pretty stiff, but it's not the cause of the jumpiness. Changed my suspension (springs + shocks) and a world of difference, even with the stock runflats.....car rides smoother, absorbs bumps really well and as an added bonus body rolls are reduced significantly in turns.
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
09-26-2008, 01:24 AM | #14 | |
PuffPuffPass
52
Rep 1,096
I guess soon in the future ill get a set of coilovers and call it a day.
09-26-2008, 08:21 AM | #15 |
Rep 4,163
its not just the XI.
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
09-26-2008, 08:44 AM | #16 |
Rep 1,053
I've come to accept the harsh, bone jarring "thunk" that comes from hitting dips, bumps and potholes but its the floating issue that I am concerned with. I feel like the harsh bumps/dips are more the tires and the heavier suspension but the "floatiness" has to have more to do with the ride height.
Anyone here on an e92 XI have a better experience with the slightly lower suspension on that? Does the e92 still float over crests of hills at higher speed? I actually feel like my '05 Infiniti G35 stayed a little more planted going over crests at high speed - then again I was probably going 15+ mph slower than I am in the 335. I know the XI suspension components are heavier than the I. Add in the runflats and the higher ride hight and this is the result. While I dont regret getting the 335xi, you better believe I will be at least giving the S4 a look when my lease is up. |
09-26-2008, 08:48 AM | #17 |
Rep 1,369
the XI suspension is just crap and the bodyroll is disgusting even when hitting the slightest bumps and turns. the KWv3 are the way to go.. I was skeptable at first because of the price and how their is always bias on this board towards them but since i have the XI i really had no choice. for daily driving the V3's are not needed but a suspension upgrade is! other then springs on stock shocks which IMO is not a valid option for getting ride of that bounce and "airy" feeling..
09-26-2008, 09:51 AM | #18 | |
Rep 4,393
anyways, yes, the xi suspension sucks as does the ride height. If the ride height weren't so high, i dont think it would be THAT big of a deal, but it seems that all xi cars ride around in stilts (hence the handling issues). What I don't understand is why only BMWs raise the ride height. Audi and their Quattro systems don't seem to have the 4x4 ride height issues. Oh, and another thing, don't buy springs alone. As of this point, I'm SOO tempted to just by springs (financial situation won't allow me to buy coilovers), however, there are still horror stories going around with springs busting the OEM shocks. As of this point, shocks + springs aren't an option since no shocks are available for the xi. And coilovers are too damn expensive (i.e. KW3). H&R? Who knows when those will come out...
09-26-2008, 11:56 AM | #19 |
Rep 1,369
it does it even better and smoother with the feeling of more control now that i have my KWs
09-26-2008, 08:20 PM | #20 | |
PuffPuffPass
52
Rep 1,096
+100000000 Its not bout driving around a dip or anything. If you're cruising 80~90 and you decide to change lanes and go thru the little cracks or uneven pavements the car tends to "skid over it" with a airborne feeling. It isnt rough or anything its more like too soft with no grip? Kinda scary when it happens.
10-01-2008, 04:46 PM | #22 | |
Rep 429
Also, is the .8" increase in ride height really THAT much of a difference? I've seen some other non-335 E90s and they don't look any different in the wheel gap buy maybe they had smaller rims? I'm not one to track or autocross my (stock) 08 335XI so I'm not that into the suspension to understand what the difference would feel like. I get the "floatiness" though too. It's really weird, like there's just no suspension travel so the whole car gets thrown up when going over a bump vs just the wheel/suspension moving up&down. Does anyone have a technical explanation of exactly what KX v3s or other coilovers are doing vs what the stock suspension is not able to do? e.g. the KWs have lower/higher rate springs, give 2" more travel, harder rebound and softer compression vs stock etc. thanks BB
2014 Audi S5 DSG
2011 335xi Sedan (retired) 2008 335xi Sedan (retired) |
