Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications M340 - JB4 Review
      07-11-2020, 04:11 PM   #1
aeaustinG20
Drives: M340
Recently installed the JB4 from Burger Tuning on my M340 (xdrive). Been running Map 1 & 2 for a few days. Initial thoughts on tune:
1. Super easy to install. I'm not much a DIY'er but with a couple YouTube videos it was a piece of cake.
2. Blue tooth adapter with iOS App = A+. Real time feed with the gauges is a very cool, and the ability to change maps and settings on the fly is impressive.
3. Power (even in Map 1) is serious. Instant power all through the bands; seamless shifting.
4. Ability to uninstall the tune when going in for a service; 👌🏽
Conclusion: If you're looking for a piggy back tune, this seems to be a great option. Very happy with the investment so far.
2022 X3M Comp
2020 M340 - Sold
2010 328i - Sold
      07-11-2020, 10:01 PM   #2
Dravit_M340i
Dravit_M340i's Avatar
136
Drives: 2020 BMW M340i Dravit Grey
This is one I am highly considering. Looking to stay piggy for the ability to uninstall. Glad you are enjoying it!
      07-11-2020, 10:30 PM   #3
nola2atx
nola2atx's Avatar
Drives: 2023 M2
Any performance metrics to share?
Zandvoort ///M2
Brooklyn X3 ///M50i
My Exes:
E36 325i, E46 330i, F30 328i, G20 M340i
      07-12-2020, 09:55 AM   #4
aeaustinG20
Drives: M340
Unfortunately no. I haven't really dug into the logs and have no current plans to dyno. Burger Tuning does claim gains up to 100hp at the crank on a stock car in an aggressive map though.
One of the options in the app display is ECU boost vs actual boost. This seems to be good way to compare vs stock in real-time.
2022 X3M Comp
2020 M340 - Sold
2010 328i - Sold
      07-12-2020, 09:56 AM   #5
Fuel-It!
Drives: M4, M5, M2C, X4M, 440i, etc...
JB4 is a very advanced and well designed system, glad to read you're enjoying it.
      07-12-2020, 10:02 AM   #6
aeaustinG20
Drives: M340
Thanks. You won't be disappointed.
2022 X3M Comp
2020 M340 - Sold
2010 328i - Sold
      07-12-2020, 03:12 PM   #7
Swagasaurus-R3X
Swagasaurus-R3X's Avatar
Drives: BMW M340i
I called BMW last week to ask about flashing and different piggy back systems. Without me eluding about the JB4 they stated they see maybe 1 or 2 of them a year and can detect if a car has had a piggy back on it through the number of key cycles. I am not really educated in this but would like to know 100% if it can be detected because I would like to install the JB4 but don't want to risk warranty.
      07-12-2020, 03:20 PM   #8
chenry
Drives: BMWs
yes 100% any engine mod can be detected if BMW wants to dig deep enough (piggyback or flash doesn't make a difference - question those that tell you otherwise) - that said are you likely to experience a catastrophic failure of a magnitude that would cause such a probe....not likely unless you move well beyond a simple AA/JB4/RaceChip (piggybacks) or flashes stage 1 or 2 (Mission Performance, BM3, MHD) etc . But given your question and your reference to 100% the answer is no - nothing is fool proof.
That said - keep in mind a piggyback or flash (either one detected) does not simply cancel your warranty - here in the US your mods only cancel the portion of your warranty that covers parts you may have compromised by making changes
Hope this helps a bit
      07-12-2020, 03:59 PM   #9
hayko_M340
Drives: 2020 BMW M340I
I also have a JB4 installed on my M340 as well. Love it but there are a few issues you may run into. Seems as if Jb4 isn’t as optimized for the M340 B58’s yet. On Map 5 with a E30 mix it’s a gamble whether the car will function properly or not. Throws a drivetrain malfunction for me and seems to be running quite lean most of the time. Map 1 & 2 with 91 pump are solid though, never had a issue. Only run into issues whenever I push it a little. Love it regardless highly recommend it but just give it time so they figure some stuff out. Let me know if you run into any similar issues.
      07-12-2020, 10:41 PM   #10
Fuel-It!
Map5 is a pretty aggressive map! They have a G20 M340 for development purposes so if you need tuning help just get in contact with them.
      07-13-2020, 11:54 AM   #11
Swagasaurus-R3X
Drives: BMW M340i
This helps a lot. Thank you. Question though.... What portion of the warranty would be compromised with installing a JB4 and/or a flash tune?
      07-13-2020, 01:44 PM   #12
Antec800
Drives: 340i x drive
The whole engine/turbo and possibly transmission/driveline warranty.
      07-13-2020, 04:09 PM   #13
Fuel-It!
I've heard people say the above but I don't understand why, there is virtually no similarities in how tunes are detected between a reflash and a JB4. With a reflash actual load and torque values are changed and the true higher than factory values are stored in the ECU, transmission computer, stability control computer, and others. These values stick out like a sore thumb during a routine scan.
With a JB4 or any well designed piggyback the ECU is never aware it's making more boost, load, or torque than factory so all these peak values remain at factory levels.
      07-13-2020, 04:20 PM   #14
aeaustinG20
Drives: M340
Thanks, I'll keep that in mind as I get more experience with the available map settings.
Map 1 & 2 with 93 octane have been flawless so far. As a daily driver, it's likely I won't be out of these two all that much.
2022 X3M Comp
2020 M340 - Sold
2010 328i - Sold
      07-14-2020, 10:54 AM   #15
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Congrats OP
https://x-ph.com/sale/
Phone number 725-221-5267
      07-14-2020, 10:58 AM   #16
possible335i2008
Drives: m2
Does anyone have any actual situations where an engine issue has occurred when a JB4 was installed and prior to warranty claim the JB4 was removed and BMWNA was not able to tell the vehicle had been modified?
      07-14-2020, 11:59 AM   #17
Fuel-It!
No one is going to admit to warranty fraud in public but it's rare to find anyone who has ever been denied due to say a JB4 that was properly removed. Those who get flagged either have flash tunes or other mods like downpipes that are easily detected.
      07-14-2020, 12:00 PM   #18
possible335i2008
Drives: m2
Is there an engine failure thread anywhere for people tuned on a JB4/flash
      07-14-2020, 10:08 PM   #19
retart13
Drives: M340i Xdrive
...or other mods like downpipes that are easily detected.
Downpipes are concern for warranty issues? I thought they were like an extension of bolt on exhausts?
      07-15-2020, 07:24 AM   #20
possible335i2008
Drives: m2
The downpipe is directly connected to the turbo, it will 100% void your warranty as you are also tampering with an emissions device. What part of the warranty it will void can range from just the turbo to the whole power train.
      07-15-2020, 07:18 PM   #21
Pacman123
Drives: Mazda 3 , BMW M340i Xdrive
Would getting quad tips welded onto the exhaust tips of the stock system void the exhaust system warranty? I figured because it was purely cosmetic it should be fine but haven't asked bmw to confirm.
      07-15-2020, 08:00 PM   #22
possible335i2008
Drives: m2
It would void the exhaust itself, so if the welds rust and it somehow messes up the rest of the exhaust or muffler then that wouldn't be covered, typically YMMV.
