07-26-2020, 10:47 AM | #1 |
Rep 714
I ordered the OEM roof rack from GetBMWParts.com which is for the most part is good. However, the installation tool failed (rounded off) after two installations (see attached picture). I am now using my own Allen tool, but I run the risk of over torquing or under torquing during installation. This dealer tried to have BMW provide a replacement but told them that is not possible and requires me to order a new kit. If you are in the fence with the OEM kit and Thule, I would recommend a Thule.
My installation tool from my 14 year old E90 roof rack is still good. So I'm not sure why BMW's vendor for this kit did not have the same quality. I wanted to make sure everyone is aware. I am sending my information to BMWNA. Cheers!
07-26-2020, 05:25 PM | #2 |
Rep 1,771
Same thing happened to me after 2 times... the service manager at the dealership chopped the rounded tip off of my tool so that i can use it again, but i suspect it will happen again once i continue to use it :
Instagram: @dg_g20
seccsc239.00 |
07-27-2020, 08:20 AM | #3 |
Rep 714
That's what I was thinking but I'm sure the same issue will occur. The whole thing can be disassembled. I'm going to see if I can modify an Allen tool and replace the deficient piece.
07-27-2020, 05:06 PM | #4 |
Rep 2,499
Is there a built-in clutch on the handle? Why would you risk over/under torquing if you used your own allen wrench?
That looks like fairly cheap tool steel. Probably made in China using cheap steel. |
07-28-2020, 08:57 AM | #5 | |
Rep 714
The possibility of under-torquing is much more prevalent than over-torquing. However, based on the fine threads, there is a risk of damaging the fastener or insert if using a long handle Allen wrench and untrained operator. Cheers!
07-28-2020, 09:50 AM | #6 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
I had the OEM version for my F35 and it's still in good shape after a couple of installation, this cross bar is made by Thule and pretty sure you can order it from a local rack store or BMW shop.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
seccsc239.00 |
07-28-2020, 11:04 AM | #7 |
Rep 714
I received an email from BMWNA.
GetBMWParts.com is not an authorized BMW dealer and I was directed to contact my local dealer for assistance. BMWNA can not assist me directly.
07-28-2020, 10:47 PM | #8 |
1131
Rep 5,557
Getbmwparts is under Silver Spring BMW wing and they are legit place to obtain genuine BMW parts.
