08-10-2020, 05:26 AM | #1 |
![]() ![]() 114
Rep 320
USB stick size and file format?
Hey guys, I have a question, has anyone tested if the G20 supports the NTFS format, or is it just FAT32? Additionally what's the max USB storage the G20 can handle, 128gb/256gb or unlimited?
08-10-2020, 05:00 PM | #3 |
![]() ![]() 114
Rep 320
Can confirm, 128gb works, movies and music play, though can't play subtitles for movies so you need them in the native language of the kids. Tried FAT32 only and it works, maybe will try NTFS, but I am almost certain it will not work, due to how outdated the car manufacturers are.
08-11-2020, 04:36 AM | #4 |
![]() ![]() ![]() ![]() ![]() 421
Rep 724
San Disk Ultra Fit
USB 3.1 64GB Formatted in FAT32. File structure is /Artist/Album Everything works "fine" - although the car doesn't remember where it left off nor does it remember that it was set to shuffle. So, it's starts on the same song every time I turn the car on. No clue what the issue is there? |
08-11-2020, 05:17 AM | #5 | |
![]() ![]() 114
Rep 320
08-12-2020, 09:38 AM | #6 |
![]() ![]() 114
Rep 320
Upload 66GBs on my USB stick and put in the car and it literally died, luckily the USB stick is still under warranty so I'm getting a replacement for free tomorrow. Will try that and update you guys on how it works with movies and music, unless it dies again
08-12-2020, 08:12 PM | #7 | |
![]() ![]() 665
Rep 364
Drives: 2020 M340i RWD
I use a super-low profile Kingston 128 GB combo USB 3.0/USB-C drive plugged into the USB-C port in the center armrest. I had heard early on that the standard USB interface may not work as well as the C, and my testing seemed to bear this out. I only got it perfect once I used the USB-C. Bonus is that it is impossible to spill drinks on it and you never bump it in the center console! I use iTunes for my library, and then I used a program called iTunesFusion. I think there was a 1 month trial on it and then it was pretty cheap and totally worth it. This program effectively allows a USB drive to sync to your iTunes library. When you build the sync profile (the rules for creating the folder structure on the USB drive), these are the settings that worked for me: Destination Folder \Music Album Art Resizing (you do this once) Check the box and set the size to 600x600. Necessary for correct display and reading of album art. For playlists to work (.M3U files), they must be synchronized to the root of the drive, and the checkbox for "Remove Leading Backslashes..." MUST be checked. The drive will show a Music folder at the root and then all the playlists loosely. This is the only method that worked for me. When done, verify the playlist format by opening your playlist file in Notepad. It should look similar to this: #EXTM3U Music\Alice In Chains\Facelift\01 - We Die Young.mp3 Music\Alice In Chains\Facelift\02 - Man In The Box.mp3 Music\Alice In Chains\Facelift\03 - Sea Of Sorrow.mp3 Hope this helps you!
"Christy" - 2020 BMW M340i 8AT BSM / Black&BlueStitching
Gone! "Edna" - 2011 BMW 335i 6MT TiAg / BlackOyster - M-Sport, Premium, Comfort Access, Navigation, Heated Seats, Rollerblinds R.I.P. "Heidi" - 2005 BMW 330xi 6MT BSM / Black - Sport, Premium, Cold Weather, Harmon Kardon, Navigation |
3erMan143.50 |
08-19-2020, 04:48 AM | #8 |
![]() ![]() 146
Rep 74
I just bought and installed a 512GB Sandisk Fit Ultra in mine and worked perfect. Also, formatted as NTFS. I have it maxed out with lossless FLAC - a mix between 16 and 24bit and all plays perfectly. I, however, just noticed this morning that when starting the car cold, it does not resume play from where you were listening. Instead, it plays the first tract in the first artist's album on the disk. That's a bother.
https://www.amazon.co.uk/SanDisk-Ult...083ZS4HYD?th=1 |
08-19-2020, 04:51 AM | #9 | |
![]() ![]() 114
Rep 320
That's why I always play in shuffle. |
