Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Where is the negative battery terminal in the engine bay on a G20 B58?
      12-03-2020, 02:53 AM   #1
ToeJoe
Drives: 2020 M340i xDrive
Hi all,
Noob question. Can anyone confirm where the negative battery terminal is on the M340i in the engine bay? A mate needs a jump start. So while I can clamp negative to ground on his car, I need to know where the negative is on mine. BMW manual is very vague and alludes to a "special point" that points to nothing (thanks BMW).
Although unlabelled unlike the positive terminal, I'm guessing it's this protrusion. Anyone know for sure?
(Yes this is a 320i or 330i but it's the same layout)
Name:  Screen Shot 2020-12-03 at 6.45.47 pm.png
      12-03-2020, 07:30 AM   #2
Yossi123
Drives: 330xi G21
Originally Posted by ToeJoe View Post
Hi all,
Yep, this is the negative terminal.
For additional confirmation, stolen from other thread:
ToeJoe1.50
VipinLJ1630.00
      12-03-2020, 10:54 AM   #3
ToeJoe
Thanks champ!!! Much appreciated
      12-03-2020, 06:43 PM   #4
M340_pilot
Maybe this helps too
2020 M340i
BM3, VRSF catted dp, MPE, Dinan springs
      12-09-2020, 01:14 PM   #5
ToeJoe
Yeah but that is the vague and incorrect diagram in the Owner's Manual I was referring to.
The positive terminal is labelled in the bay so is easy enough to find, and its position correctly identified by the manual.
However for the negative terminal, the arrow is pointing to .... what? It looks like it's pointing to some section of the chassis. There's nothing at that location in the engine bay, I checked.
Or are they pointing to this?
That's what I then thought they meant, but that's just a chassis bolt, it's not a terminal. So the manual is plain wrong. You can see from my and Yossi's photos that the real neg terminal is just aft of the washer fluid tank cap, but it's not even shown in the manual, much less correctly identified with the arrow!
      12-09-2020, 03:35 PM   #6
VipinLJ
VipinLJ's Avatar
Drives: 20 330i,16 X3,18 SQ5,17 A7
The photo Yossi123 is the correct one. The manual is wrong.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      12-09-2020, 08:10 PM   #7
M340_pilot
The manual is def off. I used it as a reference and found the neg terminal in a few seconds. Apologies if the pic made things worse.
2020 M340i
      12-14-2020, 11:09 PM   #8
ToeJoe
No need for apologies at all, thanks for trying to help!
Copyright ©2000 - 2021, vBulletin Solutions Inc.
