12-06-2020, 11:12 AM | #1 |
Rep 19
Need help identifying which brakes I have.
Hello I have a new 340 without ZTK. My only complaint with the car are the brakes do not have initial bite or great stopping power.
I am considering m performance brakes as that is the only upgrade I am aware of but I cannot tell if I already have the same size brakes as m performance brakes ? Need advise the best or most affordable option to upgrade my brakes maybe even different brake pads ? |
12-06-2020, 01:05 PM | #2 |
![]() ![]() 651
Rep 1,470
Drives: 2020 M340Xi (G20)
Solid2021,
I have a 2020 M340; one of the standard items that came with the car was S2NHA M Sport brakes -- just checked the VIN decoder. So you might already have M brakes Having said that I agree with you that the car needs a little better brakes, particularly on the track.
Al
![]() 2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
12-06-2020, 04:27 PM | #3 |
![]() ![]() 3081
Rep 4,210
Yes...you have the MSport brakes. On a 2018 5 series, the regular brakes were sliding one piston in the back and two fixed pistons in front; the MSport had a fixed two piston caliper in the back and four piston caliper in the front.
12-06-2020, 05:38 PM | #4 | |
![]() ![]() 97
Rep 143
12-06-2020, 05:52 PM | #5 |
Rep 19
From the research I have done it appears I have the m performance brakes. I copied a picture another member posted who updated from M sport to M performance brakes you can see there’s slight differences in the design of the caliper and the design matches the calipers I have on my car.
It appears to me the only difference between my current brakes and what’s included with the m performance brakes are the dotted rotors. I very curious to see pictures of the actual brakes on a car with the heating and cooling package as that is supposed to have upgraded brakes. |
12-06-2020, 06:47 PM | #6 | |
![]() ![]() 238
Rep 287
Edit: After looking closer i think you're correct. The size from a Picture can really play tricks. |
12-06-2020, 06:54 PM | #7 |
![]() ![]() 4597
Rep 3,603
Definitely not the upgraded caliper or rotor size that you got with the 2020 ZTK package.
Current: 2022 Audi RS5 / 2022 Audi Q7
Gone: 2020 BMW M340i / 2019 Audi RS5 |
12-07-2020, 11:36 AM | #8 |
![]() ![]() ![]() ![]() 332
Rep 742
I think you have standard M sport brakes.
The 2 piston placement circles are too close together. (Purple) If you look at the 3 dots above each piston ciclenon the outer edge you will see INDENT - HOLE - INDENT is the M sport and the M performance have the holes on the outside of each set of indentations. (Orange) The opening above the ///M logo looks smaller in the comparison photo you posted, but this is due to the slightly different angle in that shot. The M performance calipers would extend further above and below the standard sized rotor you have (green) Last edited by siegester; 12-07-2020 at 11:42 AM.. |
JTYAMSHAYIN238.00 |
12-07-2020, 12:49 PM | #9 | |
![]() 3540
Rep 2,292
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser 2011 E90 M3 ZCP Past: E90 328i, F10 535i, F80 M3 (murdered) |
12-07-2020, 02:07 PM | #11 |
![]() ![]() 4597
Rep 3,603
Here's the caliper from the cooling package (ZTK) from my 2020 M340i. You can see it is the same as the red upgraded "M Performance brakes"...
OM3RTA386.50 |
12-07-2020, 04:00 PM | #12 |
![]() ![]() 387
Rep 1,034
12-07-2020, 04:05 PM | #13 | |
![]() ![]() 387
Rep 1,034
12-08-2020, 07:22 AM | #15 |
![]() ![]() ![]() ![]() 340
Rep 400
12-08-2020, 08:54 AM | #16 |
![]() ![]() 4597
Rep 3,603
Yes, minus the cross drilled and slotting on the rotors (same size rotor and caliper though).
12-08-2020, 01:50 PM | #17 | |
![]() ![]() 2177
Rep 2,533
1. M sport level 1: standard m340 brake setup 348mm rotor, caliper available in blue or red 2. m sport level 2: ztk factory upgrade includes flat steel 374mm rotor (front) and larger caliper: available in blue or red 3. M performance brakes: aftermarket bmw performance part, (do not believe these are a port option), includes slotted and cross drilled 374mm rotor (front), slotted and cross drilled rear rotor, and larger front caliper. only available in red? |
Burrcold4596.50 |
12-08-2020, 05:18 PM | #18 | |
![]() ![]() 4597
Rep 3,603
12-10-2020, 12:07 PM | #19 |
![]() ![]() 387
Rep 1,034
12-10-2020, 12:13 PM | #20 |
![]() ![]() 1991
Rep 2,499
Are you sure you guys aren't mistaking initial bite for brake performance? A lot of lower end BMW brakes have extremely sharp initial bite but that's not desired behavior for a performance brake. Performance brakes should have even travel and be confident in high speed braking. and also be more tolerant of brake fade.
A good performance brake will seem like they actually stop better at high speeds than at low speeds. |
12-10-2020, 12:34 PM | #21 | |
![]() ![]() 97
Rep 143
