12-07-2020, 04:38 AM | #1 |
Rep 7
2012 F30 328i Waterpump failure leading to ECU failure
Just wondering if other have encountered this issue or its a well known problem. Took my F30 back to the BMW dealers for some recall work. Was then my water pump failed which then possibly short circuited the ECU.
The car was then taken to a ECU specialist which couldn't point out to the specific cause for this problem. The Water pump still works but pumps at 100% and the ECU cannot communicate with the water pump. Car still drivable, I'm suspecting possibly something was caused by the recall but the dealers are denying that and refusing to accept responsibility. Anyone else encountered this? |
12-07-2020, 05:59 PM | #2 | |
Rep 68
12-09-2020, 06:17 AM | #4 | |
Rep 7
12-09-2020, 06:21 AM | #5 |
Rep 7
Main one was the replacement of the fuel tank as well as changing some corrosion protection of engine compartment. I just don't really believe that the chances can be thay likely some thing unrelated fails while it's in the dealers care.
12-09-2020, 10:33 AM | #6 |
Rep 16,175
I can't see how a bad water pump can damage the ECU. It's not like the ECU is cooled by the cooling system. No communication with the water pump, or anything else for that matter, is usually a wiring or connector problem.
12-09-2020, 11:26 AM | #7 |
Rep 146
Would it be possible that a short in the water pump could feed back up to the ECU in some way?
12-09-2020, 11:52 AM | #8 |
Rep 16,175
Not likely. The ECU sends voltage to the pump. If that shorts out it should blow a fuse before causing damage. I had a similar issue with a emissions evaporation sensor. My scan said there was no sensor contact with the DME module, and no voltage present at the sensor. It turned out to be insulation on the wire between the sensor and DME had been chewed by a mouse. The exposed copper conductor corroded and eventually broke.
Phoenix70488.00 |
12-14-2020, 07:08 PM | #9 |
Rep 4,917
What do you mean by "water pump failure". If something happened that you had an unlikely short in the motor, then I suppose it's possible to blow out the ECU control circuit, but as Billfitz said, there should be a fuse in line which should have spared it before that happened.
Tags |
ecu, water pump failure |
