Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications 2020 M340i JB4 & catless DP RWD / update
      01-09-2021, 06:59 PM   #1
Jperezivan
Drives: 2023 M2
I figured I would post my results to help others in the future decide if the JB4 it’s worth it since in my search I saw mixed reviews.
I will post my best run stock and my recent run after JB4 and DP install. All runs were done on 93, the JB4 run was done in map2.
Update
New run completed using Map3, I did add 1 gallon of E85 to 8 gallons of 93. Per some online E calculators it’s running an E18 blend. I did order the EWG connector so waiting on that to raise the E content. Still planning on taking it to the track to this week to see what she runs on a prepped surface.
      01-09-2021, 11:20 PM   #2
VipinLJ
VipinLJ's Avatar
12.98s quarter mile stock??? Looks like you didn't use launch control?
The improvement is great though.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-09-2021, 11:39 PM   #3
Jperezivan
Drives: 2023 M2
I tried using launch control a few times, but did not have great success with stock all season tires and unfortunately I have the square set up. So 225s in the rear and rwd and launch control is not a great combination.
These runs were not done at the track. That is coming soon with a better tire set up
      01-10-2021, 12:26 AM   #4
VipinLJ
VipinLJ's Avatar
Ahhh that makes a lot of sense. I cannot imagine doing LC runs with a 380+hp car, that too an RWD, on skinny tyres!
Why haven't you tried map 3?
      01-10-2021, 12:27 AM   #5
rrfitness20
rrfitness20's Avatar
Drives: Bmw m340i
I can't wait till I get my new tire set up installed. I too have that awful square set up. Launch control paired with JB+ is more of a burn out session lol.
      01-10-2021, 07:35 AM   #6
Patgilm
Drives: GT-R, X7 M50i, M340
The mph in the 1/4 is impressive. I could only get 117-118 on my flash only tune. I wonder what I could pick up on mine with a catless downpipe.
      01-10-2021, 07:47 AM   #7
Jperezivan
Drives: 2023 M2
Good question lol, I was under the impression that to run map 3 it had to be 93+ octane so I was planning on adding a little E85 to raise the octane rating. Not sure if running it on just on 93 was kinda pushing it?
      01-10-2021, 09:21 AM   #8
rrfitness20
Drives: Bmw m340i
Would it be ok to have JB plus setting at 75% and add one gallon of E85?
      01-10-2021, 09:52 AM   #9
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
Drives: G01///G20///I20
I’d add 3 or 4 gallons of E85 to a full tank myself but I’m sure others will disagree with that
11gallons of ACN91 plus 4 gallons of E85 (assuming at least 70% ethanol) should give you about 93 octane maybe a little more or less considering how good the pump and ethanol gasses are.
You have you remember our 91 in California is more like 89 unfortunately
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      01-10-2021, 09:57 AM   #10
Banana Clipper
Jewel Runner
Do you know if your DME is locked or not? Are you using the JB4 EWG? What drive settings are you using, for example is traction control on, dsc on, lane departure on, manual shifts or automatic, etc
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
      01-10-2021, 10:07 AM   #11
rrfitness20
Drives: Bmw m340i
Currently have a Catted DP and dinan exhaust.
I've read a lot of mixed things about adding e85.
I don't have anything to measure it.
I just wanted to add one gallon and top it off with cali's crappy 91 lol.
Just wanted to know if it was ok to do so
And if there's any negatives by adding a gallon
      01-10-2021, 10:14 AM   #12
Banana Clipper
Jewel Runner
I wouldn’t get too crazy by going in on a half tank but one or two gallons shouldn’t even be debatable. I used to add a gallon or two to my hybrid accord when I was at a station with ethanol. There literally already is ethanol in pump gas and a gallon or two will barely increase ethanol content but raise octane...faaaaaaaaaaar better than using a can of “octane booster” in my opinion but as I said I’m sure others will argue the ill effects
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
      01-10-2021, 11:38 AM   #13
VipinLJ
VipinLJ's Avatar
True that. What I did was log my car on map 3 with 93 octane and send it to Ando. He said it looked fine with 93oct on map 3 and that it was safe for me to run it. I now add roughly 3.5-3.75 gallons of E85 to around 11 gallons of 93 for a full tank. That has helped my logs even more and the car feels better. You should do the same. Send BMS logs on map 2 and map 3 and see what they say.
Yes. 3-4 gallons is fine I guess. I do that in my 330i and BMS even said I could do that.
Not sure 1 gallon will do much? I could be wrong. But definitely nothing wrong in adding a gallon.
      01-10-2021, 12:51 PM   #14
Jperezivan
Drives: 2023 M2
DME is locked, and I am not using JB4 EWG.
All runs where with dsc on and on automatic in sport plus, lane departure off feathering the throttle on launch due to traction limitations. I did install Michelin PS4s
245/35zr-19 last week on the rear ,hence the better 60ft. I plan on a track day either this week or the other to see how much better the times will be with a prepped surface.
      01-10-2021, 01:00 PM   #15
Jperezivan
Drives: 2023 M2
[QUOTE=VipinLJ;27103773]True that. What I did was log my car on map 3 with 93 octane and send it to Ando. He said it looked fine with 93oct on map 3 and that it was safe for me to run it. I now add roughly 3.5-3.75 gallons of E85 to around 11 gallons of 93 for a full tank. That has helped my logs even more and the car feels better. You should do the same. Send BMS logs on map 2 and map 3 and see what they say.
Thanks for the heads up, I will definitely do that
      01-10-2021, 01:10 PM   #16
Fuel-It!
Drives: M4, M5, M2C, X4M, 440i, etc...
7mph trap speed gain is really substantial, at least 80whp gained. Traction on RWD is really hard. Using the JB4 to limit boost in 1st and 2nd will help a bit.
russell21147.00
      01-17-2021, 01:43 PM   #17
Jperezivan
Drives: 2023 M2
Once I get more familiarize with the JB4 I will try that out.
Thanks
      01-17-2021, 06:30 PM   #18
Fuel-It!
Thanks
It's easy in app when connected to car just go to user adjustment, scroll down to 1st gear boost reduction, enter 6.0, and press save.
      01-17-2021, 08:49 PM   #19
bSwiazzy
Drives: 2021 X3M
does the jb4 work with the new 2021 x3 m40i or m340i?
what downpipe ru running on the setup?
2015 Honda Civic Si // FBO + Hondata // Retired
2017 340i // FBO + BM3 // Retired
2020 M340i // Stage 2 // Retired
2021 X3M // RGSport Midpipe + MSS + RaceChipGTS // Retired
2016 Rav4
      01-17-2021, 09:20 PM   #20
Jperezivan
Drives: 2023 M2
From what I am read yes JB4 will work
Down pipe I am using is VRSF
      01-17-2021, 09:22 PM   #21
Jperezivan
Drives: 2023 M2
Sounds easy ; I will trying that out this week thank you
      01-19-2021, 02:13 PM   #22
Banana Clipper
Jewel Runner
Better 60' and thats a mid to low 11 sec run trapping 120mph
I was running low 11.8's/ high 11.7's on an E90 with 2mph less trap, I see no reason these cars cant cut a 1.8 60' with the proper suspension/wheel/tire setup.
AWD guys are already running low 11's but cut ridiculous 60ft times
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
